thread_mqtt_sn_client_publisher for dongle (pca10059)
I try to transfer the thread_mqtt_sn_client_publisher example from the pca10056 to the pca10059.
Before that, I tried out the example with the pca10056, a boarder router (RPi + pca10059) and homeassistant server. I was able to send a message via mqttsn by pressing a button on the DK to homeassistant. Everthing worked as expected.
Now I want to do the same with the pca10059. But since I have not enough buttons on the dongle, I tried to connect to the network within my main with some time to wait for each step and then periodically publish a message:
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "app_scheduler.h"
#include "app_timer.h"
#include "bsp_thread.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#include "mqttsn_client.h"
#include "thread_utils.h"
#include <openthread/thread.h>
#define SEARCH_GATEWAY_TIMEOUT 5                                            /**< MQTT-SN Gateway discovery procedure timeout in [s]. */
#define SCHED_QUEUE_SIZE       32                                           /**< Maximum number of events in the scheduler queue. */
#define SCHED_EVENT_DATA_SIZE  APP_TIMER_SCHED_EVENT_DATA_SIZE              /**< Maximum app_scheduler event size. */
static mqttsn_client_t      m_client;                                       /**< An MQTT-SN client instance. */
static mqttsn_remote_t      m_gateway_addr;                                 /**< A gateway address. */
static uint8_t              m_gateway_id;                                   /**< A gateway ID. */
static mqttsn_connect_opt_t m_connect_opt;                                  /**< Connect options for the MQTT-SN client. */
static uint8_t              m_led_state        = 0;                         /**< Previously sent BSP_LED_2 command. */
static uint16_t             m_msg_id           = 0;                         /**< Message ID thrown with MQTTSN_EVENT_TIMEOUT. */
static char                 m_client_id[]      = "nRF52840_publisher";      /**< The MQTT-SN Client's ID. */
static char                 m_topic_name[]     = "nRF52840_resources/led3"; /**< Name of the topic corresponding to subscriber's BSP_LED_2. */
static mqttsn_topic_t       m_topic            =                            /**< Topic corresponding to subscriber's BSP_LED_2. */
    .p_topic_name = (unsigned char *)m_topic_name,
    .topic_id     = 0,
 * @section MQTT-SN
/**@brief Turns the MQTT-SN network indication LED on.
 * @details This LED is on when an MQTT-SN client is in connected or awake state.
static void light_on(void)
    LEDS_ON(BSP_LED_3_MASK);
/**@brief Turns the MQTT-SN network indication LED off.
 * @details This LED is on when an MQTT-SN client is in disconnected or asleep state.
static void light_off(void)
    LEDS_OFF(BSP_LED_3_MASK);
/**@brief Initializes MQTT-SN client's connection options.
static void connect_opt_init(void)
    m_connect_opt.alive_duration = MQTTSN_DEFAULT_ALIVE_DURATION,
    m_connect_opt.clean_session  = MQTTSN_DEFAULT_CLEAN_SESSION_FLAG,
    m_connect_opt.will_flag      = MQTTSN_DEFAULT_WILL_FLAG,
    m_connect_opt.client_id_len  = strlen(m_client_id),
    memcpy(m_connect_opt.p_client_id, (unsigned char *)m_client_id, m_connect_opt.client_id_len);
/**@brief Processes GWINFO message from a gateway.
 * @details This function updates MQTT-SN Gateway information.
 * @param[in]    p_event  Pointer to MQTT-SN event.
static void gateway_info_callback(mqttsn_event_t * p_event)
    m_gateway_addr = *(p_event->event_data.connected.p_gateway_addr);
    m_gateway_id   = p_event->event_data.connected.gateway_id;
/**@brief Processes CONNACK message from a gateway.
 * @details This function launches the topic registration procedure if necessary.
static void connected_callback(void)
    light_on();
    uint32_t err_code = mqttsn_client_topic_register(&m_client,
                                                     m_topic.p_topic_name,
                                                     strlen(m_topic_name),
                                                     &m_msg_id);
    if (err_code != NRF_SUCCESS)
        NRF_LOG_ERROR("REGISTER message could not be sent. Error code: 0x%x\r\n", err_code);
/**@brief Processes DISCONNECT message from a gateway. */
static void disconnected_callback(void)
    light_off();
/**@brief Processes REGACK message from a gateway.
static void regack_callback(mqttsn_event_t * p_event)
    m_topic.topic_id = p_event->event_data.registered.packet.topic.topic_id;
    NRF_LOG_INFO("MQTT-SN event: Topic has been registered with ID: %d.\r\n",
                 p_event->event_data.registered.packet.topic.topic_id);
/**@brief Processes retransmission limit reached event. */
static void timeout_callback(mqttsn_event_t * p_event)
    NRF_LOG_INFO("MQTT-SN event: Timed-out message: %d. Message ID: %d.\r\n",
                  p_event->event_data.error.msg_type,
                  p_event->event_data.error.msg_id);
/**@brief Processes results of gateway discovery procedure. */
static void searchgw_timeout_callback(mqttsn_event_t * p_event)
    NRF_LOG_INFO("MQTT-SN event: Gateway discovery result: 0x%x.\r\n", p_event->event_data.discovery);
/**@brief Function for handling MQTT-SN events. */
void mqttsn_evt_handler(mqttsn_client_t * p_client, mqttsn_event_t * p_event)
    switch(p_event->event_id)
        case MQTTSN_EVENT_GATEWAY_FOUND:
            NRF_LOG_INFO("MQTT-SN event: Client has found an active gateway.\r\n");
            gateway_info_callback(p_event);
        case MQTTSN_EVENT_CONNECTED:
            NRF_LOG_INFO("MQTT-SN event: Client connected.\r\n");
            connected_callback();
        case MQTTSN_EVENT_DISCONNECT_PERMIT:
            NRF_LOG_INFO("MQTT-SN event: Client disconnected.\r\n");
            disconnected_callback();
        case MQTTSN_EVENT_REGISTERED:
            NRF_LOG_INFO("MQTT-SN event: Client registered topic.\r\n");
            regack_callback(p_event);
        case MQTTSN_EVENT_PUBLISHED:
            NRF_LOG_INFO("MQTT-SN event: Client has successfully published content.\r\n");
        case MQTTSN_EVENT_TIMEOUT:
            NRF_LOG_INFO("MQTT-SN event: Retransmission retries limit has been reached.\r\n");
            timeout_callback(p_event);
        case MQTTSN_EVENT_SEARCHGW_TIMEOUT:
            NRF_LOG_INFO("MQTT-SN event: Gateway discovery procedure has finished.\r\n");
            searchgw_timeout_callback(p_event);
 * @section State
static void state_changed_callback(uint32_t flags, void * p_context)
    NRF_LOG_INFO("State changed! Flags: 0x%08x Current role: %d\r\n",
                 flags, otThreadGetDeviceRole(p_context));
 * @section Buttons
static void publish(void)
    uint32_t err_code = mqttsn_client_publish(&m_client, m_topic.topic_id, "Hello", 1, &m_msg_id);
        NRF_LOG_ERROR("PUBLISH message could not be sent. Error code: 0x%x\r\n", err_code)
 * @section Initialization
/**@brief Function for initializing the Application Timer Module.
static void timer_init(void)
    uint32_t err_code = app_timer_init();
/**@brief Function for initializing the LEDs.
static void leds_init(void)
    LEDS_CONFIGURE(LEDS_MASK);
    LEDS_OFF(LEDS_MASK);
static void log_init(void)
/**@brief Function for initializing the Thread Stack.
static void thread_instance_init(void)
    thread_configuration_t thread_configuration =
        .radio_mode        = THREAD_RADIO_MODE_RX_ON_WHEN_IDLE,
        .autocommissioning = true,
        .autostart_disable = false,
    thread_init(&thread_configuration);
    thread_cli_init();
    thread_state_changed_callback_set(state_changed_callback);
/**@brief Function for initializing the MQTTSN client.
static void mqttsn_init(void)
    uint32_t err_code = mqttsn_client_init(&m_client,
                                           MQTTSN_DEFAULT_CLIENT_PORT,
                                           mqttsn_evt_handler,
                                           thread_ot_instance_get());
    connect_opt_init();
/**@brief Function for initializing scheduler module.
static void scheduler_init(void)
    APP_SCHED_INIT(SCHED_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
int main(int argc, char *argv[])
    log_init();
    scheduler_init();
    timer_init();
    leds_init();
    thread_instance_init();
    thread_bsp_init();
    mqttsn_init();
    nrf_delay_ms(10000);
    mqttsn_client_search_gateway(&m_client, SEARCH_GATEWAY_TIMEOUT);
    mqttsn_client_connect(&m_client, &m_gateway_addr, m_gateway_id, &m_connect_opt);
    while (true)
        thread_process();
        app_sched_execute();
            thread_sleep();
        nrf_delay_ms(2000);
        publish();
Unfortunately, I dont receive any input, when I start listining to the topic in homeassistant.
What do I have to consider, when transferring the code to the dongle.
I changed everything in the makefile and linker script to fit the specifications of the dongle.
Regards
Maboo
Ps: I use Linux, SDK17, VS-Code, pca10059
  • I used the mqttsn_client_publisher example. And the idea is, I have a border router with your firmware and the dongle publishing a string via the router to Home-assistant after I press a button.
    Now I manually connected the router with the dongle as described before: I connect myself to the router via wifi, open the OpenThread web GUI and join the dongle. Now I can send the string.
    But eventually I want to use an external commissioner like the thread app on my phone. Therefore I have to access the dongle to find out the EUI of the joiner (dongle). But here is the problem, I cant access via putty - Unable to open the connection to /dev/tty... . If I use the same code on the DK, it works perfectly.
    I have enabled UART and RTT in the sdk_config.h
  • The dongle's usb pins aren't connected to UART. In fact, it is not possible to move the USB pins. They are fixed in HW. Use the same implementation that is used in the example.
    SDK\examples\thread\cli\ftd\usb\pca10059.
    You can even test it and see that the CLI is working over USB there.
    So to clarify, the USB pinout on the dongle is not the same as the programming usb port on the DK. On the DK, the default uart pins are routed through the programmer back to the USB cable, while the USB peripheral on the DK (the one located on the long side) is the same usb port that is present on the dongle.
    BR,
    Edvin
  • Thanks for the quick response. I understand the problem with the HW USB pins on the dongle. But what do you mean by:
    Where can I find the usb implementation for the dongle? Do you mean the sdk_config?
  • i guess you mean the sdk_config and makefile?!
  • No, I mean that you should look into how this example, compared to the UART CLI example sets up the CLI to use the USB peripheral instead of the UART. The reason I just said you should check out the implementation is that I don't remember by heart how it is set up. But whatever you copied from the UART CLI example to set up CLI to your dongle, you should copy from the USB CLI example in stead.
    If you are stuck along the way, I would also suggest trying this on the nRF52840 DK first, where you use the USB peripheral (the port on the long side of the DK) as the CLI interface, because then you should be able to debug and check the log using the other USB cable (the programmer/UART usb). It may give a lot of helpful information along the way.
    Edvin
