Hi!
I have a custom board with a NRF52840 and some extra sensors for my application. I'm trying to comunicate with one SPI sensor but I have a little extrange behavior. I put my osciloscope on the MOSI, MISO and SCK pins and I don't have any signal on MISO and MOSI pins.
To test the hardware, I'm using the example of the SDK 17.0.2, located at \examples\peripheral\spi, with a little modifications for my board, here is my code:
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SPI_INSTANCE 0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE); /**< SPI instance. */
static volatile bool spi_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */
#define TEST_STRING "Nordic"
static uint8_t m_tx_buf[] = TEST_STRING; /**< TX buffer. */
static uint8_t m_rx_buf[sizeof(TEST_STRING) + 1]; /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf); /**< Transfer length. */
* @brief SPI user event handler.
* @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
void * p_context)
spi_xfer_done = true;
NRF_LOG_INFO("Transfer completed.");
if (m_rx_buf[0] != 0)
NRF_LOG_INFO(" Received:");
NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
//bsp_board_init(BSP_INIT_LEDS);
nrf_gpio_cfg_output(LED_1);
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin = NRF_GPIO_PIN_MAP(0, 26);
spi_config.miso_pin = NRF_GPIO_PIN_MAP(0, 8);
spi_config.mosi_pin = NRF_GPIO_PIN_MAP(0, 6);
spi_config.sck_pin = NRF_GPIO_PIN_MAP(0, 4);
APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
NRF_LOG_INFO("SPI example started.");
while (1)
// Reset rx buffer and transfer done flag
memset(m_rx_buf, 0, m_length);
spi_xfer_done = false;
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));
while (!spi_xfer_done)
__WFE();
NRF_LOG_FLUSH();
nrf_gpio_pin_toggle(LED_1);
nrf_delay_ms(200);
I'm missing some configuration?
Thanks!
