I having issues when merging softdevice and application hex files together. If I use nrfConnect and I add the two hex files not merged (ble_app.hex and s132_nrf52_7.2.0_softdevice.hex) or if I use SES, everything works fine. The target device is nRF52832 and I am using nrf52DK board.
For merging, at first I tried to use the command
mergehex -m ble_app.hex s132_nrf52_7.2.0_softdevice.hex -o full.hex
which generates full.hex correctly, but when I load this file into nrfConnect it says:
Overlapping data around address 0x32c28
I searched on this website for a solution and I figured out I need to add "bootloader/setting" hex file, so I tried to merge all the files in this way:
nrfutil settings generate --family NRF52 --application ble_app.hex --application-version 1 --bootloader-version 1 --bl-settings-version 2 settings.hex
mergehex -m ble_app.hex settings.hex -o merged-app-settings.hex
mergehex -m merged-app-settings.hex s132_nrf52_7.2.0_softdevice.hex -o full.hex
This time nrfConnect does not complain about area overlap but I get this log and the app fails app: fds_init failed
nrfutil version 6.1.0
I am not sure about flags for nrfutil command, from my understanding I can arbitrarily choose --application-version and --bootloader-version for --bl-settings-version I set it to 2 as I am using sdk17
What is the correct procedure to make it work?
Thank you!
