time out error in higher sampling rate of SAADC with soft device(sending over BLE)
Hi all,
i am getting values properly, if i set 250 samples per second. but if i set 1000 samples (1ms), i can not get values after some moments. it is showing time out error (0*08) in nrf connect application.
i am enabling one channel, taking samples in 1 milli second, making buffer of 6 samples and sending over NUS. well, this is working during 4 or above milli second sampling rate. Also, connection minimum and maximum interval have been set to 10 and 100 respectively. still, unable to fix the same.
it is highly appreciated if anyone help to figure it out the same to fix...
Here i am attaching the code snippet..
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(8, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
#define SAADC_SAMPLES_IN_BUFFER         6
#define SAADC_SAMPLE_RATE               1
    ret_code_t err_code;
    nrf_drv_timer_config_t timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG;
    timer_config.frequency = NRF_TIMER_FREQ_31250Hz;
    err_code = nrf_drv_timer_init(&m_timer, &timer_config, timer_handler);
    /* setup m_timer for compare event */
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer,SAADC_SAMPLE_RATE);
    nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
    uint32_t saadc_sample_event_addr = nrf_drv_saadc_sample_task_get();
    err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_event_addr);
        uint16_t adc_value;
        uint16_t bytes_to_send;
        uint8_t value[SAADC_SAMPLES_IN_BUFFER*2];
        // set buffers
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
        // print samples on hardware UART and parse data for BLE transmission
        //printf("ADC event number: %d\r\n",(int)m_adc_evt_counter);
        for (int i = 0; i < SAADC_SAMPLES_IN_BUFFER; i++)
            printf("E: %d\r\n", p_event->data.done.p_buffer[i]);
            adc_value = p_event->data.done.p_buffer[i];
            value[i*2] = adc_value;
            value[(i*2)+1] = adc_value >> 8;
         // Send data over BLE via NUS service. Create string from samples and send string with correct length.
        uint8_t nus_string[50];
        bytes_to_send = sprintf(nus_string,
                                "E1:%d E2:%d E3:%d E4:%d E5:%d E6:%d",
                                p_event->data.done.p_buffer[0],p_event->data.done.p_buffer[1],p_event->data.done.p_buffer[2],p_event->data.done.p_buffer[3],p_event->data.done.p_buffer[4],
                                p_event->data.done.p_buffer[5]);
        err_code = ble_nus_data_send(&m_nus, nus_string, &bytes_to_send, m_conn_handle);
        if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_NOT_FOUND))
        m_adc_evt_counter++;
void saadc_init(void)
    nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
    saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT;
    nrf_saadc_channel_config_t channel_0_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN3);
    channel_0_config.gain = NRF_SAADC_GAIN1_4;
    channel_0_config.reference = NRF_SAADC_REFERENCE_VDD4;
    err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAADC_SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAADC_SAMPLES_IN_BUFFER);
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    nrf_gpio_cfg_output(6);
    nrf_gpio_pin_set(6);
    saadc_sampling_event_init();
    saadc_init();
    // Start execution.
    advertising_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
    You will have to send more samples in each BLE transfer if you need that high sample rate. Now, the SAADC handler will be called for every 6 samples and this will be sent over BLE as a notification. Notifications are only sent on connection intervals, and the minimum configurable connection interval is 7.5 ms. With 1ms sample interval, you will fill up the notification queue and get an error. You can either increase SAADC_SAMPLES_IN_BUFFER to get less frequent interrupt from the SAADC peripheral and send all these over BLE, or pause the sampling when you get an error that the notification queue is full.
    Jørgen
