Hi
I am using the latest SDK for Mesh and also the latest nrf sdk.
Downloaded and installed both last week.
I have written an application that is derived from the light_switch client example and I merged in the usb-cdc example.
Goal, send a command over virtual serial port to trigger a mesh message to be sent.
I have got to the stage that when I run in Segger IDE using F5 it fires up. From Nordic's phone mesh app I can see it there waiting to be provisioned.
I also see the virtual comport appear in Windows.
When I now unplug the devkit from my PC and just plug in the virtual serial port cable, I do not see the serial port.
I wrote the app so that using #defines I can disable mesh or usb-cdc functionality.
When I disable usb-cdc but enable mesh, I see the board fireup without the debugger and I can see it waiting to be provisioned.
When I disable mesh but enable usb-cdc, I can see the serail port appear in windows.
Hence independently the work.
When I enable both, I can see it waiting to be provisioned, but I cannot see the serial port -- unless I plug-in the USB cable for jlink
Can you help?
Look forward to hearing from you
Kind regards
Mahendra
