Dear,
I tried to make a copy of the Asset Tracker example application to start my own project. i gett this error
create_nordic_project.py failed
Creating solution aws_iot.emProject
C:/NordicSemi/v1.4.1/toolchain/opt/bin/cmake.exe -GNinja -DBOARD=thingy91_nrf9160 -DBOARD_DIR=C:\NordicSemi\v1.4.1\nrf\boards\arm\thingy91_nrf9160 -BC:\NordicSemi\v1.4.1\nrf\samples\nrf9160\aws_iot\build_thingy91_nrf9160 -SC:\NordicSemi\v1.4.1\nrf\samples\nrf9160\aws_iot -DNCS_TOOLCHAIN_VERSION=1.4.1 -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:\NordicSemi\v1.4.1\toolchain\segger_embedded_studio/html/configure_nordic_project_menuconfig.py
-- Application: C:/NordicSemi/v1.4.1/nrf/samples/nrf9160/aws_iot
-- Zephyr version: 2.4.0 (C:/NordicSemi/v1.4.1/zephyr)
-- Found Python3: C:/NordicSemi/v1.4.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.7.2", minimum required is "0.7.1")
-- Board: thingy91_nrf9160
-- Cache files will be written to: C:/NordicSemi/v1.4.1/zephyr/.cache
-- Found dtc: C:/NordicSemi/v1.4.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (C:/NordicSemi/v1.4.1/toolchain/opt)
-- Found BOARD.dts: C:/NordicSemi/v1.4.1/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160.dts
-- Generated zephyr.dts: C:/NordicSemi/v1.4.1/nrf/samples/nrf9160/aws_iot/build_thingy91_nrf9160/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/NordicSemi/v1.4.1/nrf/samples/nrf9160/aws_iot/build_thingy91_nrf9160/zephyr/include/generated/devicetree_unfixed.h
Parsing C:/NordicSemi/v1.4.1/nrf/samples/nrf9160/aws_iot/Kconfig
Loaded configuration 'C:/NordicSemi/v1.4.1/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_defconfig'
Merged configuration 'C:/NordicSemi/v1.4.1/nrf/samples/nrf9160/aws_iot/prj.conf'
Including boilerplate (Zephyr base): C:/NordicSemi/v1.4.1/zephyr/cmake/app/boilerplate.cmake
-- Using NCS Toolchain 1.4.1 for building. (C:/NordicSemi/v1.4.1/toolchain/cmake)
warning: BSD_LIBRARY (defined at C:/NordicSemi/v1.4.1/nrf\lib\bsdlib/Kconfig:8) has direct dependencies TRUSTED_EXECUTION_NONSECURE with value n, but is currently being y-selected by the following symbols:
- MODEM_INFO (defined at C:/NordicSemi/v1.4.1/nrf\lib\modem_info/Kconfig:7), with value y, direct dependencies y (value: y)
error: Aborting due to Kconfig warnings
CMake Error at C:/NordicSemi/v1.4.1/zephyr/cmake/kconfig.cmake:239 (message):
command failed with return code: 1
C:/NordicSemi/v1.4.1/zephyr/cmake/app/boilerplate.cmake:591 (include)
C:/NordicSemi/v1.4.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
C:/NordicSemi/v1.4.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
CMakeLists.txt:9 (find_package)
error: cmake failed
create_nordic_project.py failed (1)
