nrf9160-DK SPI from BME280 sensor config issue
I am on nrfConnect v3.6 trying to build an SPI test using the command line (west)
I get this error:
error: SPI_3_NRF_SPIM (defined at drivers/spi/Kconfig.nrfx:133) is assigned in a configuration file,
but is not directly user-configurable (has no prompt). It gets its value indirectly from other
symbols. See docs.zephyrproject.org/.../CONFIG_SPI_3_NRF_SPIM.html
and/or look up SPI_3_NRF_SPIM in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
might be helpful too.
CMake Error at ~/Nordic/nrfsrc/ncs/zephyr/cmake/kconfig.cmake:239
My prj.conf:
CONFIG_SPI=y
CONFIG_SPI_3=y
CONFIG_SPI_3_NRF_SPIM=y
CONFIG_SPI_3=y
CONFIG_SPI_NRFX=y
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_SENSOR=y
My Kconfig:
# Copyright (c) 2020, Nordic Semiconductor ASA
config LOG
default y
config LOG_PRINTK
default y
config SENSOR_LOG_LEVEL
default 4
# Workaround for not being able to have commas in macro arguments
DT_COMPAT_BOSCH_BME280 := bosch,bme280
# Enable SPI support by default if there are any BME280 sensors
# on a SPI bus.
config SPI
default $(dt_compat_on_bus,$(DT_COMPAT_BOSCH_BME280),spi)
# Enable I2C support by default if there are any BME280 sensors
# on an I2C bus.
config I2C
default $(dt_compat_on_bus,$(DT_COMPAT_BOSCH_BME280),i2c)
source "Kconfig.zephyr"
My nrf9160dk_nrf9160ns.overlays
&spi3 {
status = "ok";
sck-pin = <10>;
mosi-pin = <11>;
miso-pin = <12>;
#ss-pin = <13>;
#spi-max-frequency = <4000000>;
&uart3 {
status = "disabled";
Sadly, the references in the error message have not helped me much.
Any suggestions pls.
