We base on the light switch example to include the dfu process into it.
Device FW information is as follows:
Mesh sdk: v4.2.0
SoftDevice: s113_nrf52_7.0.1_softdevice.hex
bootloader: mesh_bootloader_gccarmemb_nrf52832_xxAA.hex
device page: device_page_nrf52832_xxAA_s113_7.0.1.hex
Testing environment:
1. PC <-UART-> 52832 DK
Build a DFU-sender program with c code (just like the nrfutil works) in PC to send the bin and dat data to 52832DK.
The 52832DK with pre-compile bootloader,soft device, application FW and device page can be dfu updated successfully via UART.
0> <t: 4266661>, serial_bearer.c, 394, frank: C8 0> <t: 4266667>, serial_bearer.c, 394, frank: A 0> <t: 4266673>, serial_bearer.c, 394, frank: 40 0> <t: 4266680>, serial_bearer.c, 394, frank: D 0> <t: 4266682>, serial_bearer.c, 212, ----frank--- end_reception 0> <t: 4266684>, serial_bearer.c, 141, ----frank--- serial_process 0> <t: 4266688>, nrf_mesh_dfu.c, 502, DFU segment rx: 9623/9623 0> <t: 4266693>, nrf_mesh_dfu.c, 656, TIMER set: 30000000us delay (@1696209137) 0> <t: 4266697>, nrf_mesh_dfu.c, 581, RADIO TX! SLOT 1, count 3, interval: exponential, handle: FFFC 0> <t: 5249733>, nrf_mesh_dfu.c, 351, Timeout fired @1696209137 0> <t: 5264814>, nrf_mesh_dfu.c, 367, Write complete (0x2000FD38) 0> <t: 5264818>, nrf_mesh_dfu.c, 376, Flash idle. 0> <t: 5264891>, nrf_mesh_dfu.c, 372, Erase complete (0x7E000) 0> <t: 5264899>, nrf_mesh_dfu.c, 367, Write complete (0x7F000) 0> <t: 5265033>, nrf_mesh_dfu.c, 367, Write complete (0x7F004) 0> <t: 5265041>, nrf_mesh_dfu.c, 367, Write complete (0x7F048) 0> <t: 5265044>, nrf_mesh_dfu.c, 367, Write complete (0x7F054) 0> <t: 5265048>, nrf_mesh_dfu.c, 367, Write complete (0x7F060) 0> <t: 5265051>, nrf_mesh_dfu.c, 367, Write complete (0x7F06C) 0> <t: 5265054>, nrf_mesh_dfu.c, 367, Write complete (0x7F080) 0> <t: 5265057>, nrf_mesh_dfu.c, 367, Write complete (0x7F088) 0> <t: 5265060>, nrf_mesh_dfu.c, 367, Write complete (0x7F0E0) 0> <t: 5265132>, nrf_mesh_dfu.c, 372, Erase complete (0x7F000) 0> <t: 5265140>, nrf_mesh_dfu.c, 367, Write complete (0x7E000) 0> <t: 5265275>, nrf_mesh_dfu.c, 367, Write complete (0x7E004) 0> <t: 5265283>, nrf_mesh_dfu.c, 367, Write complete (0x7E048) 0> <t: 5265286>, nrf_mesh_dfu.c, 367, Write complete (0x7E054) 0> <t: 5265289>, nrf_mesh_dfu.c, 367, Write complete (0x7E060) 0> <t: 5265292>, nrf_mesh_dfu.c, 367, Write complete (0x7E06C) 0> <t: 5265295>, nrf_mesh_dfu.c, 367, Write complete (0x7E080) 0> <t: 5265298>, nrf_mesh_dfu.c, 367, Write complete (0x7E088) 0> <t: 5265301>, nrf_mesh_dfu.c, 367, Write complete (0x7E0E0) 0> <t: 5265304>, nrf_mesh_dfu.c, 376, Flash idle. 0> <t: 5265306>, nrf_mesh_dfu.c, 520, DFU END! 0> <t: 5265310>, dfu_init.c, 152, ----- NRF_MESH_EVT_DFU_END... 0> <t: 5265314>, nrf_mesh_dfu.c, 527, DFU BANK AVAILABLE 0> <t: 5265317>, dfu_init.c, 159, ----- NRF_MESH_EVT_DFU_BANK_AVAILABLE... 0> <t: 5265374>, nrf_mesh_dfu.c, 367, Write complete (0x2000FD38) 0> <t: 5265378>, nrf_mesh_dfu.c, 376, Flash idle.
2.other MCU <-UART-> 52832 module
Build a DFU-sender program with c code (just like the nrfutil works) in "other MCU" to send the bin and dat data to 52832 module.
The 52832 module with the same FW as above (pre-compile bootloader,soft device, application FW and device page) can get the bin+data data successfully with no errors (correct event,op-code and status) from "other MCU" via UART. But it shows "the Abort event. Reason: 0x4".
0> <t: 3850853>, serial_bearer.c, 388, frank: A3 0> <t: 3850859>, serial_bearer.c, 388, frank: 7E 0> <t: 3850862>, nrf_mesh_dfu.c, 502, DFU segment rx: 9622/9623 0> <t: 3850867>, nrf_mesh_dfu.c, 581, RADIO TX! SLOT 1, count 3, interval: exponential, handle: FFFC 0> <t: 3854159>, serial_bearer.c, 388, frank: 19 0> <t: 3854164>, serial_bearer.c, 388, frank: 78 0> <t: 3854170>, serial_bearer.c, 388, frank: FC 0> <t: 3854176>, serial_bearer.c, 388, frank: FF 0> <t: 3854181>, serial_bearer.c, 388, frank: 97 0> <t: 3854187>, serial_bearer.c, 388, frank: 25 0> <t: 3854193>, serial_bearer.c, 388, frank: 1 0> <t: 3854198>, serial_bearer.c, 388, frank: 0 0> <t: 3854204>, serial_bearer.c, 388, frank: 0 0> <t: 3854210>, serial_bearer.c, 388, frank: 0 0> <t: 3854216>, serial_bearer.c, 388, frank: 5A 0> <t: 3854221>, serial_bearer.c, 388, frank: 14 0> <t: 3854227>, serial_bearer.c, 388, frank: 81 0> <t: 3854233>, serial_bearer.c, 388, frank: BD 0> <t: 3854238>, serial_bearer.c, 388, frank: 15 0> <t: 3854244>, serial_bearer.c, 388, frank: 8D 0> <t: 3854250>, serial_bearer.c, 388, frank: 59 0> <t: 3854256>, serial_bearer.c, 388, frank: 8D 0> <t: 3854262>, serial_bearer.c, 388, frank: D2 0> <t: 3854267>, serial_bearer.c, 388, frank: D1 0> <t: 3854273>, serial_bearer.c, 388, frank: A4 0> <t: 3854279>, serial_bearer.c, 388, frank: 6F 0> <t: 3854284>, serial_bearer.c, 388, frank: C8 0> <t: 3854290>, serial_bearer.c, 388, frank: A 0> <t: 3854296>, serial_bearer.c, 388, frank: 40 0> <t: 3854301>, serial_bearer.c, 388, frank: D 0> <t: 3854305>, nrf_mesh_dfu.c, 502, DFU segment rx: 9623/9623 0> <t: 3854310>, nrf_mesh_dfu.c, 656, TIMER set: 30000000us delay (@1171624207) 0> <t: 3854314>, nrf_mesh_dfu.c, 581, RADIO TX! SLOT 1, count 3, interval: exponential, handle: FFFC 0> <t: 4837350>, nrf_mesh_dfu.c, 351, Timeout fired @1171624207 0> <t: 4852242>, nrf_mesh_dfu.c, 431, Abort event. Reason: 0x4 0> <t: 4852246>, dfu_init.c, 151, ----- NRF_MESH_EVT_DFU_END... 0> <t: 4852250>, nrf_mesh_dfu.c, 581, RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFE 0> <t: 6047382>, serial_bearer.c, 388, frank: 55 0> <t: 6047387>, serial_bearer.c, 388, frank: 7 0> <t: 6047393>, serial_bearer.c, 388, frank: 32 0> <t: 6047399>, serial_bearer.c, 388, frank: 1 0> <t: 6047404>, serial_bearer.c, 388, frank: 0 0> <t: 6047410>, serial_bearer.c, 388, frank: C7
Could anyone help it?
Frank
