thread_mqtt_sn_client_publisher for dongle (pca10059)
I try to transfer the thread_mqtt_sn_client_publisher example from the pca10056 to the pca10059.
Before that, I tried out the example with the pca10056, a boarder router (RPi + pca10059) and homeassistant server. I was able to send a message via mqttsn by pressing a button on the DK to homeassistant. Everthing worked as expected.
Now I want to do the same with the pca10059. But since I have not enough buttons on the dongle, I tried to connect to the network within my main with some time to wait for each step and then periodically publish a message:
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "app_scheduler.h"
#include "app_timer.h"
#include "bsp_thread.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#include "mqttsn_client.h"
#include "thread_utils.h"
#include <openthread/thread.h>
#define SEARCH_GATEWAY_TIMEOUT 5                                            /**< MQTT-SN Gateway discovery procedure timeout in [s]. */
#define SCHED_QUEUE_SIZE       32                                           /**< Maximum number of events in the scheduler queue. */
#define SCHED_EVENT_DATA_SIZE  APP_TIMER_SCHED_EVENT_DATA_SIZE              /**< Maximum app_scheduler event size. */
static mqttsn_client_t      m_client;                                       /**< An MQTT-SN client instance. */
static mqttsn_remote_t      m_gateway_addr;                                 /**< A gateway address. */
static uint8_t              m_gateway_id;                                   /**< A gateway ID. */
static mqttsn_connect_opt_t m_connect_opt;                                  /**< Connect options for the MQTT-SN client. */
static uint8_t              m_led_state        = 0;                         /**< Previously sent BSP_LED_2 command. */
static uint16_t             m_msg_id           = 0;                         /**< Message ID thrown with MQTTSN_EVENT_TIMEOUT. */
static char                 m_client_id[]      = "nRF52840_publisher";      /**< The MQTT-SN Client's ID. */
static char                 m_topic_name[]     = "nRF52840_resources/led3"; /**< Name of the topic corresponding to subscriber's BSP_LED_2. */
static mqttsn_topic_t       m_topic            =                            /**< Topic corresponding to subscriber's BSP_LED_2. */
    .p_topic_name = (unsigned char *)m_topic_name,
    .topic_id     = 0,
 * @section MQTT-SN
/**@brief Turns the MQTT-SN network indication LED on.
 * @details This LED is on when an MQTT-SN client is in connected or awake state.
static void light_on(void)
    LEDS_ON(BSP_LED_3_MASK);
/**@brief Turns the MQTT-SN network indication LED off.
 * @details This LED is on when an MQTT-SN client is in disconnected or asleep state.
static void light_off(void)
    LEDS_OFF(BSP_LED_3_MASK);
/**@brief Initializes MQTT-SN client's connection options.
static void connect_opt_init(void)
    m_connect_opt.alive_duration = MQTTSN_DEFAULT_ALIVE_DURATION,
    m_connect_opt.clean_session  = MQTTSN_DEFAULT_CLEAN_SESSION_FLAG,
    m_connect_opt.will_flag      = MQTTSN_DEFAULT_WILL_FLAG,
    m_connect_opt.client_id_len  = strlen(m_client_id),
    memcpy(m_connect_opt.p_client_id, (unsigned char *)m_client_id, m_connect_opt.client_id_len);
/**@brief Processes GWINFO message from a gateway.
 * @details This function updates MQTT-SN Gateway information.
 * @param[in]    p_event  Pointer to MQTT-SN event.
static void gateway_info_callback(mqttsn_event_t * p_event)
    m_gateway_addr = *(p_event->event_data.connected.p_gateway_addr);
    m_gateway_id   = p_event->event_data.connected.gateway_id;
/**@brief Processes CONNACK message from a gateway.
 * @details This function launches the topic registration procedure if necessary.
static void connected_callback(void)
    light_on();
    uint32_t err_code = mqttsn_client_topic_register(&m_client,
                                                     m_topic.p_topic_name,
                                                     strlen(m_topic_name),
                                                     &m_msg_id);
    if (err_code != NRF_SUCCESS)
        NRF_LOG_ERROR("REGISTER message could not be sent. Error code: 0x%x\r\n", err_code);
/**@brief Processes DISCONNECT message from a gateway. */
static void disconnected_callback(void)
    light_off();
/**@brief Processes REGACK message from a gateway.
static void regack_callback(mqttsn_event_t * p_event)
    m_topic.topic_id = p_event->event_data.registered.packet.topic.topic_id;
    NRF_LOG_INFO("MQTT-SN event: Topic has been registered with ID: %d.\r\n",
                 p_event->event_data.registered.packet.topic.topic_id);
/**@brief Processes retransmission limit reached event. */
static void timeout_callback(mqttsn_event_t * p_event)
    NRF_LOG_INFO("MQTT-SN event: Timed-out message: %d. Message ID: %d.\r\n",
                  p_event->event_data.error.msg_type,
                  p_event->event_data.error.msg_id);
/**@brief Processes results of gateway discovery procedure. */
static void searchgw_timeout_callback(mqttsn_event_t * p_event)
    NRF_LOG_INFO("MQTT-SN event: Gateway discovery result: 0x%x.\r\n", p_event->event_data.discovery);
/**@brief Function for handling MQTT-SN events. */
void mqttsn_evt_handler(mqttsn_client_t * p_client, mqttsn_event_t * p_event)
    switch(p_event->event_id)
        case MQTTSN_EVENT_GATEWAY_FOUND:
            NRF_LOG_INFO("MQTT-SN event: Client has found an active gateway.\r\n");
            gateway_info_callback(p_event);
        case MQTTSN_EVENT_CONNECTED:
            NRF_LOG_INFO("MQTT-SN event: Client connected.\r\n");
            connected_callback();
        case MQTTSN_EVENT_DISCONNECT_PERMIT:
            NRF_LOG_INFO("MQTT-SN event: Client disconnected.\r\n");
            disconnected_callback();
        case MQTTSN_EVENT_REGISTERED:
            NRF_LOG_INFO("MQTT-SN event: Client registered topic.\r\n");
            regack_callback(p_event);
        case MQTTSN_EVENT_PUBLISHED:
            NRF_LOG_INFO("MQTT-SN event: Client has successfully published content.\r\n");
        case MQTTSN_EVENT_TIMEOUT:
            NRF_LOG_INFO("MQTT-SN event: Retransmission retries limit has been reached.\r\n");
            timeout_callback(p_event);
        case MQTTSN_EVENT_SEARCHGW_TIMEOUT:
            NRF_LOG_INFO("MQTT-SN event: Gateway discovery procedure has finished.\r\n");
            searchgw_timeout_callback(p_event);
 * @section State
static void state_changed_callback(uint32_t flags, void * p_context)
    NRF_LOG_INFO("State changed! Flags: 0x%08x Current role: %d\r\n",
                 flags, otThreadGetDeviceRole(p_context));
 * @section Buttons
static void publish(void)
    uint32_t err_code = mqttsn_client_publish(&m_client, m_topic.topic_id, "Hello", 1, &m_msg_id);
        NRF_LOG_ERROR("PUBLISH message could not be sent. Error code: 0x%x\r\n", err_code)
 * @section Initialization
/**@brief Function for initializing the Application Timer Module.
static void timer_init(void)
    uint32_t err_code = app_timer_init();
/**@brief Function for initializing the LEDs.
static void leds_init(void)
    LEDS_CONFIGURE(LEDS_MASK);
    LEDS_OFF(LEDS_MASK);
static void log_init(void)
/**@brief Function for initializing the Thread Stack.
static void thread_instance_init(void)
    thread_configuration_t thread_configuration =
        .radio_mode        = THREAD_RADIO_MODE_RX_ON_WHEN_IDLE,
        .autocommissioning = true,
        .autostart_disable = false,
    thread_init(&thread_configuration);
    thread_cli_init();
    thread_state_changed_callback_set(state_changed_callback);
/**@brief Function for initializing the MQTTSN client.
static void mqttsn_init(void)
    uint32_t err_code = mqttsn_client_init(&m_client,
                                           MQTTSN_DEFAULT_CLIENT_PORT,
                                           mqttsn_evt_handler,
                                           thread_ot_instance_get());
    connect_opt_init();
/**@brief Function for initializing scheduler module.
static void scheduler_init(void)
    APP_SCHED_INIT(SCHED_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
int main(int argc, char *argv[])
    log_init();
    scheduler_init();
    timer_init();
    leds_init();
    thread_instance_init();
    thread_bsp_init();
    mqttsn_init();
    nrf_delay_ms(10000);
    mqttsn_client_search_gateway(&m_client, SEARCH_GATEWAY_TIMEOUT);
    mqttsn_client_connect(&m_client, &m_gateway_addr, m_gateway_id, &m_connect_opt);
    while (true)
        thread_process();
        app_sched_execute();
            thread_sleep();
        nrf_delay_ms(2000);
        publish();
Unfortunately, I dont receive any input, when I start listining to the topic in homeassistant.
What do I have to consider, when transferring the code to the dongle.
I changed everything in the makefile and linker script to fit the specifications of the dongle.
Regards
Maboo
Ps: I use Linux, SDK17, VS-Code, pca10059
