Dear support,
I am developing a TDMA protocol on a custom board with the NRF52840 and SEGGER EMbedded Studio and the SDK 15.0.0. Everything went well until I wished to reduce the power consumption using nrf_pwr_mgmt_run().
Now, on the logical analyser, I observe that the MCU reboots about 2.6 ms after the radio is listening (READY event and START by shortcut).
Trying to solve the problem, I reduced my code and removed my protocol and I could reproduce the problem with the code below:
Radio initialisation (mode = proprietary 1 Mbps, same issue observed with BLE_1Mbps):
void radio_Init()
wiseradio.hfClockAlwaysOn = FALSE;
wiseradio.txStartCallback = NULL;
// Proprietary mode 1 Mbps
NRF_RADIO->MODE = (RADIO_MODE_MODE_Nrf_1Mbit << RADIO_MODE_MODE_Pos);
// Radio config
WiseRadio.radio_SetTxPower(RADIO_TXPOWER_TXPOWER_Pos4dBm);
WiseRadio.radio_SetChannel(mib.beaconChannel);
// Radio address config
NRF_RADIO->PREFIX0 =
((uint32_t)swap_bits(0xC3) << 24) // Prefix byte of address 3 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC2) << 16) // Prefix byte of address 2 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC1) << 8) // Prefix byte of address 1 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC0) << 0); // Prefix byte of address 0 converted to nRF24L series format
NRF_RADIO->PREFIX1 =
((uint32_t)swap_bits(0xC7) << 24) // Prefix byte of address 7 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC6) << 16) // Prefix byte of address 6 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC4) << 0); // Prefix byte of address 4 converted to nRF24L series format
NRF_RADIO->BASE0 = bytewise_bitswap(0x01234567UL); // Base address for prefix 0 converted to nRF24L series format
NRF_RADIO->BASE1 = bytewise_bitswap(0x89ABCDEFUL); // Base address for prefix 1-7 converted to nRF24L series format
NRF_RADIO->TXADDRESS = 0x00UL; // Set device address 0 to use when transmitting
NRF_RADIO->RXADDRESSES = 0x01UL; // Enable device address 0 to use to select which addresses to receive
// Packet configuration
NRF_RADIO->PCNF0 = (PACKET_S1_FIELD_SIZE << RADIO_PCNF0_S1LEN_Pos) |
(PACKET_S0_FIELD_SIZE << RADIO_PCNF0_S0LEN_Pos) |
(PACKET_LENGTH_FIELD_SIZE << RADIO_PCNF0_LFLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
NRF_RADIO->PCNF1 = (RADIO_PCNF1_WHITEEN_Disabled << RADIO_PCNF1_WHITEEN_Pos) |
(RADIO_PCNF1_ENDIAN_Big << RADIO_PCNF1_ENDIAN_Pos) |
(PACKET_BASE_ADDRESS_LENGTH << RADIO_PCNF1_BALEN_Pos) |
(PACKET_STATIC_LENGTH << RADIO_PCNF1_STATLEN_Pos) |
(PACKET_PAYLOAD_MAXSIZE << RADIO_PCNF1_MAXLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
// CRC Config
NRF_RADIO->CRCCNF = (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos); // Number of checksum bits
if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos))
NRF_RADIO->CRCINIT = 0xFFFFUL; // Initial value
NRF_RADIO->CRCPOLY = 0x11021UL; // CRC poly: x^16 + x^12^x^5 + 1
else if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_One << RADIO_CRCCNF_LEN_Pos))
NRF_RADIO->CRCINIT = 0xFFUL; // Initial value
NRF_RADIO->CRCPOLY = 0x107UL; // CRC poly: x^8 + x^2^x^1 + 1
WiseRadio.radio_Off();
Turn off radio = turn off HFCLK clock as the radio is disabled by END -> DISABLE shortcut: In this case hfClockAlwaysOn is FALSE.
void radio_Off(void)
DBG_DISPLAY_VAL8(0xA8);
NRF_RADIO->EVENTS_DISABLED = 0;
NRF_RADIO->TASKS_DISABLE = 1;
//while (NRF_RADIO->EVENTS_DISABLED == 0){} //Wait while radio is ramping down.
if (wiseradio.hfClockAlwaysOn == FALSE) {
stop_NrfHFClock();
wiseradio.state = WISERADIO_IDLE;
The test program initialises the board and starts a timer which turns the radio on, set it in listening mode and when something is received, the radio is turned off and a new timer starts the same process again.
Turn on radio:
void radio_On (void)
// Because we are using the shortcuts between READY and START, here radio_On basically means
// starting the HF clock, which takes about 350 us. The delay on waiting for this operation
// should be set to 400 us to be on the safe side.
Start listening:
void radio_ReceiveFrame(uint8_t *buf, uint8_t maxlen, uint8_t * lenPtr, uint8_t *rssiPtr, t_timTime *timePtr,
void (*funStart)(void *), void (*funEnd)(void *))
DBG_DISPLAY_VAL8(0xC6);
wiseradio.rxBufLen = maxlen;
wiseradio.rxCallback = funEnd;
wiseradio.startCallback = funStart;
wiseradio.rxLenPtr = lenPtr;
*wiseradio.rxLenPtr = 0;
wiseradio.rssiPtr = rssiPtr;
*wiseradio.rssiPtr= 0;
wiseradio.timePtr = timePtr;
wiseradio.rxBufPtr = buf;
wiseradio.rxBufferAvailable = 1;
(((uint32_t) maxlen) << RADIO_PCNF1_MAXLEN_Pos);
NRF_RADIO->PACKETPTR = (uint32_t)buf;
NRF_RADIO->SHORTS = (RADIO_SHORTS_READY_START_Enabled << RADIO_SHORTS_READY_START_Pos) |
(RADIO_SHORTS_END_DISABLE_Enabled << RADIO_SHORTS_END_DISABLE_Pos);
wiseradio.state = WISERADIO_RX_WAIT_SYNC;
NRF_RADIO->EVENTS_END = 0;
NRF_RADIO->EVENTS_READY = 0;
NRF_RADIO->EVENTS_ADDRESS = 0;
NRF_RADIO->EVENTS_PAYLOAD = 0;
NRF_RADIO->TASKS_RXEN = 1;
Finally, the main program:
appl_Init(); // init system such as timer
wisenode_SetUpGPIOs(); // simply configure some GPIOs
//wisenode_SetupI2C();
DBG_DISPLAY_VAL8(0x89);
DBG_TRIGGER(6);
// This function starts a time with startRxTest as call back. It uses app_timer_create() and app_timer_start()
tim_TimerStartFast(TIM_TIMER_MAC1, TIM_ONE_SHOT, 100000, startRxTest, NULL, FALSE); // timeout in microseconds, thus here 100ms
LED1_OFF();
LED2_OFF();
LED3_OFF();
nrf_pwr_mgmt_init();
while (TRUE) {
nrf_pwr_mgmt_run();
void startRxTest(void* arg)
WiseRadio.radio_On();
// RADIO_OFF_TO_HFCLK_ON_DELAY_US = 400 us. Increasing this value doesn't help.
tim_TimerStartFast(TIM_TIMER_MAC1, TIM_ONE_SHOT, RADIO_OFF_TO_HFCLK_ON_DELAY_US, rxTest, NULL, FALSE);
void rxTest(void* arg)
DBG_TRIGGER(4);
MyBuffer = buff_RxGetNew();
WiseRadio.radio_ReceiveFrame((uint8_t*) dataBuf[MyBuffer].buffer, BUFF_MAX_SIZE-1, (uint8_t*) &(dataBuf[MyBuffer].len),
(uint8_t*) &(dataBuf[MyBuffer].rxRssi), (t_timTime*) &(dataBuf[MyBuffer].receivedTime),
rxTestStart, rxTestEnd);
// This routine below is called when the radio triggers the END event.
void rxTestEnd(void* arg)
uint8_t i;
uint8_t len;
uint8_t status;
DBG_TRIGGER(3);
DBG_DISPLAY_VAL8(0xBF);
status = WiseRadio.radio_ReturnState();
DBG_DISPLAY_VAL8(status);
len = dataBuf[MyBuffer].len;
/*DBG_DISPLAY_VAL8(len);
DBG_DISPLAY_VAL8(dataBuf[MyBuffer].buffer[0]);
if (status == WISERADIO_RX_COMPLETE) {
for (i = 1; i <= len; i++) {
DBG_DISPLAY_VAL8(dataBuf[MyBuffer].buffer[i]);
tim_TimerStartFast(TIM_TIMER_MAC1, TIM_ONE_SHOT, 10000, startRxTest, NULL, FALSE);
buff_Release(MyBuffer, 0xE1);
When the program is executed, the MCU crashes (= reboots) about 2.6 ms after the radio event READY is thrown shortly after rxTest() is executed. If nrf_pwr_mgmt_run(); is commented out in the main loop, the same problem appears. However, if some instruction that turns on and off a GPIO is added instead of nrf_pwr_mgmt_run();, then there is no reboot.
I have spent lots of time trying to understand this issue without succes, thus any help would be greatly appreciated. Thanks and best regards,
Damien
