i2c_burst_read and i2c_burst_write not working on NRF5340
Greetings!
we are using nrf5340dk to communicate with a Nucleo shield that has LIS2DW12 accelerometer on it (shield is X-nucleo-IKS01A3). We have a problem communicating with the accelerometer as we are not getting correct sensor values.
Our setup:
Function sensor_channel_get is always returning only zero values and we can confirm this is true by the logic analyzer scans.
After some search on the Internet we found a similar issue on the DevZone here: https://devzone.nordicsemi.com/f/nordic-q-a/54451/nrf5340-support-in-nrf-connect-sdk-and-zephyr
We managed to fix the problem by going into i2c driver files for LIS2DW12 (ncs/zephyr/drivers/sensor/lis2dw12/lis2dw12_i2c.c) and replacing i2c burst functions with normal i2c functions.
Below you can see the part of the file that we changed:
static int lis2dw12_i2c_read(struct lis2dw12_data *data, uint8_t reg_addr,
				 uint8_t *value, uint16_t len)
	//return i2c_burst_read(data->bus, lis2dw12_i2c_slave_addr,
			      //reg_addr, value, len);
    return i2c_write_read(data->bus, lis2dw12_i2c_slave_addr, &reg_addr, 1, value, len);
static int lis2dw12_i2c_write(struct lis2dw12_data *data, uint8_t reg_addr,
	//return i2c_burst_write(data->bus, lis2dw12_i2c_slave_addr,
    uint8_t temp_buf[1000] = {0};
    temp_buf[0] = reg_addr;
    memcpy(&temp_buf[1], data, len);
    return i2c_write(data->bus, temp_buf, len+1, lis2dw12_i2c_slave_addr);
With above change we can communicate with the sensor. What can be done to fix the i2c burst functions, as we obviously can not use this workaround in production?
Marko
