Firmware not starting after DFU
Hello, I have the following question. I'm trying to program my firmware via DFU Bootloader and nRF Connect (smartphone). That works perfectly with the test board SparkFun nRF52832 Breakout. But if I do the same with my own hardware, the firmware won't start. The upload goes perfectly, but DFU will start again in two seconds. If the firmware is flashed without a DFU, it works without a problem. It looks like the problem is with the hardware. But I compared everything and found no mistake. What could be causing the error in the hardware that does not allow the flashed firmware to start?
SDK_17.0.0_9d13099, nRF52832
Schematic board SparkFun
Thanks in advance
  • Hi Edvin,
    On the SparkFun hardware, did you program the bootloader yourself, or was it pre-programmed?
    I programmed both hardware (SparkFun and my own hardware) with SES. First Target -> Erase All and then Target -> Download secure_bootloader_ble_s132_pca10040.
    How did you program the bootloader and application on your custom hardware? Did you generate and program the bootloader settings?
    I did not generate bootloader settings. Probably here is my mistake?
    If you compiled the bootloader yourself, did you do any changes to the bootloader project? If so, which ones?
    I only removed LED functions (bsp_board_led_on(BSP_BOARD_LED_0)…) and #include "boards.h" from example nRF5_SDK_17.0.0_9d13099 \ examples \ dfu \ secure_bootloader \ pca10040_s132_ble.
    Do you see the bootloader advertisements? have you tried to update the firmware via DFU? If so, how did you generate the DFU image?
    Yes, I see DFU advertisements in nRF Connect Android app. I can also flash FW. I generated the FW image with nrfutill. The image is successfully flashed via Android app and works with SparkFun hardware. The image is flashed in the same way with own hardware but does not start. The RTT log says that app is invalid: <debug> app: DFU mode because app is not valid.
    Maybe it is missing bootloader settings in own hardware?
    Thanks
  • Hello Edvin,
    I believe i have found possible cause. The SparkFun hardware has nRF52832-QFAA 64kB. In my own hardware I have nRF52832-QFAB 32kB. I only now understood that I ordered the wrong nRF. I have read out memories from both nRFs with nRF Connect (please see screenshot). With nRF AB (32 kB) bootloader is not displayed, why? Although DFU works and the screenshots are already with the app that I flashed via DFU (please see address 0x00026000 - 0x0002C52B). App is only 25,900 bytes and should also work with nRF AB. The app does not start with nRF52832-QFAB 32kB. What do I have to adjust in order to start the app with nRF AB (32 kB)?
  • I see.
    Did it not throw any errors when you programmed the bootloader? If not, what happens if you try to read out e.g. the flash address:
    "nrfjprog --memrd 0x00078000 --n 1024"
    What is the bootloader's flash start address?
    Basically what you need to do is to change the flash addresses. If your application uses FDS (Used if you use the peer manager or any other parts that uses FDS), then make sure that it fetches the correct address.
    Depening on what IDE you are using, it is probably possible to change the compiler to set the QFAB instead of QFAA as the target.
    Edvin
  • Hi Edvin,
    No, there were no errors
    QFAA and QFAB memories are absolutely the same:
    C:\Program Files (x86)\Nordic Semiconductor\nrf-command-line-tools\bin>nrfjprog --memrd 0x00078000 --n 1024
    0x00078000: 20010000 0007835D 00078345 00078347   |... ]...E...G...|
    0x00078010: 00078349 0007834B 0007834D 00000000   |I...K...M.......|
    0x00078020: 00000000 00000000 00000000 0007D0C1   |................|
    0x00078030: 00078351 00000000 00078353 00078355   |Q.......S...U...|
    0x00078040: 00078357 00078357 00078357 00078357   |W...W...W...W...|
    0x00078050: 00078357 00078357 00078357 00078357   |W...W...W...W...|
    0x00078060: 00078357 00078357 00078357 00078357   |W...W...W...W...|
    0x00078070: 00078357 00078357 00078357 00078357   |W...W...W...W...|
    0x00078080: 0007B3AD 00078357 00078357 00078357   |....W...W...W...|
    0x00078090: 00078357 00078357 0007D2C9 00078357   |W...W.......W...|
    0x000780A0: 00078357 00078357 00078357 00078357   |W...W...W...W...|
    0x000780B0: 00078357 00078357 00000000 00000000   |W...W...........|
    0x000780C0: 00078357 00078357 00078357 00078357   |W...W...W...W...|
    0x000780D0: 0007B061 00078357 00078357 00000000   |a...W...W.......|
    0x000780E0: 00000000 00000000 00000000 00000000   |................|
    0x000780F0: 00000000 00000000 00000000 00000000   |................|
    0x00078100: 00000000 00000000 00000000 00000000   |................|
    0x00078110: 00000000 00000000 00000000 00000000   |................|
    0x00078120: 00000000 00000000 00000000 00000000   |................|
    0x00078130: 00000000 00000000 00000000 00000000   |................|
    0x00078140: 00000000 00000000 00000000 00000000   |................|
    0x00078150: 00000000 00000000 00000000 00000000   |................|
    0x00078160: 00000000 00000000 00000000 00000000   |................|
    0x00078170: 00000000 00000000 00000000 00000000   |................|
    0x00078180: 00000000 00000000 00000000 00000000   |................|
    0x00078190: 00000000 00000000 00000000 00000000   |................|
    0x000781A0: 00000000 00000000 00000000 00000000   |................|
    0x000781B0: 00000000 00000000 00000000 00000000   |................|
    0x000781C0: 00000000 00000000 00000000 00000000   |................|
    0x000781D0: 00000000 00000000 00000000 00000000   |................|
    0x000781E0: 00000000 00000000 00000000 00000000   |................|
    0x000781F0: 00000000 00000000 00000000 00000000   |................|
    0x00078200: 48324931 D0021A0A 43912207 4930468D   |1I2H.....".C.F0I|
    0x00078210: 1A0A4830 2207D006 F3814391 22028809   |0H.....".C....."|
    0x00078220: 8814F382 492D482C F0004A2D 482DF83C   |....,H-I-J..<.-H|
    0x00078230: 4A2E492D F837F000 492E482D F0004A2E   |-I.J..7.-H.I.J..|
    0x00078240: 482EF832 4A2F492E F82DF000 492F482E   |2..H.I/J..-..H/I|
    0x00078250: F0004A2F 482FF828 4A30492F F823F000   |/J..(./H/I0J..#.|
    0x00078260: 4930482F F0004A30 4830F81E 22004930   |/H0I0J....0H0I."|
    0x00078270: F824F000 4930482F F0002200 4A2FF81F   |..$./H0I."..../J|
    0x00078280: 481F4790 4288491F 6802D005 B4033004   |.G.H.I.B...h.0..|
    0x00078290: BC034790 2000E7F7 46EC4686 21002000   |.G..... .F.F. .!|
    0x000782A0: 47904A27 4288E7FE 1A52D007 7803D005   |'J.G...B..R....x|
    0x000782B0: 700B3001 3A013101 4770D1F9 D0024288   |.0.p.1.:..pG.B..|
    0x000782C0: 30017002 4770E7FA 20010000 2000F800   |.p.0..pG... ... |
    0x000782D0: 20010000 20010000 0007DB40 2000597C   |... ... @...|Y. |
    0x000782E0: 200059B4 000783B8 000783B8 0007D5FE   |.Y. ............|
    0x000782F0: 0007DB40 2000597C 2000597C 0007D66C   |@...|Y. |Y. l...|
    0x00078300: 0007D66C 0007D66C 0007D66C 0007D66C   |l...l...l...l...|
    0x00078310: 0007D66C 0007D66C 0007D66C 0007DB40   |l...l...l...@...|
    0x00078320: 0007DB78 200059B4 200059B4 200059B4   |x....Y. .Y. .Y. |
    0x00078330: 20007F64 20007F64 20007F64 00078385   |d.. d.. d.. ....|
    0x00078340: 00079C71 E7FEE7FE E7FEE7FE E7FEE7FE   |q...............|
    0x00078350: E7FEE7FE E7FEE7FE B802F000 BFFCF7FF   |................|
    0x00078360: F04F480F 43880107 480E4685 480E4780   |.HO....C.F.H.G.H|
    0x00078370: F4416801 60010170 8F4FF3BF 8F6FF3BF   |.hA.p..`..O...o.|
    0x00078380: BF3EF7FF 490A4809 42884A0A 1A52D007   |..>..H.I.J.B..R.|
    0x00078390: 7803D005 700B3001 3A013101 4770D1F9   |...x.0.p.1.:..pG|
    0x000783A0: 20010000 0007B489 E000ED88 0007D658   |... ........X...|
    0x000783B0: 20005968 2000597C B5301C4B 460400DB   |hY. |Y. K.0....F|
    0x000783C0: 0003F012 D10DB29B 602A4D07 4B07441A   |.........M*`.D.K|
    0x000783D0: 4B07601A 4B077018 4B077018 4B07801C   |.`.K.p.K.p.K...K|
    0x000783E0: BD308019 E7FC2007 200059BC 200059B8   |..0.. ...Y. .Y. |
    0x000783F0: 200059B4 200059C4 200059C0 200059C2   |.Y. .Y. .Y. .Y. |
    In QFAA 0x00078000. How can I determine that in QFAB?
    In SES I have "flash_placement.xml" and settings in Project -> Options -> Linker -> Memory Segments and Section Placement Macros. Do I have to adjust both? Can you tell me which parameters do I need to change?
    Memory Segments
    FLASH RX 0x0 0x80000;RAM RWX 0x20000000 0x10000;mbr_params_page RX 0x0007E000 0x1000;bootloader_settings_page RX 0x0007F000 0x1000;uicr_bootloader_start_address RX 0x10001014 0x4;uicr_mbr_params_page RX 0x10001018 0x4
    FLASH_PH_START=0x0
    FLASH_PH_SIZE=0x80000
    RAM_PH_START=0x20000000
    RAM_PH_SIZE=0x10000
    FLASH_START=0x78000
    FLASH_SIZE=0x6000
    RAM_START=0x20005968
    RAM_SIZE=0xa698
    Unfortunately I did not find this in SES.
    Many thanks for the help!
  • So the main difference between the QFAA and QFAB is that:
    the QFAA has 512kB of flash and 64kB of RAM, while
    the QFAB has 256kB of flash and 32kB of RAM.
    Some of the QFAB chips actually has more than 256kB of flash, but the flash above the 256kB address is not tested during production, and therefore it is likely that it doesn't work as intended (normally non functional flash blocks will be replaced). This is a bit tricky in SES, but you are on the track of it.
    Settings in SES:
    These are for the QFAA:
    FLASH_PH_START=0x0
    RAM_PH_SIZE=0x10000
    FLASH_START=0x78000
    FLASH_SIZE=0x6000
    RAM_SIZE=0xa698
    If you want to run it on the QFAB, you need to change it to:
    FLASH_PH_START=0x0
    FLASH_PH_SIZE=0x40000
    RAM_PH_SIZE=0x8000
    FLASH_START=0x38000
    FLASH_SIZE=0x6000
    RAM_SIZE=0x2698
    To match the QFAB's flash and RAM.
    In addition, you should change the QFAA's:
    FLASH RX 0x0 0x80000;RAM1 RWX 0x20000000 0x10000;mbr_params_page RX 0x0007E000 0x1000;bootloader_settings_page RX 0x0007F000 0x1000;uicr_bootloader_start_address RX 0x10001014 0x4;uicr_mbr_params_page RX 0x10001018 0x4
    To:
    FLASH RX 0x0 0x40000;RAM1 RWX 0x20000000 0x8000;mbr_params_page RX 0x0003E000 0x1000;bootloader_settings_page RX 0x0003F000 0x1000;uicr_bootloader_start_address RX 0x10001014 0x4;uicr_mbr_params_page RX 0x10001018 0x4
    You should also look into your preprocessor definitions:
    You should change it to NRF52832_XXAB, but before you do, search up this definition in your projects (bootloader and application) and make sure that the equivalent of NRF52832_XXAA is implemented for NRF52832_XXAB. If it is not, please implement it. (I don't think all the implementations are included in the latest SDKs).
    Remember to set "Common" in the drop down menu before you change your settings in Segger Embedded Studio, as seen below the top red arrow in the above screenshot.
    Edvin
