app_timer_mesh, app_button, FreeRTOS and Mesh
Hi there!
Okay, we're back again... I'm using ARMGCC in combination with Make, nRF5 SDK, nRF SDK for Mesh, FreeRTOS and C++. This time I wanted to use the APP_BUTTON library to get notified when a pin changes value. This works fine. The problem, however, is that it doesn't work when compiled with Mesh.
So, to be more clear; the APP_BUTTON library works fine in combination with FreeRTOS and the app_timer_freertos.c but doesn't work at all when the app_timer_freertos.c is replaced with app_timer_mesh.c. App_button.init then returns ERROR 8 [NRF_ERROR_INVALID_STATE]. I can't figure out how to resolve it... The code underneath results in the error.
void battery_c::gpiote_init(){
    APP_ERROR_CHECK(nrf_drv_gpiote_init());
    app_button_cfg_t charge_pin_config;
    charge_pin_config.pin_no = CHARGE_PIN;
    charge_pin_config.active_state = APP_BUTTON_ACTIVE_LOW;
    charge_pin_config.pull_cfg = NRF_GPIO_PIN_PULLUP;
    charge_pin_config.button_handler = pin_event_handler;
    app_button_cfg_t standby_pin_config;
    standby_pin_config.pin_no = STANDBY_PIN;
    standby_pin_config.active_state = APP_BUTTON_ACTIVE_LOW;
    standby_pin_config.pull_cfg = NRF_GPIO_PIN_PULLUP;
    standby_pin_config.button_handler = pin_event_handler;
    static app_button_cfg_t pin_configs[] = {charge_pin_config, standby_pin_config};
    APP_ERROR_CHECK(app_button_init(pin_configs, 2, 500));
    APP_ERROR_CHECK(app_button_enable());
The question boils down to the following; is it possible to use the APP_BUTTON library while the Mesh SDK is running? If so; how? Thanks in advance!
Jochem
    Have you tried to step into the code and check which function actually returning NRF_ERROR_INVALID_STATE ?
    If it's app_timer_create() call inside the app_button_init() returned error 8 then it's because app_timer_init() should be called prior to the call to app_timer_create().
    Please refer to our example in the SDK, we usually call timer_init() before any call to the app_button.
    Btw, we have this example for mesh+ free RTOS, it may be useful for you: https://github.com/NordicPlayground/nrf-mesh-freeRTOS-example
  • Hi Hung,
    Well, now that you're saying it i'm starting to doubt wether or not I've tried adding app_timer_init() in front of it. I don't think it made a difference, but it indeed is the app_timer_create() call that's returning the error.
    I've got a hard deadline for tomorrow so don't really have time to look into it, but I definetely will in the future. I'll keep you updated.
    Oh and btw, I'm aware of the example. I took it as a guideline for the changes but am not using CMake. Thanks anyway.
    Jochem
