hi ,
I am working on the nrf525832 , i want to store the data which is sent from phone via BLE using nrf toolbox . I tried to merge the flashwrite and ble_app_uart example . while executing the program i am getting the nrf_breakpoint_error
please correct my code if anything wrong
* Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_uart_over_ble_main main.c
* @ingroup ble_sdk_app_nus_eval
* @brief UART over BLE application main file.
* This file contains the source code for a sample application that uses the Nordic UART service.
* This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_calendar.h"
#include "nrf_nvmc.h"
#include "nrf_cli.h"
#include "nrf_cli_uart.h"
#define FLASHWRITE_EXAMPLE_MAX_STRING_LEN (62u)
#define FLASHWRITE_EXAMPLE_BLOCK_VALID (0xA55A5AA5)
#define FLASHWRITE_EXAMPLE_BLOCK_INVALID (0xA55A0000)
#define FLASHWRITE_EXAMPLE_BLOCK_NOT_INIT (0xFFFFFFFF)
NRF_CLI_UART_DEF(m_cli_uart_transport, 0, 64, 16);
NRF_CLI_DEF(m_cli_uart, "uart_cli:~$ ", &m_cli_uart_transport.transport, '\r', 4);
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "Nordic_UART" /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_evt Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
uint32_t err_code;
for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
do
// err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
} while (err_code == NRF_ERROR_BUSY);
if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
uint32_t err_code;
ble_nus_init_t nus_init;
// Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
NRF_LOG_INFO("Disconnected");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
// Pairing not supported
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// No implementation needed.
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
ret_code_t err_code;
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
static uint8_t index = 0;
uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
// UNUSED_VARIABLE(app_uart_get(&data_array[index]));
index++;
if ((data_array[index - 1] == '\n') ||
(data_array[index - 1] == '\r') ||
(index >= m_ble_nus_max_data_len))
if (index > 1)
do
} while (err_code == NRF_ERROR_RESOURCES);
index = 0;
case APP_UART_FIFO_ERROR:
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
uint32_t err_code;
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
uint32_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
typedef struct
uint32_t magic_number;
uint32_t buffer[FLASHWRITE_EXAMPLE_MAX_STRING_LEN + 1]; // + 1 for end of string
} flashwrite_example_flash_data_t;
typedef struct
uint32_t addr;
uint32_t pg_size;
uint32_t pg_num;
flashwrite_example_flash_data_t * m_p_flash_data;
} flashwrite_example_data_t;
static flashwrite_example_data_t m_data;
static ret_code_t clock_config(void)
err_code = nrf_drv_clock_init();
if (err_code != NRF_SUCCESS && err_code != NRF_ERROR_MODULE_ALREADY_INITIALIZED)
return err_code;
return NRF_SUCCESS;
static void flash_page_init(void)
m_data.pg_num = NRF_FICR->CODESIZE - 1;
m_data.pg_size = NRF_FICR->CODEPAGESIZE;
m_data.addr = (m_data.pg_num * m_data.pg_size);
m_data.m_p_flash_data = (flashwrite_example_flash_data_t *)m_data.addr;
while (1)
if (m_data.m_p_flash_data->magic_number == FLASHWRITE_EXAMPLE_BLOCK_VALID)
return;
if (m_data.m_p_flash_data->magic_number == FLASHWRITE_EXAMPLE_BLOCK_INVALID)
++m_data.m_p_flash_data;
continue;
nrf_nvmc_page_erase(m_data.addr);
return;
static void flash_string_write(uint32_t address, const char * src, uint32_t num_words)
uint32_t i;
// Enable write.
NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen;
while (NRF_NVMC->READY == NVMC_READY_READY_Busy)
for (i = 0; i < num_words; i++)
/* Only full 32-bit words can be written to Flash. */
((uint32_t*)address)[i] = 0x000000FFUL & (uint32_t)((uint8_t)src[i]);
NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren;
static void flashwrite_erase_cmd(nrf_cli_t const * p_cli, size_t argc, char **argv)
static void flashwrite_read_cmd(nrf_cli_t const * p_cli, size_t argc, char **argv)
flashwrite_example_flash_data_t * p_data = (flashwrite_example_flash_data_t *)m_data.addr;
char string_buff[FLASHWRITE_EXAMPLE_MAX_STRING_LEN + 1]; // + 1 for end of string
if ((p_data == m_data.m_p_flash_data) &&
(p_data->magic_number != FLASHWRITE_EXAMPLE_BLOCK_VALID))
nrf_cli_fprintf(p_cli, NRF_CLI_WARNING, "Please write something first.\r\n");
return;
while (p_data <= m_data.m_p_flash_data)
if ((p_data->magic_number != FLASHWRITE_EXAMPLE_BLOCK_VALID) &&
(p_data->magic_number != FLASHWRITE_EXAMPLE_BLOCK_INVALID))
nrf_cli_fprintf(p_cli, NRF_CLI_WARNING, "Corrupted data found.\r\n");
return;
uint8_t i;
for (i = 0 ; i <= FLASHWRITE_EXAMPLE_MAX_STRING_LEN; i++)
string_buff[i] = (char)p_data->buffer[i];
nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "%s\r\n", string_buff);
++p_data;
// device_name[10]=string_buff;
// nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "%s\r\n", device_name);
static void flashwrite_write_cmd(nrf_cli_t const * p_cli, size_t argc, char **argv)
static uint16_t const page_size = 4096;
if (argc < 2)
nrf_cli_fprintf(p_cli, NRF_CLI_ERROR, "%s:%s", argv[0], " bad parameter count\r\n");
return;
if (argc > 2)
NRF_CLI_WARNING,
"%s:%s",
argv[0],
" bad parameter count - please use quotes\r\n");
return;
uint32_t len = strlen(argv[1]);
if (len > FLASHWRITE_EXAMPLE_MAX_STRING_LEN)
NRF_CLI_ERROR,
"Too long string. Please limit entered string to %d chars.\r\n",
FLASHWRITE_EXAMPLE_MAX_STRING_LEN);
return;
if ((m_data.m_p_flash_data->magic_number != FLASHWRITE_EXAMPLE_BLOCK_NOT_INIT) &&
(m_data.m_p_flash_data->magic_number != FLASHWRITE_EXAMPLE_BLOCK_VALID))
nrf_cli_fprintf(p_cli, NRF_CLI_ERROR, "Flash corrupted, please errase it first.");
return;
uint32_t new_end_addr = (uint32_t)(m_data.m_p_flash_data + 2);
uint32_t diff = new_end_addr - m_data.addr;
if (diff > page_size)
NRF_CLI_WARNING,
"Not enough space - please erase flash first.\r\n");
return;
nrf_nvmc_write_word((uint32_t)&m_data.m_p_flash_data->magic_number,
FLASHWRITE_EXAMPLE_BLOCK_INVALID);
//++len -> store also end of string '\0'
flash_string_write((uint32_t)m_data.m_p_flash_data->buffer, argv[1], ++len);
FLASHWRITE_EXAMPLE_BLOCK_VALID);
static void flashwrite_cmd(nrf_cli_t const * p_cli, size_t argc, char **argv)
ASSERT(p_cli);
ASSERT(p_cli->p_ctx && p_cli->p_iface && p_cli->p_name);
if ((argc == 1) || nrf_cli_help_requested(p_cli))
nrf_cli_help_print(p_cli, NULL, 0);
return;
nrf_cli_fprintf(p_cli, NRF_CLI_ERROR, "%s:%s%s\r\n", argv[0], " unknown parameter: ", argv[1]);
/**@brief Application main function.
bool erase_bonds;
// Initialize.
uart_init();
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
flash_page_init();
// Start execution.
advertising_start();
//flash_page_init();
nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
ret_code_t err_code = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
err_code = nrf_cli_start(&m_cli_uart);
NRF_LOG_RAW_INFO("Flashwrite example started.\r\n");
NRF_LOG_RAW_INFO("Execute: <flash -h> for more information "
"or press the Tab button to see all available commands.\r\n");
// Enter main loop.
for (;;)
idle_state_handle();
