Sending CONNACK to nrfPublisher, but no responses (MQTT)
I am following the MQTT example provided https://infocenter.nordicsemi.com/topic/sdk_nrf5_v16.0.0/iot_sdk_app_mqtt.html?cp=7_5_0_4_2_4_6 with nRFSDK 16.0.0 and nRF52DK
I have similar problem like this thread (I can't find a solution in this thread) but with the non secure port 1883. I established 6lowpan connection with nRF52DK and raspberry pi w. The ping6 shows fine and the LED 1 is ON
ping6 2001:db8::63:f7ff:fe14:8e3 -c 4
PING 2001:db8::63:f7ff:fe14:8e3(2001:db8::63:f7ff:fe14:8e3) 56 data bytes
64 bytes from 2001:db8::63:f7ff:fe14:8e3: icmp_seq=1 ttl=255 time=222 ms
64 bytes from 2001:db8::63:f7ff:fe14:8e3: icmp_seq=2 ttl=255 time=149 ms
64 bytes from 2001:db8::63:f7ff:fe14:8e3: icmp_seq=3 ttl=255 time=122 ms
64 bytes from 2001:db8::63:f7ff:fe14:8e3: icmp_seq=4 ttl=255 time=145 ms
and the interface address is same as the example 2001:db8::1.
Connection changed to non secure with the port 1883
static void app_mqtt_connect(void)
    mqtt_client_init(&m_app_mqtt_client);
    memcpy(m_app_mqtt_client.broker_addr.u8, m_broker_addr.u8, IPV6_ADDR_SIZE);
    m_app_mqtt_client.broker_port          = APP_MQTT_BROKER_PORT;
    m_app_mqtt_client.evt_cb               = app_mqtt_evt_handler;
    m_app_mqtt_client.client_id.p_utf_str  = (uint8_t *)m_client_id;
    m_app_mqtt_client.client_id.utf_strlen = strlen(m_client_id);
    m_app_mqtt_client.p_password           = NULL;
    m_app_mqtt_client.p_user_name          = NULL;
    m_app_mqtt_client.transport_type       = MQTT_TRANSPORT_NON_SECURE;
    //m_app_mqtt_client.p_security_settings  = &m_tls_keys;
    m_app_mqtt_client.p_security_settings  = NULL;
    m_app_mqtt_client.protocol_version = MQTT_VERSION_3_1_1;
    UNUSED_VARIABLE(mqtt_connect(&m_app_mqtt_client));
And disabled the legacy mode (#define BLE_6LOWPAN_LEGACY_MODE 0)
When pressing button 1 on DK, the mosquitto broker response like this
1610669581: New client connected from 2001:db8::63:f7ff:fe14:8e3 as nrfPublisher (c1, k60).
1610669581: No will message specified.
1610669581: Sending CONNACK to nrfPublisher (0, 0)
1610669671: Client nrfPublisher has exceeded timeout, disconnecting.                                                    1610669671: Socket error on client nrfPublisher, disconnecting.
And tshark listens on port 1883
    1 0.000000000 2001:db8::63:f7ff:fe14:8e3 → 2001:db8::1  TCP 80 49153 → 1883 [SYN] Seq=0 Win=3584 Len=0 MSS=896
    2 0.000313993  2001:db8::1 → 2001:db8::63:f7ff:fe14:8e3 TCP 80 1883 → 49153 [SYN, ACK] Seq=0 Ack=1 Win=64660 Len=0 MSS=1220
    3 0.096899823 2001:db8::63:f7ff:fe14:8e3 → 2001:db8::1  MQTT 102 Connect Command
    4 0.097272815  2001:db8::1 → 2001:db8::63:f7ff:fe14:8e3 TCP 76 1883 → 49153 [ACK] Seq=1 Ack=27 Win=64634 Len=0
    5 0.101568718  2001:db8::1 → 2001:db8::63:f7ff:fe14:8e3 MQTT 80 Connect Ack
    6 0.402768953  2001:db8::1 → 2001:db8::63:f7ff:fe14:8e3 TCP 80 [TCP Retransmission] 1883 → 49153 [PSH, ACK] Seq=1 Ack=27 Win=64634 Len=4
    7 1.012792260  2001:db8::1 → 2001:db8::63:f7ff:fe14:8e3 TCP 80 [TCP Retransmission] 1883 → 49153 [PSH, ACK] Seq=1 Ack=27 Win=64634 Len=4
    8 2.262781237  2001:db8::1 → 2001:db8::63:f7ff:fe14:8e3 TCP 80 [TCP Retransmission] 1883 → 49153 [PSH, ACK] Seq=1 Ack=27 Win=64634 Len=4
    9 4.742809773  2001:db8::1 → 2001:db8::63:f7ff:fe14:8e3 TCP 80 [TCP Retransmission] 1883 → 49153 [PSH, ACK] Seq=1 Ack=27 Win=64634 Len=4
   10 9.622823178  2001:db8::1 → 2001:db8::63:f7ff:fe14:8e3 TCP 80 [TCP Retransmission] 1883 → 49153 [PSH, ACK] Seq=1 Ack=27 Win=64634 Len=4
   11 19.702820089  2001:db8::1 → 2001:db8::63:f7ff:fe14:8e3 TCP 80 [TCP Retransmission] 1883 → 49153 [PSH, ACK] Seq=1 Ack=27 Win=64634 Len=4
   12 39.542833533  2001:db8::1 → 2001:db8::63:f7ff:fe14:8e3 TCP 80 [TCP Retransmission] 1883 → 49153 [PSH, ACK] Seq=1 Ack=27 Win=64634 Len=4
   13 78.582847983  2001:db8::1 → 2001:db8::63:f7ff:fe14:8e3 TCP 80 [TCP Retransmission] 1883 → 49153 [PSH, ACK] Seq=1 Ack=27 Win=64634 Len=4
   14 90.307113109  2001:db8::1 → 2001:db8::63:f7ff:fe14:8e3 TCP 76 1883 → 49153 [FIN, ACK] Seq=5 Ack=27 Win=64634 Len=0
However, there is no response from the nRF52DK, the UART interface shows
<info> app: Physical layer in connectable mode.
<info> app: Physical layer: connected.
<info> app: IPv6 Interface Up.
It seems that the board hangs for ever, even-though the ping6 still works fine, but no more actions with any buttons. Also tried a break point at mqtt_handle_packet() in mqtt_rx.c, but this event is never called.
== Update ==
Enabled mqtt config log (#define MQTT_CONFIG_LOG_ENABLED 1, and #define MQTT_CONFIG_LOG_LEVEL 4) and after pressing button 1 returns this
<debug> mqtt_enc: Encoding Protocol Description. Str:MQTT�0 Size:00000004.
<debug> mqtt_enc: >> pack_utf8_str USL:00000006 BL:0000007B, B:0x20004B7D, O:00000000 A:0000007B
<debug> mqtt_enc: >> pack_uint16 V:0004 BL:0000007B, B:0x20004B7D, O:00000000 A:0000007B
<debug> mqtt_enc: Encoding Protocol Version 04.
<debug> mqtt_enc: >> pack_uint8 V:04 BL:0000007B, B:0x20004B7D, O:00000006
<debug> mqtt_enc: Encoding Keep Alive Time 003C.
<debug> mqtt_enc: >> pack_uint16 V:003C BL:0000007B, B:0x20004B7<debug> mqtt_enc: >> pack_uint8 V:10 BL:00000080, B:0x20004B7B, O:00000000
<debug> mqtt_enc: >> RL:0x00000018 O:00000001 P:0x20004B7B
<debug> mqtt_enc: << RLS:0x00000001
<debug> mqtt_lwip: [0x2000C028]: TCP Write in Progress, length 0x0000001A.
<debug> mqtt_lwip: [0x2000C028]: TCP Write Complete.
And further button 1 press the function "mqtt_connect" returns error code 51460
