Softdevice Assert at PC=0x15810 (S132 7.2.0) / RTC clock drift when using timeslot
I'm trying to narrow down the cause of a Softdevice assertion happening in S132 7.2.0 at PC=0x15810.
We set up a proprietary RF project which utilises parts of the SDK for Mesh (specifically, the timeslot implementation and bearer_handler) because it provides a safe base to run high performance timeslot applications on. Unfortunately I do have one device which runs into a softdevice assertion at instruction 0x15810. I feel that it is a timing issue - maybe the device is operating at the outer limits of the clock accuracy, because while the issue appears sporadically on Development Kits or other devices, this specific device does trigger it quite often.
  • What exact assertion fails when at PC=0x15810?
  • Does the Softdevice shut down TIMER0 before doing this test or after an assertion fails?
  • Are timing assertions made by the softdevice based on RTC0?
  • Is there a reason why TIMER0 in the mesh stack is running in 24-bit mode as opposed to 32-bit mode?
Any help is greatly appreciated.
EDIT: In the meantime I think I found the cause of the issue. Assuming that the timing assertions by the Softdevice are done using RTC0, there seems to be a rather large discrepancy between the RTC0 timing and TIMER0 timing. After 9'999'249us on TIMER0 pass, RTC0 has counted 10'000'732us, so they're almost 1ms apart!
The device in question is running the LFCLK from the RC oscillator and we do usually have BLE deactivated. I did assume that the softdevice takes care of adjusting for clock drift, but could it be that I have to somehow take care of this manually?
EDIT2: Note that - as we're using the nRF SDK for Mesh as a codebase - when calculating the available time on the timeslot, we should already account for clock drift per the following calculation:
(p_timeslot->length_us * (m_lfclk_ppm + HFCLOCK_PPM_WORST_CASE)) / 1000000;
EDIT3: I previously wrote that we "do usually have BLE deactivated". What I actually mean by this is that most of the time the device is neither connected nor is it currently advertising. So there is no BLE activity to schedule by the softdevice. Timeslots are always active, though.
  • Hi Einar,
    I looked a bit more into the behaviour of the device when this issue occurs - and tried to implement a workaround, too.
    Tracing RTC0->EVENTS_COMPARE[1]
    I did trace RTC0->EVENTS_COMPARE[1] via PPI with a logic analyzer, because this seems to be the timing reference the softdevice uses to assert timeslots are ended in time.
    It looks like the compare event fires significantly earlier than normal when the unexpected behaviour occurs even though the timeslot was extended to the exact same duration as every other timeslot before.
    I noticed that during undisrupted/regular operation, the period of RTC0->EVENTS_COMPARE[1] is in the range of 10'000'457us to 10'000'486us, with a standard deviation of ~28us, whereas the compare-event that occurs right before the unexpeced IDLE event fires is raised after e.g. 9'999'971us, so 486us earlier than the earliest of the other compare events, which is an order of magnitude more.
    It looks like NRF_EVT_RADIO_SESSION_IDLE is then invoked within around 60us of RTC0->EVENTS_COMPARE[1], so lookis like this is triggered from the RTC0 COMPARE1 interrupt handler.
    See the following logic analyzer trace (attached as Saleae Logic 2 data file, too).
    sd-assert-rtc-debug-1.zip
    Tracing RTC0->CC[1]
    I also looked at how the RTC0->CC[1] value changes when timeslots are extended. The nRF SDK for Mesh timeslot extension algorithm initially (when invoking sd_radio_request()) tries to reserve a "short" timeslot of 14000us duration and then tries to match the previous length by extending it up to 10'000'000us (without BLE activity this will be achieved).
    I tried to see whether there were any anomalies when calculating the CC[1] value for the RTC, but did not observe any. When receiving NRF_RADIO_CALLBACK_SIGNAL_TYPE_START, the difference between NRF_RTC0->COUNTER and NRF_RTC0->CC[1] is consistently at 459, corresponding to around 14'000us. After extending to 10s (NRF_RADIO_CALLBACK_SIGNAL_TYPE_EXTEND_SUCCEED), the difference is consistently at 327681, corresponding to ~10'000'000us. This is no different for the timeslot in which the observed issue occurs.
    Looking at another logic analyzer trace where I also traced the LFCLK, (RTC0 TICK event via PPI), I came to the conclusion that the reason of the early compare event apparently seems to be RC clock drift that is larger than assumed.
    The amount of ticks counted from about the time the timeslot extension concluded up to the point the RTC0 COMPARE1 event fires was consistently higher for the period after which NRF_EVT_RADIO_SESSION_IDLE is invoked, while the measured duration was consistently significantly shorter.
    I attached the Logic trace (recorded with the below workaround active, so there are no Softdevice asserts happening...)
    sd-assert-measure-rtc-tick.zip
    Workaround
    I figured - since I can actually detect the unexpected NRF_EVT_RADIO_SESSION_IDLE, I could try a workaround where I just force stop all my timeslot activity (while disabling the MWU region that watches RADIO and TIMER0...) and re-order a new timeslot. It seems to be a viable workaround since in our application this issue seems to occur only or at least mostly while there is no BLE activity (advertising or connection) at all.
    A bug in the timeslot_timer prevented the workaround to work from the get-go, but once I figured that out, it started to look promising.
    I do not include the code here, since it's probably a bad idea to actually use it...
    The actual solution
    As it turns out, the actual solution to the problem seems to be way simpler and less hacky than my workaround. It looks like for some reason the "normal" values of NRF_SDH_CLOCK_LF_RC_CTIV (16, corresponding to 4 seconds) and NRF_SDH_CLOCK_LF_RC_TEMP_CTIV (2, corresponding to force recalibration every second interval - so I assume 8 seconds), seem to not result in an accurate enough LFCLK. I reduced NRF_SDH_CLOCK_LF_RC_CTIV to 4 (corresponding to every second) and NRF_SDH_CLOCK_LF_RC_TEMP_CTIV to 0 (corresponding to recalibration at every interval).
    So far, this has been running stable even on the "wonkier" devices. So two questions remain:
    1. How do I determine the "correct" values for NRF_SDH_CLOCK_LF_RC_CTIV and NRF_SDH_CLOCK_LF_RC_TEMP_CTIV? Why were the defaults not appropriate?
    2. Why does the softdevice not assert once it knows that timeslot is actually overstretched, but only fire the IDLE event? The COMPARE0-IRQ of RTC0 is enabled and active, after all so the possibility for the assert is there! This looks like unexpected behaviour by the softdevice.
    EDIT:
    3. How is the RC oscillator calibrated? Does this run in hardware entirely or is there code running, taking care of this? Is this running in interrupt handlers and at what priority? With As far as I understand , a temperature measurement is required if NRF_SDH_CLOCK_LF_RC_TEMP_CTIV is >= 2. Would be great if you could elaborate on this!
  • Hi Mike,
    These are very interesting findings.
    This is a good question. I have not found any reports of similar issues with the LFRC. Using regular calibration it should stay within +-500 ppm. If there is an issue here I would expect many other customers seeing a set of other issues as well (for instance missing BLE timing etc.), so it is a bit strange. We have found the default configuration, which you have described, to be good enough to not cause problems while not calibrating too often (in order to save power). I am not able to explain why this does not seem to be the case here. If it was just one device then I would suspect an issue with that specific device, but that doe snot seem to be the case her based on earlier discussions - though there are variations.
    I see your point, but that is not in line with how the timeslot API is designed. The application does not signal that the timeslot has ended (sd_radio_session_close() is only called when a session ends, i.e. when the app no longer needs timeslots), so the SoftDevice does not know that the app did not respect the time until something unexpectedly happens when it should not.
    Calibration is done in hardware. The SoftDevice simply starts the HFXO and triggers the CAL task (NRF_CLOCK_TASK_CALL) to trigger calibration and HW does the rest.
    Einar
  • Hi Einar
    So, unfortunately I'm not sure what to make of this. It looks like there is something wrong, but what?
    • Could there be an issue with the custom module or environment? I can't imagine that there are temperature variations > 0.5°C within 4s - that would really be unexpected, but I'm not too knowledgeable about hardware these days...
    • We did not observe any unexpected behaviour during BLE connections - which sometimes are established for rather long durations! In fact, it looked like the application runs more stable while BLE is active.
    • As I said, it looks like PCA20020 shows this same occasional behaviour from time to time as well!
    EDIT: I just reverted back to the recommended original LFCLK configuration and traced NRF_CLOCK->EVENTS_DONE and it does not look like any temperature drifts are detected, the calibration is done at the 8s interval throughout!
    I'm not sure I agree entirely - at least from my "black box perspective": the softdevice still signals NRF_EVT_RADIO_SESSION_IDLE at this point, so it does react somehow at the time the timeslot should have ended. So it looks like it should know that the application did not respect the time.
    But if this is normal behaviour, I think it would be great if it were somehow documented! I don't think I've seen this documented in the Softdevice specification.
    Of course the SD would assert as soon as the application accesses one of the MWU-protected peripherals or something similar.
    Sorry, I was not clear with my question. I'm aware of the NRF_CLOCK->TASK_CAL, but I was more trying to find out when and how this is triggered (through software? PPI? from what interrupt priority? Is there any difference in handling if temperature variation triggers the calibration?
    I'm just trying to figure out if there are any negative impacts if the LF-clock is calibrated more often besides power consumption. (We are not running on battery and have the RADIO receiver enabled almost all of the time - so power consumption is not an issue.)
    Sorry for the unending amount of questions, but this whole issue does bother us quite a bit, as we still lack understanding in cause and details. I'm really happy to have found the workaround with more frequent calibration, thogh, it's quite relieving to be honest, as it looks like even the most "sensitive" device we have around is now running rock-solid.
    Thank you for your patience & support. Best regards,
    -mike
  • Hi Mike,
    It seems clear that this is clock related, but not exactly how. Did you by any chance test with NRF_CLOCK_LF_SRC_SYNTH? In that case the LF clock and HF clock would use the same clock source so there will not be any drift. Perhaps it is somehow related to erratum 146 though I do not immediately see how.
    Update: There is a confirmed bug in the SoftDevice where it does not account for drift between HF clock and LF clock in the internal scheduler. I do not immediately see how it relates to this specific case as the SoftDevice only use the RTC and no timer in timeslots, so it would be up to the application to handle this drift, which it does. There may be something here, though.
    Yes, you are right. It is the applications responsibility to clean up so that it have not configured any interrupts that will happen after the end of the timeslot on the restricted peripherals (like TIMER0). I agree that is not clearly stated though.
    The decision on whether to calibrate or not depends on configuration as discussed. In the implementation a calibration timer fires regularly and the temperature is checked. If temperature has changed more than the threshold, calibration will be performed. If not a check if calibration has been skipped for too long is done, and if it is, calibration is performed. The actual calibration is done in the same way regardless of why it was triggered.
    The calibration itself consists of very little code, most importantly these steps:
    1. Request the HFXO clock
    2. Check if HW clock is running (it takes some time to start). If it is continue, if not configure an interrupt on the HFCLOCK started event so that calibration can start when clock is ready
    3. Apply first part of workaround for erratum 192.
    4. Trigger NRF_CLOCK->TASKS_CAL
    5. Wait for calibration to finish signaled by an NRF_CLOCK->EVENTS_DONE.
    6. Do last part of erratum 192 workaround
    7. release HFXO clock
    Another thing... When initializing the mesh stack with mesh_stack_init(), you pass a mesh_stack_init_params_t instance which has a member core.lfclksrc. Is this correctly configured, with the correct accuracy?
    Einar
  • Hi Einar,
    Sorry for the late response - I've been out of the office for a few days.
    I did not yet test with NRF_CLOCK_LF_SRC_SYNTH, but will do such a test now.
    Are there any downsides to using this apart from current consumption? For our setup with power supply and maximised radio uptime (i.e. HFCLK is always running), it seems like this is actually the "better" solution for this issue than using the RC oscillator.
    Considering the symptoms of the issue, I think this should resolve it from a software POV.
    Status Quo
    In the meantime, unfortunately it looked like the unwanted drift still occurs even with #define NRF_SDH_CLOCK_LF_RC_CTIV 8 and NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 0.
    The frequency of it happening is massively reduced, though. While it seemed to happen once in 10 - 15mins with NRF_SDH_CLOCK_LF_RC_CTIV 16 and NRF_SDH_
    CLOCK_LF_RC_TEMP_CTIV 2, it only happened about twice or thrice a day with the above configuration.
    The application should account for 500ppm RC clock drift, so I'm not sure this applies. Though could this drift be even larger?
    I also looked into Erratum 192, which looked like it may be interfering here, but the fact that it happens less frequently with more frequent calibration seems to contradict this...
    FYI: Since I delivered the Mesh-example I reverted back to working on our actual non-mesh application. We only use parts of the Mesh-stack, specifically the timeslot- and bearer_handler-modules and whatever is needed to support these.
    I did verify multiple times that the accuracy-parameter passed into timeslot_init() is correct (500ppm), so the drift calculation should work with the intended results.
    EDIT:
    I do have one suspicion as to the cause of the issue: Is it possible that the cause could be a mismatch of the HFXO load capacitance? It does not look right to me, but I'll have to talk to our HW engineer. We do not seem to have any issues with BLE, though.
    EDIT2:
    It does indeed seem that C_pin_HFXO and C_PCB have been neglected when calculating the required capacitance. The XTAL requires a C_L of 6pF while we currently do have a C_L in the range of 8pF to 9pF (assuming C_PCB between 0pF and 2pF).
    -mike
