Problem with compiling C++ code for nRF52820
I tried to build the ble_app_uart example for nRF52820/s140. In my project I need to use C++ modules.
My usual approach that worked so far:
  • Take an example project
  • Rename the main.c to main.cpp
  • Replace line 381-385
    ble_gap_phys_t const phys =
        .tx_phys = BLE_GAP_PHY_AUTO,
        .rx_phys = BLE_GAP_PHY_AUTO,
  • Compile with -std=gnu+11.
Oddly this doesn't work with the nRF52820 example and I always get the following error when compiling.
In file included from ../nrf5_sdk/modules/nrfx/mdk/nrf.h:192,
                 from D:\Development\wDALI2_BT_Switch\wdali-2-bt-button\firmware\ble_app_uart_pca10100e_s140\main.cpp:55:
../nrf5_sdk/modules/nrfx/mdk/compiler_abstraction.h:193:60: error: expected constructor, destructor, or type conversion before '(' token
../nrf5_sdk/modules/nrfx/mdk/compiler_abstraction.h:232:5: note: in expansion of macro 'NRF_STATIC_ASSERT'
../nrf5_sdk/modules/nrfx/mdk/nrf_erratas.h:48:1: note: in expansion of macro 'NRF_MDK_VERSION_ASSERT_AT_LEAST'
When I do the same thing with the ble_app_uart example for nRF52840/s140 it compiles just fine with C++.
Does anyone have an idea how to fix this problem and why it only occurs when compiling for nRF52820?
Thanks in advance.
  • I was able to trace the problem down to the header file nrf_gpio.h. It seems like it doesn't build with C++ for nRF52820 because of the include in line 65. But I'm not sure how to solve this properly.
    #if defined(NRF52820_XXAA)
    #include <nrf_erratas.h>
    Please search for
    extern "C"
    In your project. See how some files have this:
        #ifdef __cplusplus
             }  /* extern "C" */
          }  /* namespace std */
        #endif /* __cplusplus */
        #ifdef __cplusplus
        #ifndef __STDARG_NO_EXPORTS
          using ::std::va_list;
    Try to include that in nrf_erratas.h.
    Edvin
    thanks for your answer.
    Did you mean to put the extern "C" in nrf_erratas.h like below?
    Because I tried that and I am still getting the same error on building.
    #ifdef __cplusplus
    extern "C" {
    #ifdef __cplusplus
  • What does the nrf_erratas.h file look like now? And what error message do you get? Can you paste it even though it is the same as before?
    I don't have the C++ setup that you have. If I did, I would have tested this myself, but unfortunately, I don't.
    Edvin
  • Right now I am just using the ble_app_uart for pca10100e/s140 example (nRF5 SDK 17.0.2) with no additions other than the following to make it build with the C++ compiler.
    This is my edited nrf_erratas.h file:
    nrf_erratas.h
    This is the compilation error I get:
    ../nrf5_sdk/modules/nrfx/mdk/nrf_erratas.h:52:1: note: in expansion of macro 'NRF_MDK_VERSION_ASSERT_AT_LEAST'
