How to Read ADXL362 values via SPI and Transmit them using Beacon Transmitter
*** SOLVED PARTIALLY ***
Hello again,
I solved my problem partially, the part that reads accelerometer value and transmit BLE advertising data as beacon works fine.
However, in the BLE advertising part, I couldn't really understand how to update values.
I came up with a solution that first stop advertising, then update beacon data, and start advertising again.
Is this the way how to do that? Are there any better way to update advertising data?
I would be very happy if you could help.
Best regards.
main.c
 * @brief ADXL362 Accelerometer SPI Beacon Transmitter Sample Application main source file.
#include <stdbool.h>
#include <stdint.h>
#include <stdlib.h>
#include <string.h>
#include "nordic_common.h"
#include "bsp.h"
#include "nrf_soc.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_advdata.h"
#include "app_timer.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include "nrf.h"
#include "nrf_drv_gpiote.h"
// ADXL362 Registers
#define DEVID_AD            0x00
#define DEVID_MST           0x01
#define PARTID              0x02
#define REVID               0x03
#define XDATA               0x08
#define YDATA               0x09
#define ZDATA               0x0A
#define STATUS              0x0B
#define XDATA_L             0x0E
#define XDATA_H             0x0F
#define YDATA_L             0x10
#define YDATA_H             0x11
#define ZDATA_L             0x12
#define ZDATA_H             0x13
#define TEMP_L              0x14
#define TEMP_H              0x15
#define SOFT_RESET          0x1F
#define THRESH_ACT_L        0x20
#define THRESH_ACT_H        0x21
#define TIME_ACT            0x22
#define THRESH_INACT_L      0x23
#define THRESH_INACT_H      0x24
#define TIME_INACT_L        0x25
#define TIME_INACT_H        0x26
#define ACT_INACT_CTL       0x27
#define FIFO_CONTROL        0x28
#define FIFO_SAMPLES        0x29
#define INTMAP1             0x2A
#define INTMAP2             0x2B
#define FILTER_CTL          0x2C
#define POWER_CTL           0x2D
#define SELF_TEST           0x2E
// ADXL362 SPI Commands
#define WR_ADXL             0x0A
#define RD_ADXL             0x0B
#define FIFO_ADXL           0x0D
// ADXL362 USER Defined Constants
#define USER_ACT_TIME       50
#define USER_ACT_THRESH     50
#define USER_INACT_TIME     50
#define USER_INACT_THRESH   50
// ADXL362 SPI Pin Configurations
#define ADXL362_SCK_PIN     19
#define ADXL362_MOSI_PIN    21
#define ADXL362_MISO_PIN    23
#define ADXL362_CS_PIN      12
#define SPI_INSTANCE        0                                                   // SPI instance index.
#define APP_BLE_CONN_CFG_TAG            1                                       // A tag identifying the SoftDevice BLE configuration.
#define UPDATE_MS                       5000
#define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(UPDATE_MS, UNIT_0_625_MS) // The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s).
#define BEACON_INTERVAL                 APP_TIMER_TICKS(UPDATE_MS)
#define APP_BEACON_INFO_LENGTH          0x0F                                    // Total length of information advertised by the Beacon.
#define APP_ADV_DATA_LENGTH             0x0D                                    // Length of manufacturer specific data in the advertisement.
#define APP_DEVICE_TYPE                 0x02                                    // 0x02 refers to Beacon.
#define APP_MEASURED_RSSI               0xC3                                    // The Beacon's measured RSSI at 1 meter distance in dBm.
#define APP_COMPANY_IDENTIFIER          0xFFFF                                  // Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org.
#define APP_MAJOR_VALUE                 0x01, 0x02                              // Major value used to identify Beacons.
#define APP_MINOR_VALUE                 0x03, 0x04                              // Minor value used to identify Beacons.
#define APP_BEACON_UUID 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00			// Proprietary UUID for Beacon.
#define DEAD_BEEF                       0xDEADBEEF                              // Value used as error code on stack dump, can be used to identify stack location on stack unwind.
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO   18                                      // Position of the MSB of the Major Value in m_beacon_info array.
#define UICR_ADDRESS                    0x10001080                              // Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location.
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);            // SPI instance
static volatile bool spi_xfer_done;                                             // Flag used to indicate that SPI instance completed the transfer.
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;                   // SPI configuration
int16_t xyzt[4];        // ADXL362_GetXYZT function parameters
uint8_t idxb = 0;
APP_TIMER_DEF(m_beacon_timer_id);                                               // Timer ID
static volatile bool m_beacon_timer_flag = false;                               // Timer Flag
static ble_gap_adv_params_t m_adv_params;                                       // Parameters to be passed to the stack when starting advertising.
static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;      // Advertising handle used to identify an advertising set.
static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];       // Buffer for storing an encoded advertising set.
 * @brief Struct that contains pointers to the encoded advertising data.
static ble_gap_adv_data_t m_adv_data =
		.adv_data =
				.p_data = m_enc_advdata,
				.len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
		.scan_rsp_data =
				.p_data = NULL,
				.len    = 0
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                          // Information advertised by the Beacon.
		APP_DEVICE_TYPE,                                                        // Manufacturer specific information. Specifies the device type in this implementation.
		APP_ADV_DATA_LENGTH,                                                    // Manufacturer specific information. Specifies the length of the manufacturer specific data in this implementation.
		APP_BEACON_UUID,                                                        // 128 bit UUID value.
		APP_MAJOR_VALUE,                                                        // Major arbitrary value that can be used to distinguish between Beacons.
		APP_MINOR_VALUE,                                                        // Minor arbitrary value that can be used to distinguish between Beacons.
		APP_MEASURED_RSSI                                                       // Manufacturer specific information. The Beacon's measured TX power in this implementation.
 * @brief Callback function for asserts in the SoftDevice.
 * @warning This handler is an example only and does not fit a final product.
 * You need to analyze how your product is supposed to react in case of Assert.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
 * @brief   SPI user event handler.
 * @param   event.
 * @retval  None.
void spi_event_handler(nrf_drv_spi_evt_t const * p_event, void * p_context)
	spi_xfer_done = true;
 * @brief   Function for reading from ADXL362 register.
 * @param   spi_config  SPI master configuration structure pointer.
 * @param   address     Address of register to read.
 * @retval  None.
uint8_t ADXL362_ReadReg(nrf_drv_spi_config_t * spi_config, uint8_t address)
	uint8_t m_rx_buf[3] = {0, 0, 0};
	uint8_t m_tx_buf[3] = {0, 0, 0};
	spi_xfer_done = false;
	m_tx_buf[2] = 0x00;                                                         // Dummy byte for reading reg
	m_tx_buf[1] = address;                                                      // Address
	m_tx_buf[0] = RD_ADXL;                                                      // Read instruction
	nrf_gpio_pin_clear(spi_config->ss_pin);                                     // Pull ss pin low to enable the slave
	APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, 3, m_rx_buf, 3));      // Transmit the read instruction, address, and receive register value
	while (!spi_xfer_done) { __WFE(); }                                         // Wait until SPI communication is finished
	nrf_gpio_pin_set(spi_config->ss_pin);                                       // Pull ss pin high to disable the slave
	return m_rx_buf[2];                                                         // Return register value
 * @brief   Function for writing to ADXL362 register.
 * @param   address     Address of register to write.
 * @param   cmd         Command byte to write to register.
 * @retval  None.
void ADXL362_WriteReg(nrf_drv_spi_config_t * spi_config, uint8_t address, uint8_t cmd)
	m_tx_buf[2] = cmd;                                                          // Command
	m_tx_buf[0] = WR_ADXL;                                                      // Write instruction
	APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, 3, m_rx_buf, 3));      // Transmit the write instruction, address, and command
 * @brief   Function for reading 8-bits XYZ values from ADXL362 register.
 * @param   x           Points to data buffer for X-axis.
 * @param   y           Points to data buffer for Y-axis.
 * @param   z           Points to data buffer for Z-axis.
 * @retval  None.
void ADXL362_GetXYZ8(nrf_drv_spi_config_t * spi_config, int8_t * x, int8_t * y, int8_t * z)
	uint8_t m_rx_buf[5] = {0, 0, 0, 0, 0};
	uint8_t m_tx_buf[5] = {0, 0, 0, 0, 0};
	m_tx_buf[1] = XDATA;                                                        // Address
	APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, 5, m_rx_buf, 5));      // Transmit the read instruction, address, and receive XYZ 8bit values
	// Store sensor data into buffers
	*x = m_rx_buf[2];                                                           // x
	*y = m_rx_buf[3];                                                           // y
	*z = m_rx_buf[4];                                                           // z
 * @brief   Function for reading 12-bits XYZ values from ADXL362 register.
 * @retval None.
void ADXL362_GetXYZ12(nrf_drv_spi_config_t * spi_config, int16_t * x, int16_t * y, int16_t * z)
	uint8_t m_rx_buf[8] = {0, 0, 0, 0, 0, 0, 0, 0};
	uint8_t m_tx_buf[8] = {0, 0, 0, 0, 0, 0, 0, 0};
	m_tx_buf[1] = XDATA_L;                                                      // Address
	APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, 8, m_rx_buf, 8));      // Transmit the read instruction, address, and receive XYZ 12bit values
	*x = ((int16_t)m_rx_buf[3] << 8) | (int16_t)m_rx_buf[2];                    // x
	*y = ((int16_t)m_rx_buf[5] << 8) | (int16_t)m_rx_buf[4];                    // y
	*z = ((int16_t)m_rx_buf[7] << 8) | (int16_t)m_rx_buf[6];                    // z
 * @brief   Function for reading 12-bits XYZT values from ADXL362 register.
 * @param   xyzt        Points to data buffer for XYZ-axes and temperature.
 * @retval  None.
void ADXL362_GetXYZT(nrf_drv_spi_config_t * spi_config, int16_t * xyzt)
	uint8_t m_rx_buf[10] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
	uint8_t m_tx_buf[10] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
	APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, 10, m_rx_buf, 10));    // Transmit the read instruction, address, and receive 12-bits XYZ values
	xyzt[0] = ((int16_t)m_rx_buf[3] << 8) | (int16_t)m_rx_buf[2];               // x
	xyzt[1] = ((int16_t)m_rx_buf[5] << 8) | (int16_t)m_rx_buf[4];               // y
	xyzt[2] = ((int16_t)m_rx_buf[7] << 8) | (int16_t)m_rx_buf[6];               // z
	xyzt[3] = ((int16_t)m_rx_buf[9] << 8) | (int16_t)m_rx_buf[8];               // t
 * @brief   Function for writing activity setup to ADXL362 register.
 * @param   thresh      THRESH_ACT value for activity detection "sensitivity".
 * @param   timer       TIME_ACT value for activity detection "delay".
 * @retval  None.
void ADXL362_ActivityInit(nrf_drv_spi_config_t * spi_config, uint16_t thresh, uint8_t timer)
	m_tx_buf[4] = timer;                                                        // TIME_ACT
	m_tx_buf[3] = (thresh >> 8) & 0xFF;                                         // THRESH_ACT_H
	m_tx_buf[2] = thresh & 0xFF;                                                // THRESH_ACT_L
	m_tx_buf[1] = THRESH_ACT_L;                                                 // Address
 * @brief   Function for writing inactivity setup to ADXL362 register.
 * @param   thresh      THRESH_ACT value for inactivity detection "sensitivity".
 * @param   timer       TIME_ACT value for inactivity detection "delay".
 * @retval  None.
void ADXL362_InactivityInit(nrf_drv_spi_config_t * spi_config, uint16_t thresh, uint16_t timer)
	uint8_t m_rx_buf[6] = {0, 0, 0, 0, 0, 0};
	uint8_t m_tx_buf[6] = {0, 0, 0, 0, 0, 0};
	m_tx_buf[5] = (timer >> 8) & 0xFF;                                          // TIME_INACT_H
	m_tx_buf[4] = timer & 0xFF;                                                 // TIME_INACT_L
	m_tx_buf[3] = (thresh >> 8) & 0xFF;                                         // THRESH_INACT_H
	m_tx_buf[2] = thresh & 0xFF;                                                // THRESH_INACT_L
	m_tx_buf[1] = THRESH_INACT_L;                                               // Address
	APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, 6, m_rx_buf, 6));      // Transmit the read instruction, address, and receive XYZ 8bit values
 * @brief   Function for initializing ADXL362.
 * @retval  None.
void ADXL362_Init(nrf_drv_spi_config_t * spi_config)
	uint8_t reg = 0;                                                            // Hold register value
	// Reset ADXL362
	//ADXL362_WriteReg(spi_config, SOFT_RESET, 0x52);                           // Write 0x52 (R in ASCII) to soft reset register
	//nrf_delay_ms(1000);
	reg = ADXL362_ReadReg(spi_config, DEVID_AD);                                // Read device id register
	// Configure ADXL362 Activity and Inactivity
	ADXL362_ActivityInit(spi_config, USER_ACT_THRESH, USER_ACT_TIME);           // Set activity threshold and time
	ADXL362_InactivityInit(spi_config, USER_INACT_THRESH, USER_INACT_TIME);     // Set inactivity threshold and time
	ADXL362_WriteReg(spi_config, ACT_INACT_CTL, 0x3F);                          // Set referenced activity and inactivity, and loop mode
	reg = ADXL362_ReadReg(spi_config, ACT_INACT_CTL);                           // Read activity and inactivity control register
	// Configure ADXL362 Interrupt Registers
	ADXL362_WriteReg(spi_config, INTMAP1, 0x40);                                // Map awake interrupt to INT1 pin
	reg = ADXL362_ReadReg(spi_config, INTMAP1);                                 // Read interrupt register
	// Configure ADXL362 Filter Control Register
	ADXL362_WriteReg(spi_config, FILTER_CTL, 0x13);                             // Set ADXL362 to 2g range, 100Hz
	reg = ADXL362_ReadReg(spi_config, FILTER_CTL);                              // Read filter control register
	// Configure ADXL362 Power Control Register
	ADXL362_WriteReg(spi_config, POWER_CTL, 0x24);                              // Set autosleep bit POWER_CTL[2] and ultralow noise
	reg = ADXL362_ReadReg(spi_config, POWER_CTL);                               // Read power control register
	ADXL362_WriteReg(spi_config, POWER_CTL, reg | 0x02);                        // Set to measurement mode
	nrf_delay_ms(100);
 * @brief   Function for initializing ADXL362 with SPI configurations.
 * @param   None.
 * @retval  None.
void spi_adxl362_init(void)
	spi_config.frequency = NRF_DRV_SPI_FREQ_125K;
	//spi_config.frequency = NRF_DRV_SPI_FREQ_250K;
	//spi_config.frequency = NRF_DRV_SPI_FREQ_1M;
	spi_config.mode = NRF_DRV_SPI_MODE_0;
	spi_config.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST;
	spi_config.orc = 0xCC;
	spi_config.ss_pin   = ADXL362_CS_PIN;
	spi_config.miso_pin = ADXL362_MISO_PIN;
	spi_config.mosi_pin = ADXL362_MOSI_PIN;
	spi_config.sck_pin  = ADXL362_SCK_PIN;
	APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
	nrf_gpio_cfg(spi_config.sck_pin, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
	nrf_gpio_cfg(spi_config.mosi_pin, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
	ADXL362_Init(&spi_config);
 * @brief   Function for initializing the Advertising functionality.
 * @param   None.
 * @retval  None.
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack
 *          when starting advertising.
	ret_code_t err_code;
	ble_advdata_t advdata;
	uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
	ble_advdata_manuf_data_t manuf_specific_data;
	manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
	// If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
	// UICR instead of using the default values. The major and minor values obtained from the UICR
	// are encoded into advertising data in big endian order (MSB First).
	// To set the UICR used by this example to a desired value, write to the address 0x10001080
	// using the nrfjprog tool. The command to be used is as follows.
	// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
	// For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
	// the following command should be used.
	// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
	uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
	uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
	uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
	m_beacon_info[index++] = MSB_16(major_value);
	m_beacon_info[index++] = LSB_16(major_value);
	m_beacon_info[index++] = MSB_16(minor_value);
	m_beacon_info[index++] = LSB_16(minor_value);
	memset(xyzt, 0, 4);
	ADXL362_GetXYZT(&spi_config, xyzt);
	m_beacon_info[2] = xyzt[0] >> 8;
	m_beacon_info[3] = xyzt[0] & 0xFF;
	m_beacon_info[4] = xyzt[1] >> 8;;
	m_beacon_info[5] = xyzt[1] & 0xFF;
	m_beacon_info[6] = xyzt[2] >> 8;
	m_beacon_info[7] = xyzt[2] & 0xFF;
	m_beacon_info[8] = xyzt[3] >> 8;
	m_beacon_info[9] = xyzt[3] & 0xFF;
	manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
	manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
	// Build and set advertising data.
	memset(&advdata, 0, sizeof(advdata));
	advdata.name_type             = BLE_ADVDATA_NO_NAME;
	advdata.flags                 = flags;
	advdata.p_manuf_specific_data = &manuf_specific_data;
	// Initialize advertising parameters (used when starting advertising).
	memset(&m_adv_params, 0, sizeof(m_adv_params));
	m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
	m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
	m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
	m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
	m_adv_params.duration        = 0;       // Never time out.
	err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
	err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
 * @brief   Function for starting advertising.
 * @param   None.
 * @retval  None.
	err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
 * @brief   Function for stopping advertising.
 * @param   None.
 * @retval  None.
static void advertising_stop(void)
	err_code = sd_ble_gap_adv_stop(m_adv_handle);
 * @brief   Function for updating advertising.
 * @param   None.
 * @retval  None.
static void advertising_update(void)
	advertising_stop();
	memset(xyzt, 0, 4);
	advertising_start();
 * @brief   Function for handling beacon timeout.
 * @param   None.
 * @retval  None.
static void beacon_timeout_handler(void * p_context)
	UNUSED_PARAMETER(p_context);
	// Set timer flag
	m_beacon_timer_flag = true;
 * @brief   Function for starting application timers.
 * @param   None.
 * @retval  None.
static void application_timers_start(void)
	// Start application timers.
	err_code = app_timer_start(m_beacon_timer_id, BEACON_INTERVAL, NULL);
 * @brief   Function for initializing the BLE stack.
 * @param   None.
 * @retval  None.
	uint32_t ram_start = 0;
	// Enable BLE stack.
 * @brief   Function for initializing timers.
 * @param   None.
 * @retval  None.
static void timers_init(void)
	// Initialize timer module.
	err_code = app_timer_init();
	// Create timers.
	err_code = app_timer_create(&m_beacon_timer_id, APP_TIMER_MODE_REPEATED, beacon_timeout_handler);
 * @brief   Function for initializing power management.
 * @param   None.
 * @retval  None.
/**@brief   Function for handling the idle state (main loop).
 * @param   None.
 * @retval  None.
 * @details If there is no pending log operation,
 *          then sleep until next the next event occurs.
	nrf_pwr_mgmt_run();
 * @brief   Function for application main entry.
 * @param   None.
 * @retval  int.
	// Initialize.
	timers_init();
	power_management_init();
	spi_adxl362_init();
	ble_stack_init();
	advertising_init();
	// Start execution.
	application_timers_start();
	// Enter main loop.
	while (1)
		// Check timer flag to update advertising data
		if (m_beacon_timer_flag)
			advertising_update();
		idle_state_handle();
*** FIRST POST ***
I have several PCB covering nRF52840 and ADXL362 accelerometer.
I'm trying to write a C code that reads ADXL362 values via SPI, and transmit them using Beacon Transmitter.
After programming nRF52840 chips with using ble_app_beacon example project in Segger Embedded Studio environment,
I have checked them using nRF Connect Android App and seen them with their addresses and names "nRF Beacon" as expected.
Here is my setup:
- nRF5 SDK v17.0.2
- Segger Embedded Studio
- Beacon Transmitter Sample Application (examples\ble_peripheral\ble_app_beacon)
Here is my main purpose:
- to write a C code that reads ADXL362 values using SPI, and transmit them using Beacon Transmitter.
- to write a Python 3 code reading those transmit values and doing other things.
I looked at related questions but I didn't find what I needed exactly.
Best regards.
  • I suggest you serch devzone for other posts about the adxl362, there are quite a few.
    The general method to interface with a sensor is to get the sensor manufacturer's driver and port it to whatever platform you're using(nRF52). The sensor drivers are usually written in a platform-agnostic way where all you need to do is to implement the serial driver API's in the sensor driver's R/W functions.
    See SPIM driver API docs.
    You should study the SPI example in the SDK first.
  • Hello again, thank you for your reply.
    I think I could not really understand how to embed SPI (examples\peripheral\spi) into Beacon (examples\ble_peripheral\ble_app_beacon). Could you also inform and help me with that issue?
    Note that,
    - I searched other posts about ADXL362 already but I will search and study again deeply as you suggested.
    - I also studied SPI Master Example (examples\peripheral\spi) but I will also study SPIM driver API docs as you suggested.
    - I will also share my related code for helping people engaging same issues, if it would be successfully implemented.
    Best regards.
    I suggest you make a copy of the SPIM example and modify that to talk to the ADX362, then merge this modified project into the beacon example.
  • Thank you for your suggestion, I will try that and notify updates for this post's followers if any :)
