How to use PPK2 with voltage over 5V
I would like to use a PPK2 on a custom board I have developed.  This board requires an power supply voltage of at least 7.5V, up to 9V.
In looking over the wiring diagram for the PPK2, I see that the supplied power is run through the PPK2.  Since the PPK2 is specified for a maximum supply voltage of 5V, it seems that I cannot use it for the particular DUT at hand.
I've given this some thought, and it occurs to me that I might be able to power the DUT using a 5V-to-8V buck converter, thereby remaining within the limits of the PPK2 while still satisfying the DUT power needs.  I realize that there would be power loss due to the converter, but I might be able to account for that.  However, it also seems to me that the inductance of a buck converter would distort the current usage pattern, preventing the PPK2 from showing the actual peaks, lows, and duration of power usage by the DUT.
Does anyone have a means of obtaining accurate readings with a PPK2 where the DUT requires more than 5V?
