HARDFAULT handler call
we've got a quite unpredictable issue with a hardfault call : actually this is in this function call : app_error_fault_handler (in app_error_weak.c file)
We use SDK 17.02 and bootloader.
this is a custom board.
The issue appears when : BLE is advertising and lora data is sent (but not every time, this is a necessary but not enough condition).
We use as well timer to mange uart transfer from another device which send the data to lora, timer for ble and a timer tick.
All of these timers are created with app_timer_create() function.
Actually, as the issue is not easy to reproduce I suspect that the issue is something linked with a timing issue of one or many of this timer (it is not a code that I have developped, so not so easy to give more details).
When the issue occured, then we are in __WEAK void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info), with the following :
- id = 1  so this mean NRF_FAULT_ID_SD_ASSERT : NRF_LOG_ERROR("SOFTDEVICE: ASSERTION FAILED");
- pc = 0x00012976 ==> seems in soft device part
- info : 0
hereunder the cpu registers, sp is 0x2000fd70
hereunder the stack :
the word 0xCAFEBABE seems to be a magic number to maybe help you to debug critical issue?
the callstack is not really help me :
last, the SCB arm registers contains this : where 0xE000ED2C address contains value 0x40000000 which means in "ARMRegisteredv7-M Architecture
Reference Manual" page 612 HardFault Status Register, HFSR, Purpose Shows the cause of any HardFault.
FORCED, bit[30] Indicates that a fault with configurable priority has been escalated to a HardFault exception,
because it could not be made active, because of priority or because it was disabled:
0 No priority escalation has occurred.
1 Processor has escalated a configurable-priority exception to HardFault.
Hope I give you enough details to help me in my research to find the root cause issue.
Many thanks
Regards
Mikael
    I recently faced the same "SOFTDEVICE: ASSERTION FAILED" error when using both BLE and LoRa on an ISP4520 chip (based on nRF52832 and SX1261 chip).
    The problem came from the CRITICAL_SECTION which mask both peripheral and SoftDevice IT resulting in "SOFTDEVICE: ASSERTION FAILED".
    This is thus caused by a conflict between the BLE SoftDevice and the way LoRa is implemented in the module ISP4520. I think BLE SoftDevice and LoRa stack are not meant to be used together.
    The LoRa stack CRITICAL_SECTION should not mask SoftDevice IT. A solution is to replace:
    void BoardCriticalSectionBegin(uint32_t *mask)
        *mask = __get_PRIMASK( );
        __disable_irq( );
    void BoardCriticalSectionEnd(uint32_t *mask)
        __set_PRIMASK( *mask );
    By:
    static uint8_t __CR_NESTED = 0;
        app_util_critical_region_enter(&__CR_NESTED);
        app_util_critical_region_exit(__CR_NESTED);
    in the file board.c provided by Insight SiP for module ISP4520.
    Using that, SoftDevice IT are not masked, and SoftDevice does not fall in "SOFTDEVICE: ASSERTION FAILED".
    I hope this will help you solve your problem,
    Have a nice day,
    Aubin
  • Hi Aubin,
    Thank you very much for this valuable information !
    Actually we were working as well with ISP4520.
    We will use your solution.
    Thanks again.
    Mikael
  • Thanks you Sigurd,
    following support from Aubin is very interesting and will probably resolved my issue.
    regards
    Mikael
