Is it impossible to use libuarte(UARTE1) while using NRF_LOG_INFO for debugging?
Hi!
I'm developing serial communication programming on nRF52840 DK to get the UARTE1 communication on SDK 12.0.2.
I want to use app_uart_put or NRF_LOG_INFO function via (TX_PIN_NUMBER, RX_PIN_NUMBER) with UART0 and do libuarte via (PIN(0,1), PIN(0,2)) with UARTE1.
There is no problem to make it compiled for this.
But, I got the error at initializing libuarte with :
#define NRF_LIBUARTE_ASYNC_WITH_APP_TIMER 1
#define NRF_LIBUARTE_DRV_UARTE1 1
#define NRFX_RTC_ENABLED 1
#define NRFX_RTC0_ENABLED 1
#define NRFX_RTC1_ENABLED 0
#define NRFX_RTC2_ENABLED 1
#define NRFX_TIMER_ENABLED 1
#define NRFX_TIMER0_ENABLED 1
#define NRFX_TIMER1_ENABLED 1
#define NRFX_TIMER2_ENABLED 1
#define NRFX_TIMER3_ENABLED 1
#define NRFX_TIMER4_ENABLED 0
NRF_LIBUARTE_ASYNC_DEFINE(uarte1, 1, 2, 2, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 512, 3);
      ret_code_t err_code;
        nrf_libuarte_async_config_t nrf_libuarte_async_config = {
.          tx_pin = 1,
          .rx_pin = 2,
.          baudrate = NRF_UARTE_BAUDRATE_115200,
.          parity = NRF_UARTE_PARITY_EXCLUDED,
.          hwfc = NRF_UARTE_HWFC_DISABLED,
.          timeout_us = 100,
.          int_prio = APP_IRQ_PRIORITY_LOW
err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
NRF_LOG_INFO("FATAL ERROR %d", err_code);
nrf_libuarte_async_enable(&libuarte);
I got the Fatal error. err_code is 7 which means invalid parameter like follwoing
<info> app: FATAL ERROR 7
<error> app: Fatal error
I'm wondering whether there are ways to use UARTE1 communication method with libuarte function to other peripheral device while debugging NRF_LOG_INFO with UART0 together?
  • Hi Michael,
    This is possible. I modified the example of nRF5_SDK_17.0.2_d674dde\examples\peripheral\libuarte to libuarte_uarte0log.zip.
    It uses UARTE0 as log backend and UARTE1(TX pin 27, RX pin 26) as libuarte demo. Pay attention to the following change on sdk_config.h. Those adding configurations set UARTE0 as log backend.
    // <e> UART_ENABLED - nrf_drv_uart - UART/UARTE peripheral driver - legacy layer
    #ifndef UART_ENABLED
    #define UART_ENABLED 1
    // <o> UART_DEFAULT_CONFIG_HWFC  - Hardware Flow Control
    // <0=> Disabled
    // <1=> Enabled
    #ifndef UART_DEFAULT_CONFIG_HWFC
    #define UART_DEFAULT_CONFIG_HWFC 0
    // <o> UART_DEFAULT_CONFIG_PARITY  - Parity
    // <0=> Excluded
    // <14=> Included
    #ifndef UART_DEFAULT_CONFIG_PARITY
    #define UART_DEFAULT_CONFIG_PARITY 0
    // <o> UART_DEFAULT_CONFIG_BAUDRATE  - Default Baudrate
    // <323584=> 1200 baud
    // <643072=> 2400 baud
    // <1290240=> 4800 baud
    // <2576384=> 9600 baud
    // <3862528=> 14400 baud
    // <5152768=> 19200 baud
    // <7716864=> 28800 baud
    // <10289152=> 38400 baud
    // <15400960=> 57600 baud
    // <20615168=> 76800 baud
    // <30801920=> 115200 baud
    // <61865984=> 230400 baud
    // <67108864=> 250000 baud
    // <121634816=> 460800 baud
    // <251658240=> 921600 baud
    // <268435456=> 1000000 baud
    #ifndef UART_DEFAULT_CONFIG_BAUDRATE
    #define UART_DEFAULT_CONFIG_BAUDRATE 30801920
    // <o> UART_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
    // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #ifndef UART_DEFAULT_CONFIG_IRQ_PRIORITY
    #define UART_DEFAULT_CONFIG_IRQ_PRIORITY 6
    // <q> UART_EASY_DMA_SUPPORT  - Driver supporting EasyDMA
    #ifndef UART_EASY_DMA_SUPPORT
    #define UART_EASY_DMA_SUPPORT 1
    // <q> UART_LEGACY_SUPPORT  - Driver supporting Legacy mode
    #ifndef UART_LEGACY_SUPPORT
    #define UART_LEGACY_SUPPORT 0
    // <e> UART0_ENABLED - Enable UART0 instance
    #ifndef UART0_ENABLED
    #define UART0_ENABLED 1
    // <q> UART0_CONFIG_USE_EASY_DMA  - Default setting for using EasyDMA
    #ifndef UART0_CONFIG_USE_EASY_DMA
    #define UART0_CONFIG_USE_EASY_DMA 1
    // </e>
    // <e> UART1_ENABLED - Enable UART1 instance
    #ifndef UART1_ENABLED
    #define UART1_ENABLED 0
    // </e>
    // <h> nRF_Log
    // <e> NRF_LOG_BACKEND_RTT_ENABLED - nrf_log_backend_rtt - Log RTT backend
    #ifndef NRF_LOG_BACKEND_RTT_ENABLED
    #define NRF_LOG_BACKEND_RTT_ENABLED 0
    // <o> NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE - Size of buffer for partially processed strings.
    // <i> Size of the buffer is a trade-off between RAM usage and processing.
    // <i> if buffer is smaller then strings will often be fragmented.
    // <i> It is recommended to use size which will fit typical log and only the
    // <i> longer one will be fragmented.
    #ifndef NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE
    #define NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE 64
    // <o> NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS - Period before retrying writing to RTT
    #ifndef NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS
    #define NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS 1
    // <o> NRF_LOG_BACKEND_RTT_TX_RETRY_CNT - Writing to RTT retries.
    // <i> If RTT fails to accept any new data after retries
    // <i> module assumes that host is not active and on next
    // <i> request it will perform only one write attempt.
    // <i> On successful writing, module assumes that host is active
    // <i> and scheme with retry is applied again.
    #ifndef NRF_LOG_BACKEND_RTT_TX_RETRY_CNT
    #define NRF_LOG_BACKEND_RTT_TX_RETRY_CNT 3
    // </e>
    // <e> NRF_LOG_BACKEND_UART_ENABLED - nrf_log_backend_uart - Log UART backend
    #ifndef NRF_LOG_BACKEND_UART_ENABLED
    #define NRF_LOG_BACKEND_UART_ENABLED 1
    // <o> NRF_LOG_BACKEND_UART_TX_PIN - UART TX pin
    #ifndef NRF_LOG_BACKEND_UART_TX_PIN
    #define NRF_LOG_BACKEND_UART_TX_PIN 6
    // <o> NRF_LOG_BACKEND_UART_BAUDRATE  - Default Baudrate
    #ifndef NRF_LOG_BACKEND_UART_BAUDRATE
    #define NRF_LOG_BACKEND_UART_BAUDRATE 30801920
    // <o> NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE - Size of buffer for partially processed strings.
    #ifndef NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE
    #define NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE 64
    // </e>
    Charlie
  • Sorry for my late reply.
    Let me get back to you after test with your work.
    Thank you very much for your cooperation.
