working with 2 saadc configurations does not work
hello Nordic
i am working with nrf52840, sdk 16.0
i am building my project over the peripheral app_ble_blinky example
i whish to have 2 seprate configs for saadc
i call the following init function twice (with 2 different saadc_configs (different naming as well) ):
err_code = nrf_drv_saadc_init(&saadc_config, saadc_sample_event_handler);
it does not seem to be working.. is there a way to initialize 2 saadc configs
best regards
Ziv
  • hello again Slight smile
    must say your site is running quite low speed today and i have to rewrite all this message again because it didn't load ):
    i have 2 modules, in each module's init function i configure the saadc.
    the first run fine the second give error 17, BUSY when i try to init the channel , i read in the forum that this type of error might have something to do with conversion of the buffers, don't realy understand why it matters in my case since i am using different buffers for each module's saadc. here is the codes:
    //  //Initialize SAADC
    //    err_code = nrf_drv_saadc_init(&hydr_saadc_config, hydr_saadc_callback);
    //    APP_ERROR_CHECK(err_code);
      //Initialize SAADC channel
        err_code = nrf_drv_saadc_channel_init(3, &hydr_channel_config);
        err_code = nrf_drv_saadc_buffer_convert(hydr_buffer_pool[0], HYDR_NUMBER_OF_ADC_SAMPLES);
        err_code = nrf_drv_saadc_buffer_convert(hydr_buffer_pool[1], HYDR_NUMBER_OF_ADC_SAMPLES);
    //    err_code = nrf_drv_saadc_init(&audio_saadc_config, audio_saadc_callback);
        audio_channel_config.pin_p = AUDIO_PIEZO_ADC_INPUT_PIN;
        err_code = nrf_drv_saadc_channel_init(0, &audio_channel_config);
        audio_channel_config.pin_p = AUDIO_MIC_ADC_INPUT_PIN;
        err_code = nrf_drv_saadc_channel_init(1, &audio_channel_config);
        audio_channel_config.pin_p = AUDIO_PIEZO_ADC_INPUT_PREAMPLYFIER_INPUT_PIN;
        err_code = nrf_drv_saadc_channel_init(2, &audio_channel_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], CONVERTED_ADC_SAMPELS_BUFF_SIZE);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], CONVERTED_ADC_SAMPELS_BUFF_SIZE);
    what will be the right way to handle this error ?
    what i have done that solved it (though i am not sure its the best way) is to take the buffer conversions and put it after i call the nrf_drv_saadc_init() each time i call it and after i finish with this module i call the saadc uninit function
    another question is that i see i start getting saadc sampling events right after calling the init even if i don't use the nrf_drv_saadc_sample()
    which is not good for me cause i want the sampling to start at a certain point and i want to have just one oversampled sample, what do i need to change ?
    my saadc init look like this now :
    err_code = nrf_drv_saadc_init(&hydr_saadc_config, hydr_saadc_callback);// TBD - need to make sure, maybe global volatile flag that
        // the other modul did not initialize the saadc WITHOUT UNINITIALIZING IT
    and my callback:
    static void hydr_saadc_callback(nrf_drv_saadc_evt_t const * p_event)
            ret_code_t err_code;
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, HYDR_NUMBER_OF_ADC_SAMPLES);
            hydration_sample_buff[count_of_10_min_sample_events] /*hydr_val*/ = p_event->data.done.p_buffer[0];// + p_event->data.done.p_buffer[1] + p_event->data.done.p_buffer[2] + p_event->data.done.p_buffer[3])/4;
            measurments_state = MEASURE_STATE_DONE;
            nrf_drv_saadc_uninit();
    [later today i edit] - apperntly i was working at release mode while debugging, returning to debug mode created some assertion issues.. in specific i don't get this assertion:
      // Oversampling can be used only with one channel.
        NRFX_ASSERT((nrf_saadc_oversample_get() != NRF_SAADC_OVERSAMPLE_DISABLED) ||
                    (m_cb.active_channels == 0));
    it says oversampling can be only when working with one channel but if over sampling is disabled and i have more then one channel it asserts .. so what should i do???, also this assertions comply me to init the saadc before the channels initiation and change the way i thought of working before .. don't know the all over consequences of this debug vs release head hack
    hope to read you soon and hope this reply will be uploaded properly so i will not have to re-write it again ):
    best regards
    Ziv
    It may be easier to just have only one buffer at any time, so:
    1. First init by saadc_init()
    2. Prepare buffer by nrf_drv_saadc_buffer_convert()
    3. Then at some time in future execute sample by nrf_drv_saadc_sample()
    4.
    Wait for NRF_DRV_SAADC_EVT_DONE event and handle saadc data
    5. Prepare buffer by nrf_drv_saadc_buffer_convert()
    Repeat from 3.
    If you want to change saadc configuration, then uninit saadc and re-init saadc again, but make sure you clear potential adc channels that may have been used earlier. Also make sure you don't do this between step 3 and 4 above.
    If you do any calibration of the saadc this should be done between 4 and 5 due to an errata, or between step 1 and 2.
    You are right that oversampling can only be done if 1 channel is configured, this is a hardware limitation, so don't have any good workaround here; you could just sample the channels faster and discard those measurement that you don't want.
    Kenneth
  • Hi Kenneth
    sorry to say but this is not very clear and does not seem to help
    my main hold back at the moment is that moving from debugging in release mode back to debug mode bring up all sort of assertions, one of them which currently holds me back is this one:
    after we can figure out why this is happening and how to fix it i will continue with other issues
    basically just to remind, i use 2 saadc instances at different times in the program, each has its own definitions and its own channels (with different numbers for each channels - there is no overlapping there)
    i init each of the saadc and its channels and then its buffers every time i wish to sample them and then uninit the saadc and reinit the other saadc and its channels and convert the buffers (each saadc has its own buffers)
    hope you can help me and that my problem is better understood now
    best regards
    Ziv
  • I can't see from your code where you are calling nrf_drv_saadc_channel_uninit() for previous configured channels?
    In hardware there is only one SAADC instance, so you will need to manually disable all ADC channels that is no longer in use. I do not think the uninit function of the driver does this for you.
    Edit: Looking at nrfx_saadc_uninit() I can see this is done. Will need to look at this closer then.
    Edit2:It doesn't make any sense that this should assert:
    Both these are cleared during nrf_drv_saadc_init()->nrfx_saadc_init() by:
    nrf_saadc_oversample_set(p_config->oversample);
    m_cb.active_channels      = 0;
    Are you 100% sure that p_config->oversample is false when calling nrfx_saadc_init()?
    Kenneth
