S130 Device manager for both central and peripheral connection at the same time
Here is a little background.
I have been developing a product based on the S130. I used the device manager from the S120 device since version 0.9 alpha. I was able to build it and make it run and connect as central and peripheral. Running central connected to another S110 device and running as peripheral connected to MCP.
When I started to have both device connected together I started noticing problem. So two device would connect and only last device connected would receive new data. Also when the S130 is connected to the iPhone it does not retain pairing information and it alway ask to pair new device again.
It seem to me that there is very little difference int he way device manager work between central and peripheral.
Then S130 version 1.0 came out and this seem to be a know issue.
  • Device Manager is not supported in multirole S130 operation.
    • Device Manager works in peripheral or central only operation on S130. This must be decided at compile time.
So I wanted to ask the experts here a few questions regarding this before I proceed.
  • Is my assumption correct about the few key difference in central and peripheral device manager?
  • Is it at all possible to have a device manager that is able to do concurrent peripheral and central connection?
  • Assuming it is at all possible would it just be making device manager work in a way that it figures out what the connection is and act accordingly?
  • Assuming it is possible, could you give a guidance to the direction needed. Right now I am thinking:
    • Merging the files together to in one file with the functions that are different.
    • Since looking at the SDK documentation the dm_handle_t does have connection.role status. I would just have to make it so that if it is a peripheral follow the current peripheral implementation and if it is central then follow the current central implementation.
Before I starts to do anything I wanted to make sure that it is possible.
Thank you.
