I'm new to Nordic tools and am stuck on getting all the pieces in place. I have:
Mac OS 10.14.6
nRF Connect v3.6.1 Getting Started Assistant
Python 3.6.3
All is well until I get to this command:
pip3 install -r nrf/scripts/requirements.txt
This fails with the following error:
Using cached sphinxcontrib-mscgen-0.5.tar.gz (10 kB)
ERROR: Command errored out with exit status 1:
command: /Library/Frameworks/Python.framework/Versions/3.6/bin/python3.6 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/private/var/folders/vs/34z554r95jq8dds6zfrx08km0000gn/T/pip-install-gocyieot/sphinxcontrib-mscgen_54acd3ed526b41f0b47a8926cfd6be5f/setup.py'"'"'; __file__='"'"'/private/var/folders/vs/34z554r95jq8dds6zfrx08km0000gn/T/pip-install-gocyieot/sphinxcontrib-mscgen_54acd3ed526b41f0b47a8926cfd6be5f/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /private/var/folders/vs/34z554r95jq8dds6zfrx08km0000gn/T/pip-pip-egg-info-zu0b17j5
cwd: /private/var/folders/vs/34z554r95jq8dds6zfrx08km0000gn/T/pip-install-gocyieot/sphinxcontrib-mscgen_54acd3ed526b41f0b47a8926cfd6be5f/
Complete output (21 lines):
File "<string>", line 1, in <module>
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/setuptools/__init__.py", line 10, in <module>
from setuptools.extern.six.moves import filter, filterfalse, map
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/setuptools/extern/__init__.py", line 1, in <module>
from pkg_resources.extern import VendorImporter
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/pkg_resources/__init__.py", line 3017, in <module>
@_call_aside
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/pkg_resources/__init__.py", line 3003, in _call_aside
f(*args, **kwargs)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/pkg_resources/__init__.py", line 3045, in _initialize_master_working_set
dist.activate(replace=False)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/pkg_resources/__init__.py", line 2577, in activate
declare_namespace(pkg)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/pkg_resources/__init__.py", line 2151, in declare_namespace
_handle_ns(packageName, path_item)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/pkg_resources/__init__.py", line 2091, in _handle_ns
_rebuild_mod_path(path, packageName, module)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/pkg_resources/__init__.py", line 2120, in _rebuild_mod_path
orig_path.sort(key=position_in_sys_path)
AttributeError: '_NamespacePath' object has no attribute 'sort'
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
I don't see anything in the forum or internet that helps so I'm stuck. Would appreciate any assistance.
ac
