Merge Eddystone beacon and DFU buttonless application
I am trying to add the beacon Eddystone features to my DFU buttonless application.
After compiling the code, I wrote the softdevice, the bootloader and the application in my nRF52832 custom board. However, the application doesn't advertise the Eddystone packets.... :(
Here is my main.c:
 * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @example examples/ble_peripheral/ble_app_buttonless_dfu
 * @brief Secure DFU Buttonless Service Application main file.
 * This file contains the source code for a sample application using the proprietary
 * Secure DFU Buttonless Service. This is a template application that can be modified
 * to your needs. To extend the functionality of this application, please find
 * locations where the comment "// YOUR_JOB:" is present and read the comments.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nrf_dfu_ble_svci_bond_sharing.h"
#include "nrf_svci_async_function.h"
#include "nrf_svci_async_handler.h"
#include "app_error.h"
#include "app_timer.h"
#include "ble.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_conn_state.h"
#include "ble_dfu.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "bsp_btn_ble.h"
#include "fds.h"
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_bootloader_info.h"
#include "nrf_drv_clock.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_power.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "es_app_config.h"
#include "app_scheduler.h"
#include "nrf_ble_es.h"
#define DEVICE_NAME "TW_DFU_ES"               /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL \
    300 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
// #define APP_ADV_DURATION                18000                                       /**< The advertising duration
// (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1  /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL        \
    MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.1 seconds). \
#define MAX_CONN_INTERVAL        \
    MSEC_TO_UNITS(200, UNIT_1_25_MS)                     /**< Maximum acceptable connection interval (0.2 second). \
#define SLAVE_LATENCY 0                                  /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY        \
    APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time \
                             sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY \
    APP_TIMER_TICKS(                  \
        30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT                                                 \
    3 /**< Number of attempts before giving up the connection parameter negotiation. \
#define SEC_PARAM_BOND 1                               /**< Perform bonding. */
#define SEC_PARAM_MITM 0                               /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0                               /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0                                /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16                      /**< Maximum encryption key size. */
#define NON_CONNECTABLE_ADV_INTERVAL        \
    MSEC_TO_UNITS(100, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This \
                                         value can vary between 100ms to 10.24s). */
#define APP_BEACON_INFO_LENGTH 0x17 /**< Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH 0x15    /**< Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE 0x02        /**< 0x02 refers to Beacon. */
#define APP_MEASURED_RSSI 0xC3      /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
#define APP_COMPANY_IDENTIFIER        \
    0x0059                         /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. \
#define APP_MAJOR_VALUE 0x01, 0x02 /**< Major value used to identify Beacons. */
#define APP_MINOR_VALUE 0x03, 0x04 /**< Minor value used to identify Beacons. */
#define APP_BEACON_UUID        \
    0x01, 0x12, 0x23, 0x34, 0x45, 0x56, 0x67, 0x78, 0x89, 0x9a, 0xab, 0xbc, 0xcd, 0xde, 0xef, \
        0xf0 /**< Proprietary UUID for Beacon. */
#define APP_ADV_DURATION BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED
#define MAX_LEN_DEVICE_NAME 12
#define DEAD_BEEF \
    0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
static ble_gap_adv_params_t m_adv_params; /**< Parameters to be passed to the stack when starting advertising. */
static uint8_t m_adv_handle =
    BLE_GAP_ADV_SET_HANDLE_NOT_SET;                          /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */
NRF_BLE_GATT_DEF(m_gatt);           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static void advertising_start(bool erase_bonds);         /**< Forward declaration of advertising start function */
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data = {.adv_data = {.p_data = m_enc_advdata, .len = BLE_GAP_ADV_SET_DATA_SIZE_MAX},
    .scan_rsp_data = {.p_data = NULL, .len = 0
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] = /**< Information advertised by the Beacon. */
        APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                             // implementation.
        APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                             // manufacturer specific data in this implementation.
        APP_BEACON_UUID,     // 128 bit UUID value.
        APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
        APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
        APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                             // this implementation.
// YOUR_JOB: Use UUIDs for service(s) used in your application.
// original: BLE_UUID_DEVICE_INFORMATION_SERVICE, fw minew: 0xFFF1
static ble_uuid_t m_adv_uuids[] = {{0xFFF1, BLE_UUID_TYPE_BLE}};
/**@brief Handler for shutdown preparation.
 * @details During shutdown procedures, this function will be called at a 1 second interval
 *          untill the function returns true. When the function returns true, it means that the
 *          app is ready to reset to DFU mode.
 * @param[in]   event   Power manager event.
 * @retval  True if shutdown is allowed by this power manager handler, otherwise false.
static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
    case NRF_PWR_MGMT_EVT_PREPARE_DFU:
        NRF_LOG_INFO("Power management wants to reset to DFU mode.");
        // YOUR_JOB: Get ready to reset into DFU mode
        // If you aren't finished with any ongoing tasks, return "false" to
        // signal to the system that reset is impossible at this stage.
        // Here is an example using a variable to delay resetting the device.
        // if (!m_ready_for_reset)
        //      return false;
        // else
        //    // Device ready to enter
        //    uint32_t err_code;
        //    err_code = sd_softdevice_disable();
        //    APP_ERROR_CHECK(err_code);
        //    err_code = app_timer_stop_all();
        // YOUR_JOB: Implement any of the other events available from the power management module:
        //      -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF
        //      -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
        //      -NRF_PWR_MGMT_EVT_PREPARE_RESET
        return true;
    NRF_LOG_INFO("Power management allowed to reset to DFU mode.");
    return true;
// lint -esym(528, m_app_shutdown_handler)
/**@brief Register application shutdown handler with priority 0.
NRF_PWR_MGMT_HANDLER_REGISTER(app_shutdown_handler, 0);
static void buttonless_dfu_sdh_state_observer(nrf_sdh_state_evt_t state, void *p_context)
    if (state == NRF_SDH_EVT_STATE_DISABLED)
        // Softdevice was disabled before going into reset. Inform bootloader to skip CRC on next boot.
        nrf_power_gpregret2_set(BOOTLOADER_DFU_SKIP_CRC);
        // Go to system off.
        nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
/* nrf_sdh state observer. */
NRF_SDH_STATE_OBSERVER(m_buttonless_dfu_state_obs, 0) = {
    .handler = buttonless_dfu_sdh_state_observer,
static void advertising_config_get(ble_adv_modes_config_t *p_config)
    memset(p_config, 0, sizeof(ble_adv_modes_config_t));
    p_config->ble_adv_fast_enabled = true;
    p_config->ble_adv_fast_interval = APP_ADV_INTERVAL;
    // p_config->ble_adv_fast_timeout  = APP_ADV_DURATION;
static void disconnect(uint16_t conn_handle, void *p_context)
    UNUSED_PARAMETER(p_context);
    ret_code_t err_code = sd_ble_gap_disconnect(conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    if (err_code != NRF_SUCCESS)
        NRF_LOG_WARNING("Failed to disconnect connection. Connection handle: %d Error: %d", conn_handle, err_code);
        NRF_LOG_DEBUG("Disconnected connection handle %d", conn_handle);
// YOUR_JOB: Update this code if you want to do anything given a DFU event (optional).
/**@brief Function for handling dfu events from the Buttonless Secure DFU service
 * @param[in]   event   Event from the Buttonless Secure DFU service.
static void ble_dfu_evt_handler(ble_dfu_buttonless_evt_type_t event)
    switch (event)
    case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
        NRF_LOG_INFO("Device is preparing to enter bootloader mode.");
        // Prevent device from advertising on disconnect.
        ble_adv_modes_config_t config;
        advertising_config_get(&config);
        config.ble_adv_on_disconnect_disabled = true;
        ble_advertising_modes_config_set(&m_advertising, &config);
        // Disconnect all other bonded devices that currently are connected.
        // This is required to receive a service changed indication
        // on bootup after a successful (or aborted) Device Firmware Update.
        uint32_t conn_count = ble_conn_state_for_each_connected(disconnect, NULL);
        NRF_LOG_INFO("Disconnected %d links.", conn_count);
    case BLE_DFU_EVT_BOOTLOADER_ENTER:
        // YOUR_JOB: Write app-specific unwritten data to FLASH, control finalization of this
        //           by delaying reset by reporting false in app_shutdown_handler
        NRF_LOG_INFO("Device will enter bootloader mode.");
    case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
        NRF_LOG_ERROR("Request to enter bootloader mode failed asynchroneously.");
        // YOUR_JOB: Take corrective measures to resolve the issue
        //           like calling APP_ERROR_CHECK to reset the device.
    case BLE_DFU_EVT_RESPONSE_SEND_ERROR:
        NRF_LOG_ERROR("Request to send a response to client failed.");
        APP_ERROR_CHECK(false);
        NRF_LOG_ERROR("Unknown event from ble_dfu_buttonless.");
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
void assert_nrf_callback(uint16_t line_num, const uint8_t *p_file_name)
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const *p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    uint32_t err_code = app_timer_init();
    // Create timers.
    /* YOUR_JOB: Create any timers to be used by the application.
               Below is an example of how to create a timer.
               For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
               one.
     uint32_t err_code;
     err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
     APP_ERROR_CHECK(err_code); */
static void set_bd_addr(void)
    ret_code_t ret_code;
    ble_gap_addr_t gap_addr;
    gap_addr.addr_id_peer = 0;
    gap_addr.addr_type = BLE_GAP_ADDR_TYPE_PUBLIC;
    // Get BD address from UICR memory
    uint8_t *ptr = (uint8_t *)&NRF_UICR->CUSTOMER[2];
    // Check if not written
    uint8_t empty_addr[MAX_LEN_DEVICE_NAME];
    memset(empty_addr, 0xff, BLE_GAP_ADDR_LEN);
    if (!memcmp(ptr, empty_addr, BLE_GAP_ADDR_LEN))
        NRF_LOG_WARNING("No BD address in flash, using chip default");
        ret_code = sd_ble_gap_addr_get(&gap_addr);
        APP_ERROR_CHECK(ret_code);
        NRF_LOG_HEXDUMP_INFO(&gap_addr.addr, 6);
        memcpy(&gap_addr.addr, ptr, BLE_GAP_ADDR_LEN);
        NRF_LOG_INFO("GAP Address");
    NRF_LOG_INFO("Setting bd address to: %02X:%02X:%02X:%02X:%02X:%02X",
        gap_addr.addr[5],
        gap_addr.addr[4],
        gap_addr.addr[3],
        gap_addr.addr[2],
        gap_addr.addr[1],
        gap_addr.addr[0]);
    // fim teste
    ret_code = sd_ble_gap_addr_set(&gap_addr);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    uint32_t err_code;
    ble_gap_conn_params_t gap_conn_params;
    err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME));
    /* YOUR_JOB: Use an appearance value matching the application's use case.
     err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
    gap_conn_params.slave_latency = SLAVE_LATENCY;
    gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
    set_bd_addr();
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the YYY Service events.
 * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
 * @details This function will be called for all YY Service events which are passed to
 *          the application.
 * @param[in]   p_yy_service   YY Service structure.
 * @param[in]   p_evt          Event received from the YY Service.
   static void on_yys_evt(ble_yy_service_t     * p_yy_service,
                          ble_yy_service_evt_t * p_evt)
    switch (p_evt->evt_type)
        case BLE_YY_NAME_EVT_WRITE:
            APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
            // No implementation needed.
    uint32_t err_code;
    ble_dfu_buttonless_init_t dfus_init = {0};
    dfus_init.evt_handler = ble_dfu_evt_handler;
    err_code = ble_dfu_buttonless_init(&dfus_init);
    /* YOUR_JOB: Add code to initialize the services used by the application.
     uint32_t                           err_code;
     ble_xxs_init_t                     xxs_init;
     ble_yys_init_t                     yys_init;
     // Initialize XXX Service.
     memset(&xxs_init, 0, sizeof(xxs_init));
     xxs_init.evt_handler                = NULL;
     xxs_init.is_xxx_notify_supported    = true;
     xxs_init.ble_xx_initial_value.level = 100;
     err_code = ble_bas_init(&m_xxs, &xxs_init);
     // Initialize YYY Service.
     memset(&yys_init, 0, sizeof(yys_init));
     yys_init.evt_handler                  = on_yys_evt;
     yys_init.ble_yy_initial_value.counter = 0;
     err_code = ble_yy_service_init(&yys_init, &yy_init);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
static void on_conn_params_evt(ble_conn_params_evt_t *p_evt)
    uint32_t err_code;
/**@brief Function for handling a Connection Parameters error.
    uint32_t err_code;
    cp_init.p_conn_params = NULL;
    cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
    cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
    cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
    cp_init.disconnect_on_fail = false;
    cp_init.evt_handler = on_conn_params_evt;
    cp_init.error_handler = conn_params_error_handler;
/**@brief Function for starting timers.
static void application_timers_start(void)
    /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
     uint32_t err_code;
     err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
    // Prepare wakeup buttons.
    // Disable SoftDevice. It is required to be able to write to GPREGRET2 register (SoftDevice API blocks it).
    // GPREGRET2 register holds the information about skipping CRC check on next boot.
    err_code = nrf_sdh_disable_request();
    uint32_t err_code;
    switch (ble_adv_evt)
    case BLE_ADV_EVT_FAST:
    case BLE_ADV_EVT_IDLE:
        sleep_mode_enter();
static void ble_evt_handler(ble_evt_t const *p_ble_evt, void *p_context)
    uint32_t err_code = NRF_SUCCESS;
    case BLE_GAP_EVT_CONNECTED:
        ble_gap_phys_t const phys = {
            .rx_phys = BLE_GAP_PHY_AUTO,
            .tx_phys = BLE_GAP_PHY_AUTO,
    case BLE_GATTC_EVT_TIMEOUT:
        err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    case BLE_GATTS_EVT_TIMEOUT:
        err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            // Pairing not supported
            err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.common_evt.conn_handle,
                                                   BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                   NULL,
                                                   NULL);
            err_code = sd_ble_gatts_sys_attr_set(p_ble_evt->evt.common_evt.conn_handle, NULL, 0, 0);
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // do Eddystone
    err_code = nrf_sdh_ble_app_ram_start_get(&ram_start);
    // Overwrite some of the default configurations for the BLE stack.
    ble_cfg_t ble_cfg;
    // Configure the maximum number of connections.
    memset(&ble_cfg, 0, sizeof(ble_cfg));
    ble_cfg.gap_cfg.role_count_cfg.periph_role_count  = 1;
#if !defined (S112)
    ble_cfg.gap_cfg.role_count_cfg.central_role_count = 0;
    ble_cfg.gap_cfg.role_count_cfg.central_sec_count  = 0;
#endif // !defined (S112)
    err_code = sd_ble_cfg_set(BLE_GAP_CFG_ROLE_COUNT, &ble_cfg, ram_start);
    // Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init()
    err_code = pm_init();
    sec_param.bond = SEC_PARAM_BOND;
    sec_param.mitm = SEC_PARAM_MITM;
    sec_param.lesc = SEC_PARAM_LESC;
    sec_param.keypress = SEC_PARAM_KEYPRESS;
    sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob = SEC_PARAM_OOB;
    sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc = 1;
    sec_param.kdist_own.id = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id = 1;
/** @brief Clear bonding information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
 * @param[in]   event   Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
    uint32_t err_code;
    switch (event)
    case BSP_EVENT_SLEEP:
        sleep_mode_enter();
        break; // BSP_EVENT_SLEEP
    case BSP_EVENT_DISCONNECT:
        err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        break; // BSP_EVENT_DISCONNECT
    case BSP_EVENT_WHITELIST_OFF:
        break; // BSP_EVENT_KEY_0
    case BSP_EVENT_KEY_0:
	bsp_board_led_invert(1);
        return; // no implementation needed
    uint32_t err_code;
    ble_advertising_init_t init;
    ble_advdata_manuf_data_t manuf_specific_data;
    manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
    // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
    // UICR instead of using the default values. The major and minor values obtained from the UICR
    // are encoded into advertising data in big endian order (MSB First).
    // To set the UICR used by this example to a desired value, write to the address 0x10001080
    // using the nrfjprog tool. The command to be used is as follows.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
    // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
    // the following command should be used.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
    uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
    uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
    uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
    m_beacon_info[index++] = MSB_16(major_value);
    m_beacon_info[index++] = LSB_16(major_value);
    m_beacon_info[index++] = MSB_16(minor_value);
    m_beacon_info[index++] = LSB_16(minor_value);
    manuf_specific_data.data.p_data = (uint8_t *)m_beacon_info;
    manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;
    //init.advdata.name_type = BLE_ADVDATA_NO_NAME;
    init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
    // init.advdata.include_appearance      = true;
    init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    // init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    // init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    init.advdata.p_manuf_specific_data = &manuf_specific_data;
    advertising_config_get(&init.config);
    // para fazer o advertise em apenas um canal
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
    m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
    m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.duration = 0; // Never time out.
    m_adv_params.channel_mask[4] = 0x60;
  adv_params.channel_mask[4] = 0x80; // Dont advertise on ch 39
  adv_params.channel_mask[4] = 0x40; // Dont advertise on ch 38
  adv_params.channel_mask[4] = 0x20; // Dont advertise on ch 37
  adv_params.channel_mask[4] = 0xA0; // Dont advertise on ch 39 and 37
  adv_params.channel_mask[4] = 0xC0; // Dont advertise on ch 38 and 39
  adv_params.channel_mask[4] = 0x60; // Dont advertise on ch 37 and 38
static void buttons_leds_init(bool *p_erase_bonds)
    uint32_t err_code;
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
// do Eddystone
    const uint8_t           buttons_cnt  = 1;
    static app_button_cfg_t buttons_cfgs =
        .pin_no         = BUTTON_REGISTRATION,
        .active_state   = APP_BUTTON_ACTIVE_LOW,
        .pull_cfg       = NRF_GPIO_PIN_PULLUP,
        .button_handler = button_evt_handler
    err_code = app_button_init(&buttons_cfgs, buttons_cnt, APP_TIMER_TICKS(100));
    err_code = app_button_enable();
/**@brief Function for the Power manager.
static void log_init(void)
    uint32_t err_code = NRF_LOG_INIT(NULL);
static void scheduler_init(void)
    APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
/**@brief   Function for initializing the GATT module.
 * @details The GATT module handles ATT_MTU and Data Length update procedures automatically.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        NRF_LOG_DEBUG("advertising is started");
    uint32_t err_code = nrf_pwr_mgmt_init();
	app_sched_execute();
        nrf_pwr_mgmt_run();
/**@brief Function for handling Eddystone events.
 * @param[in] evt Eddystone event to handle.
static void on_es_evt(nrf_ble_es_evt_t evt)
    switch (evt)
        case NRF_BLE_ES_EVT_ADVERTISEMENT_SENT:
            bsp_board_led_invert(NON_CONNECTABLE_ADV_LED_PIN);
        case NRF_BLE_ES_EVT_CONNECTABLE_ADV_STARTED:
            bsp_board_led_on(CONNECTABLE_ADV_LED_PIN);
        case NRF_BLE_ES_EVT_CONNECTABLE_ADV_STOPPED:
            bsp_board_led_off(CONNECTABLE_ADV_LED_PIN);
/**@brief Function for application main entry.
    bool erase_bonds;
    log_init();
    // Initialize the async SVCI interface to bootloader before any interrupts are enabled.
    err_code = ble_dfu_buttonless_async_svci_init();
    timers_init();
    power_management_init();
    scheduler_init();
    ble_stack_init();
    peer_manager_init();
    gap_params_init();
    gatt_init();
    static ble_gap_addr_t m_central_addr;
    set_bd_addr();
    advertising_init();
    services_init();
    conn_params_init();
    nrf_ble_es_init(on_es_evt);
    NRF_LOG_INFO("Buttonless DFU Application started.");
    // Start execution.
    application_timers_start();
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
I have no idea about the problem... Please, help.
Gabriel
