I have some issues understanding exactly how a BT central acting as a Client can get the info it wants from a BT peripheral acting as a Server. I have a custom periheral (running zephyr BLE on a nrf52840) that I want to communicate with a custom central (same thing, nrf52840).
The custom peripheral I have managed to get working, and it consist of a single service where a client can write to one characteristic and the client can read what has been written in another characteristic. The code is as follows:
Peripheral:
read_write_service.c:
#define BT_UUID_READ_WRITE_SERVICE \
BT_UUID_DECLARE_128(0x3E, 0x09, 0x99, 0x10, 0x29, 0x3F, 0x11, 0xE4, 0x93, \
0xBD, 0xAF, 0xD0, 0xFE, 0x6D, 0x1D, 0xA0)
// input to the peripheral device
#define BT_UUID_INPUT \
BT_UUID_DECLARE_128(0x3E, 0x09, 0x99, 0x11, 0x29, 0x3F, 0x11, 0xE4, 0x93, \
0xBD, 0xAF, 0xD0, 0xFE, 0x6D, 0x1D, 0xA1)
// output from the peripheral device
#define BT_UUID_OUTPUT \
0xBD, 0xAF, 0xD0, 0xFE, 0x6D, 0x1D, 0xA2)
static struct bt_gatt_attr attrs[] = {
BT_GATT_PRIMARY_SERVICE(BT_UUID_READ_WRITE_SERVICE),
BT_GATT_CHARACTERISTIC(BT_UUID_INPUT, BT_GATT_CHRC_WRITE,
BT_GATT_PERM_WRITE, NULL, write_input, NULL),
BT_GATT_CHARACTERISTIC(BT_UUID_OUTPUT, BT_GATT_CHRC_READ, BT_GATT_PERM_READ,
read_output, NULL, NULL),
static struct bt_gatt_service read_write_service = BT_GATT_SERVICE(attrs);
u8_t a_number = 0;
void read_write_service_init() {
bt_gatt_service_register(&read_write_service);
ssize_t write_input(struct bt_conn *conn, const struct bt_gatt_attr *attr,
const void *buf, u16_t len, u16_t offset, u8_t flags) {
const u8_t *new_number = buf;
if (!len) {
return BT_GATT_ERR(BT_ATT_ERR_INVALID_ATTRIBUTE_LEN);
if (*new_number >= 0 && *new_number <= 10) {
a_number = *new_number;
} else {
return BT_GATT_ERR(BT_ATT_ERR_VALUE_NOT_ALLOWED);
printk("write_input [%d]\n", a_number);
return len;
ssize_t read_output(struct bt_conn *conn, const struct bt_gatt_attr *attr,
void *buf, u16_t len, u16_t offset) {
printk("read_output\n");
return bt_gatt_attr_read(conn, attr, buf, len, offset, &a_number,
sizeof(a_number));
}main.c:
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
struct bt_conn *default_conn;
static const struct bt_data ad[] = {
BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static void connected(struct bt_conn *conn, u8_t err) {
if (err) {
printk("Connection failed (err %u)\n", err);
} else {
printk("Connected\n");
default_conn = bt_conn_ref(conn);
static void disconnected(struct bt_conn *conn, u8_t reason) {
printk("Disconnected (reason %u)\n", reason);
if (default_conn) {
bt_conn_unref(default_conn);
default_conn = NULL;
static struct bt_conn_cb conn_callbacks = {
.connected = connected,
.disconnected = disconnected,
static void bt_ready(int err) {
if (err) {
printk("Bluetooth init failed (err %d)\n", err);
return;
read_write_service_init();
/*if (IS_ENABLED(CONFIG_SETTINGS)) {
settings_load();
err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), NULL, 0);
if (err) {
printk("Advertising failed to start (err %d)\n", err);
return;
printk("Advertising successfully started\n");
void main(void) {
printk("starting in main \n\n");
int err;
err = bt_enable(bt_ready);
if (err) {
printk("Bluetooth initialization failed.");
return;
bt_conn_cb_register(&conn_callbacks);
Now, this is where my question begins: How can I read and write to the custom peripheral with a custom central? There are several perihperal guides and virtually none for a zephyr BLE central, just example code which is a bit hard to grapple. What I want to do with my custom central is:
- Do a service discovery and prompt to terminal a list of all services
- Do a characteristic discovery inside each service and prompt to terminal which characteristics can be read or written to
- Do an actual read and write to characteristics in the peripheral from the central.
This is how far I've gotten on the central side:
BT_UUID_DECLARE_128(0x3E, 0x09, 0x99, 0x10, 0x29, 0x3F, 0x11, 0xE4, \
0x93, 0xBD, 0xAF, 0xD0, 0xFE, 0x6D, 0x1D, 0xA0)
BT_UUID_DECLARE_128(0x3E, 0x09, 0x99, 0x11, 0x29, 0x3F, 0x11, 0xE4, \
0x93, 0xBD, 0xAF, 0xD0, 0xFE, 0x6D, 0x1D, 0xA1)
0x93, 0xBD, 0xAF, 0xD0, 0xFE, 0x6D, 0x1D, 0xA2)
#define BT_UUID_NAMING_CHARACTERISTIC \
0x93, 0xBD, 0xAF, 0xD0, 0xFE, 0x6D, 0x1D, 0xA3)
static void start_scan(void);
static struct bt_conn *default_conn;
static u8_t discovered(struct bt_conn *conn, const struct bt_gatt_attr *attr,
struct bt_gatt_discover_params *params);
static struct bt_gatt_discover_params discover_params;
static struct bt_uuid_128 uuid = BT_UUID_INIT_128(0);
static void device_found(const bt_addr_le_t *addr, s8_t rssi, u8_t type,
struct net_buf_simple *ad)
char addr_str[BT_ADDR_LE_STR_LEN];
int err;
if (default_conn) {
return;
/* We're only interested in connectable events */
if (type != BT_GAP_ADV_TYPE_ADV_IND &&
type != BT_GAP_ADV_TYPE_ADV_DIRECT_IND) {
return;
bt_addr_le_to_str(addr, addr_str, sizeof(addr_str));
printk("Device found: %s (RSSI %d)\n", addr_str, rssi);
/* connect only to devices in close proximity */
if (rssi < -50) {
return;
if (bt_le_scan_stop()) {
return;
err = bt_conn_le_create(addr, BT_CONN_LE_CREATE_CONN,
BT_LE_CONN_PARAM_DEFAULT, &default_conn);
if (err) {
printk("Create conn to %s failed (%u)\n", addr_str, err);
start_scan();
int err;
/* This demo doesn't require active scan */
err = bt_le_scan_start(BT_LE_SCAN_PASSIVE, device_found);
if (err) {
printk("Scanning failed to start (err %d)\n", err);
return;
printk("Scanning successfully started\n");
int err;
if (!attr) {
printk("Discover complete\n");
memset(params, 0, sizeof(*params));
return BT_GATT_ITER_STOP;
if (bt_uuid_cmp(discover_params.uuid, BT_UUID_OUTPUT)) {
memcpy(&uuid, BT_UUID_OUTPUT, sizeof(uuid));
discover_params.uuid = &uuid.uuid;
discover_params.start_handle = attr->handle + 1;
discover_params.type = BT_GATT_DISCOVER_CHARACTERISTIC;
err = bt_gatt_discover(conn, &discover_params);
if (err) {
printk("Discover failed (err %d)\n", err);
char dest2[150];
bt_uuid_to_str(params->uuid, dest2, sizeof(dest2));
printk("Discovered attribute again- uuid: %s, handle: %u\n",
dest2, attr->handle);
bt_conn_disconnect(conn, BT_HCI_ERR_REMOTE_USER_TERM_CONN);
char dest[150];
bt_uuid_to_str(attr->uuid, dest, sizeof(dest));
printk("Discovered attribute - uuid: %s, handle: %u\n", dest,
attr->handle);
if (err) {
printk("Failed to connect to %s (%u)\n", addr, err);
start_scan();
return;
if (conn != default_conn) {
return;
printk("Connected: %s\n", addr);
discover_params.func = discovered;
discover_params.start_handle = 0x0001;
discover_params.end_handle = 0xFFFF;
discover_params.type = BT_GATT_DISCOVER_PRIMARY;
return;
printk("Disconnected: %s (reason 0x%02x)\n", addr, reason);
start_scan();
void main(void)
int err;
err = bt_enable(NULL);
if (err) {
return;
printk("Bluetooth initialized\n");
start_scan();
Im not sure if the central-code is perfectly correct either, but I dont know where to go after doing a service discovery to get to the results i wanted as stated above. Hope any of you can help and would kindheartedly advice that one of your next zephyr/NCS-guides on this site could pertain a BLE Central guide.
Looking forward to hearing from you!
Jonas
