working with 2 saadc configurations does not work
hello Nordic
i am working with nrf52840, sdk 16.0
i am building my project over the peripheral app_ble_blinky example
i whish to have 2 seprate configs for saadc
i call the following init function twice (with 2 different saadc_configs (different naming as well) ):
err_code = nrf_drv_saadc_init(&saadc_config, saadc_sample_event_handler);
it does not seem to be working.. is there a way to initialize 2 saadc configs
best regards
Ziv
  • Are you 100% sure that p_config->oversample is false when calling nrfx_saadc_init()?
    this assertion does not happen in the saadc init function, it happens when i try to init the second channel
    1. i init saadc_1
    2. int saadc_1 channels
    3. convert buffers
    4. sample
    5. un-init saadc
    6. init saadc_2
    7. init saadc_2 channels -> here first channel init goes fine, in the second channel init i get the assertion
  • I understand that the assertion does not occur in saadc init function, however the values that is checked in NRFX_ASSERT() when channel init, is set during saadc init.
    Hope that make sense,
    Kenneth
  • yes the oversampling is something related to saadc init but as can be seen in my configurations:
      //Configure SAADC
        audio_saadc_config.resolution = NRF_SAADC_RESOLUTION_14BIT;       //Set SAADC resolution to 12-bit. This will make the SAADC output values from 0 (when input voltage is 0V) to 2^12=2048 (when input voltage is 3.6V for channel gain setting of 1/6).
        audio_saadc_config.oversample = NRF_SAADC_OVERSAMPLE_DISABLED;    //DIABLED - //Set oversample to 4x. This will make the SAADC output a single averaged value when the SAMPLE task is triggered 4 times.
        audio_saadc_config.interrupt_priority = APP_IRQ_PRIORITY_LOW;     //Set SAADC interrupt to low priority.
        audio_saadc_config.low_power_mode = NRFX_SAADC_CONFIG_LP_MODE;
    the oversampling is disabled
    still i get this assertion.. does it has anything to to with the previous configuration  ?
    if not then any idea for solving the problem ?
    i will also add, maybe it matters, this 2 variables that one of them goes in the saadc init are global variables in each of the modules using the saadc
    static nrf_drv_saadc_config_t audio_saadc_config;
    static nrf_saadc_channel_config_t audio_channel_config;
    static nrf_drv_saadc_config_t hydr_saadc_config;
    static nrf_saadc_channel_config_t hydr_channel_config;
    best regards
    Ziv
    Are you able to find which of the two are causing the assert in the first place?
    NRFX_ASSERT(nrf_saadc_oversample_get() != NRF_SAADC_OVERSAMPLE_DISABLED);
    NRFX_ASSERT(m_cb.active_channels == 0);
    Are you able to make a simple example where you switch between the two that I can run on an nRF52840-DK?
    Kenneth
  • hi
    in debug i can see the following:
    nrf_saadc_oversample_get() = NRF_SAADC_OVERSAMPLE_DISABLED
    m_cb.active_channels = 1
    i can't understand the logic in that assertion .. it is saying the "Oversampling can be used only with one channel" but when over sampling is disabled it fails to, so what's the point ????
    i am not sure what you meant but i can't bring my self to write a code for testing on your side, i am on tight schedule and i am late cause of this unclear bug that i am trying to explain for so long.
    here is all relevant saadc code in the order it is called:
    global vars:
    static nrf_saadc_value_t     m_buffer_pool[2][CONVERTED_ADC_SAMPELS_BUFF_SIZE];
    static nrf_saadc_value_t     hydr_buffer_pool[HYDR_NUMBER_OF_ADC_SAMPLES];
    relevant defins:
    #define ADC_PIEZO_CHANNEL     0
    #define ADC_MIC_CHANNEL       1
    #define ADC_AMPLIFIER_CHANNEL 2
    #define ADC_HYDRATION_CHANNEL 3
    init calls:
    Audio_sens_init();
    Physical_measures_init();
    the init themselvs:
    void Audio_sens_init(void)
        ret_code_t err_code;
    //    nrf_gpio_cfg_output(ARDUINO_13_PIN); // FOR DEBUG
        //Configure SAADC
        //Configure SAADC channels:
        audio_channel_config.reference = NRF_SAADC_REFERENCE_VDD4;          //Set internal reference of fixed 0.6 volts
        audio_channel_config.gain = NRF_SAADC_GAIN1_4;                      //Set input gain to 1/6. The maximum SAADC input voltage is then 0.6V/(1/6)=3.6V. The single ended input range is then 0V-3.6V
        audio_channel_config.acq_time = NRF_SAADC_ACQTIME_10US;             //Set acquisition time. Set low acquisition time to enable maximum sampling frequency of 200kHz. Set high acquisition time to allow maximum source resistance up to 800 kohm, see the SAADC electrical specification in the PS.
        audio_channel_config.mode = NRF_SAADC_MODE_SINGLE_ENDED;            //Set SAADC as single ended. This means it will only have the positive pin as input, and the negative pin is shorted to ground (0V) internally.
        audio_channel_config.pin_n = NRF_SAADC_INPUT_DISABLED;              //Since the SAADC is single ended, the negative pin is disabled. The negative pin is shorted to ground internally.
        audio_channel_config.resistor_p = NRF_SAADC_RESISTOR_DISABLED;      //Disable pullup resistor on the input pin
        audio_channel_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED;
        audio_channel_config.burst = NRF_SAADC_BURST_DISABLED;
     ....(not relevant to saadc)
    // samling event configurations - ppi timer event to start saadc sampling:
        err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_task_addr);
    void Physical_measures_init(void)
        // init saadc read:
      //Configure SAADC
        hydr_saadc_config.resolution         = NRF_SAADC_RESOLUTION_14BIT;   //Set SAADC resolution to 12-bit. This will make the SAADC output values from 0 (when input voltage is 0V) to 2^12=2048 (when input voltage is 3.6V for channel gain setting of 1/6).
        hydr_saadc_config.oversample         = NRF_SAADC_OVERSAMPLE_4X;      //Set oversample to 4x. This will make the SAADC output a single averaged value when the SAMPLE task is triggered 4 times.
        hydr_saadc_config.interrupt_priority = APP_IRQ_PRIORITY_LOW;         //Set SAADC interrupt to low priority.
        hydr_saadc_config.low_power_mode     = NRFX_SAADC_CONFIG_LP_MODE;
        hydr_channel_config.reference = NRF_SAADC_REFERENCE_VDD4;          //Set internal reference of fixed 0.6 volts
        hydr_channel_config.gain = NRF_SAADC_GAIN1_4;                      //Set input gain to 1/6. The maximum SAADC input voltage is then 0.6V/(1/6)=3.6V. The single ended input range is then 0V-3.6V
        hydr_channel_config.acq_time = NRF_SAADC_ACQTIME_10US;             //Set acquisition time. Set low acquisition time to enable maximum sampling frequency of 200kHz. Set high acquisition time to allow maximum source resistance up to 800 kohm, see the SAADC electrical specification in the PS.
        hydr_channel_config.mode = NRF_SAADC_MODE_SINGLE_ENDED;            //Set SAADC as single ended. This means it will only have the positive pin as input, and the negative pin is shorted to ground (0V) internally.
        hydr_channel_config.pin_p = HYDRATION_ADC_INPUT_PIN;               // adc input pin
        hydr_channel_config.pin_n = NRF_SAADC_INPUT_DISABLED;              //Since the SAADC is single ended, the negative pin is disabled. The negative pin is shorted to ground internally.
        hydr_channel_config.resistor_p = NRF_SAADC_RESISTOR_DISABLED;      //Disable pullup resistor on the input pin
        hydr_channel_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED;
        hydr_channel_config.burst = NRF_SAADC_BURST_ENABLED;
    saadc init calls in main loop (after initialization):
    //Initialize SAADC
        err_code = nrf_drv_saadc_init(&hydr_saadc_config, hydr_saadc_callback);
      //Initialize SAADC channel
        err_code = nrf_drv_saadc_channel_init(ADC_HYDRATION_CHANNEL, &hydr_channel_config);
        err_code = nrf_drv_saadc_buffer_convert(hydr_buffer_pool, HYDR_NUMBER_OF_ADC_SAMPLES);
        err_code = nrf_drv_saadc_sample();  // i want sampling to start only when i use saadc sample
    static void hydr_saadc_callback(nrf_drv_saadc_evt_t const * p_event)
         //   err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, HYDR_NUMBER_OF_ADC_SAMPLES);
          //  APP_ERROR_CHECK(err_code);
            hydration_sample_buff[count_of_10_min_sample_events] /*hydr_val*/ = p_event->data.done.p_buffer[0];// + p_event->data.done.p_buffer[1] + p_event->data.done.p_buffer[2] + p_event->data.done.p_buffer[3])/4;
            measurments_state = MEASURE_STATE_DONE;
            nrf_drv_saadc_uninit();
    //Initialize second SAADC
        err_code = nrf_drv_saadc_init(&audio_saadc_config, audio_saadc_callback);
        audio_channel_config.pin_p = AUDIO_PIEZO_ADC_INPUT_PIN;
        err_code = nrf_drv_saadc_channel_init(ADC_PIEZO_CHANNEL, &audio_channel_config);
        audio_channel_config.pin_p = AUDIO_MIC_ADC_INPUT_PIN;
        err_code = nrf_drv_saadc_channel_init(ADC_MIC_CHANNEL, &audio_channel_config);
    HERE IS WERE THE ASSERTION HAPPENS !!! IN THE CHANNEL INIT FOR ADC_MIC_CHANNEL
        audio_channel_config.pin_p = AUDIO_PIEZO_ADC_INPUT_PREAMPLYFIER_INPUT_PIN;
        err_code = nrf_drv_saadc_channel_init(ADC_AMPLIFIER_CHANNEL, &audio_channel_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], CONVERTED_ADC_SAMPELS_BUFF_SIZE);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], CONVERTED_ADC_SAMPELS_BUFF_SIZE);
    hope you can help me to solve this issue
    best regards
    Ziv
