Hello all!
I have been modifying the door_lock_nus example to add the set pin command (0x05 from zcl reference). So I have modified the zigbee callback to read the new command, and I am doing it right with:
The procces is as follows:
1.- Start the coordinator and establish connection between the boards.
2.- Bind the devices and send lock/unlock commands.
3.- Try to send the set pin code command by sending: zcl cmd f4ce3693d838e02b 1 0101 -p 0104 05 0x000000001234
4.- The device enters the ZB_ZCL_CMD_DOOR_LOCK_SET_PIN_CODE case but I'm stuck in getting thee payload.
My problem is that the set pin code command has a payload and I can't figure out how to read it. Do I need to use "ZB_ZCL_GENERAL_GET_NEXT_READ_ATTR_RES"? What's the way to go?
