BLE connection error with IOS devices
Hello
I'm contacting you because I'm having a problem connecting to devices that use the ble_thread_dyn_mtd_coap_cli example.
Actually, I have no problem when I connect with an Android device but the connection fails if I connect with an IOS device.
I have attached the logs of a Samsung S10 which works well and the logs of an iPhone 12 where I have a problem.
Looking at the logs, I see that in the case of IOS phones, that the smartphone sends the command "LL_PHY_REQ" saying that "Sender prefers to use the LE 2M PHY" and that nothing more happens afterwards ... However, this command is never sent with Android ...
Here are my questions:
- Do you have any idea why it stops responding after received this command?
- Would it be possible to make the smartphone believe that the device is not compatible with the 2M PHY to see if that corrects the problem?
Thank you
NOK-IPhone12-2.pcapngSamsung S10.pcapng
