I am using the nRF52832 with the s132 SoftDevice. I've been trying to interface the VL53L0X sensor to get ToF readings. I'm using the code of this driver. When calling the DataInit() and StaticInit(), they are returning a -20 (control interface error). I have checked the implementations of the functions in this driver in the i2c_platform.c (read_byte, write_multi, etc.), and they all seem to make sense, and I am not seeing where they could be wrong.
I have double checked the wiring and pin assignments between the devices, and tried it on two different devices sensors and dev kits, both of which are acting the same way.
I am using this test code to see what these control interface functions are doing:
void i2c_test(void)
int err_count = 0;
int expected_value = 0;
uint8_t buff[4] = {0x11,0x22,0x33,0x44};
uint8_t ChipID[4];
int i=0;
for (i=0; i<4; i++){ VL53L0X_read_byte(ToFDevAddr, 0xC0+i, &ChipID[i]); }
expected_value = ChipID[0]<<24 | ChipID[1]<<16 | ChipID[2]<<8 | ChipID[3];
if(rd_write_verification(0xc0, expected_value) <0) err_count++; // check the chip ID
VL53L0X_write_multi(ToFDevAddr, 0x4, buff, 4); // check WriteMulti
if(rd_write_verification(0x4, 0x11223344) <0) err_count++;
VL53L0X_write_dword(ToFDevAddr, 0x4, 0xffeeddcc); // check WrDWord
if(rd_write_verification(0x4, 0xffeeddcc) <0) err_count++;
VL53L0X_write_word(ToFDevAddr, 0x4, 0x5566); // check WrWord
VL53L0X_write_word(ToFDevAddr, 0x6, 0x7788);
if(rd_write_verification(0x4, 0x55667788) <0) err_count++;
for (i=0; i<4; i++){ VL53L0X_write_byte(ToFDevAddr, 0x04+i, &buff[i]); }
if(rd_write_verification(0x4,0x11223344) <0) err_count++;
if(err_count>0)
printf("i2c test failed - please check it\n");
int rd_write_verification( uint8_t idx, uint32_t expected_value)
uint8_t bytes[4],mbytes[4];
uint16_t words[2];
uint32_t dword;
VL53L0X_read_multi(ToFDevAddr, idx, mbytes, 4);
for (int i=0; i<4; i++){ VL53L0X_read_byte(ToFDevAddr, idx+i, &bytes[i]); }
for (int i=0; i<2; i++){ VL53L0X_read_word(ToFDevAddr, idx+i*2, &words[i]); }
VL53L0X_read_dword(ToFDevAddr, idx, &dword);
printf("expected = %08x,\n",expected_value);
printf("read_multi = %02x, %02x, %02x, %02x\n", mbytes[0],mbytes[1],mbytes[2],mbytes[3]);
printf("read_bytes = %02x, %02x, %02x, %02x\n", bytes[0],bytes[1],bytes[2],bytes[3]);
printf("read words = %04x, %04x\n",words[0],words[1]);
printf("read dword = %08x\n",dword);
if((mbytes[0]<<24 | mbytes[1]<<16 | mbytes[2]<<8 | mbytes[3]) != expected_value) return (-1);
if((bytes[0]<<24 | bytes[1]<<16 | bytes[2]<<8 | bytes[3]) != expected_value) return (-1);
if((words[0]<<16 | words[1]) != expected_value) return (-1);
if(dword != expected_value) return(-1);
return(0);
Here is what is printed out when calling this test, before the init functions mentioned above:
expected = 00000000, read_multi = 03, 00, 06, 00 read_bytes = 01, 00, 00, 00 read words = 0029, 0000 read dword = c3000000 expected = 11223344, read_multi = 03, 00, 06, 00 read_bytes = 01, 00, 00, 00 read words = 0029, 0000 read dword = c3000000 expected = ffeeddcc, read_multi = a5, da, 02, 00 read_bytes = 02, 00, 00, 00 read words = 0000, 0000 read dword = 00000004 expected = 55667788, read_multi = 6d, da, 02, 00 read_bytes = 03, 00, 00, 00 read words = 0000, 0000 read dword = 00000006 <info> app: TWI init successful
I can't figure out what could be causing these driver functions to be reading the wrong values. Any help would be appreciated, this has been a tricky problem.
Thank you!
