Error "Region 'SRAM' overflowed..." while testing the Bluetooth Throughput sample on nRF5340dk
I'm trying to implement the Bluetooth Throughput sample to nRF5340dk with nRF Connect SDK 1.4.1.
As mentioned in the README file, I added these three configs to the proj.conf file of the hci_rpmsg project:
CONFIG_BT_CTLR_TX_BUFFER_SIZE=251
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_RX_BUF_LEN=255
Then I get this error when I try building the hci_rpmsg project in SES:
1> Linking ‘zephyr_prebuilt.elf’
1> Memory region         Used Size  Region Size  %age Used
1>            FLASH:      170404 B       256 KB     65.00%
1>             SRAM:       69944 B        64 KB    106.73%
1> c:/users/jasonlei/ncs/v1.4.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr\zephyr_prebuilt.elf section `noinit' will not fit in region `SRAM'
1> c:/users/jasonlei/ncs/v1.4.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: section .intList VMA [21010000,21010097] overlaps section noinit VMA [2100d580,21011137]
1> c:/users/jasonlei/ncs/v1.4.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: region `SRAM' overflowed by 4408 bytes
1> collect2.exe: error: ld returned 1 exit status
1>         IDT_LIST:         152 B         2 KB      7.42%
Build failed
Is there any idea for solving this?
