simple mqtt and mqtt publisher not working.
Hi i was trying to use simple mqtt sample provided as example with location "ncs/nrf/samples/nrf9160/mqtt_simple" the code was build and run but during lte connection it takes aroung 5-10 minutes and after that it was failed to connect with mqtt client i tried by default defined "mqtt.eclipse.org" and some other brokers but everytime gives me error
*** Booting Zephyr OS build v2.4.0-ncs1  ***The MQTT simple sample startedLTE Link Connecting ...+CEREG: 2,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"+CEREG: 0,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"+CEREG: 2,"00D8","003AC006",9,0,0,"11100000","11100000"+CSCON: 1+CEREG: 5,"00D8","003AC006",9,,,"11100000","11100000"LTE Link Connected!IPv4 Address found 198.41.30.194ERROR: mqtt_connect -60
i search for the error it was showing timeout error but doen't help me as i didn't find to resolve it.
after this i was also trying the other sample code mqtt publisher at location "zephyr/samples/net/mqtt_publisher". the code build and programmed but after that device rebooting again and again with following error
Non-secure callable region 0 placed in flash region 0 with size 32.
can you please guide me for the mqtt code. as my requirent is to publish some messages on server after regular time intervals and how to make it faster connect with lte. please reply asap.
  • i followed the thread Nordic DevZone (nordicsemi.com) and make some changes but still here is the output log. still not working.
    SPM: prepare to jump to Non-Secure image.*** Booting Zephyr OS build v2.4.0-ncs1  ***The MQTT simple sample startedLTE Link Connecting ...+CEREG: 2,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"+CEREG: 0,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"[00:10:00.264,678] [0m<inf> lte_lc: Network connection attempt timed out[0m[00:10:00.279,418] [0m<inf> lte_lc: Using fallback network mode[0m+CEREG: 2,"00D8","003AC006",9,0,0,"11100000","11100000"+CSCON: 1+CEREG: 5,"00D8","003AC006",9,,,"11100000","11100000"LTE Link Connected!IPv4 Address found 198.41.30.194[00:10:25.039,001] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:10:48.543,548] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:11:12.547,851] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:11:36.553,283] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:12:00.558,868] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:12:24.564,422] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:12:48.568,145] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:13:12.572,570] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:13:36.577,026] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:14:00.582,702] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:14:24.588,134] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:14:48.591,674] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:15:12.596,130] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:15:36.602,539] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:16:00.607,055] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:16:24.611,572] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:16:48.617,187] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:17:12.622,009] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1[0mERROR: mqtt_connect -60[00:17:36.628,509] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20020560): Created socket 1
    you can print out more detailed debug information with these to lines in prj.conf,
    CONFIG_NET_LOG=y
    CONFIG_MQTT_LOG_LEVEL_DBG=y
  • already done ang logs were shared before and i am sharing again as below
    ***Flash regionsDomainPermissions00 00 0x00000 0x08000
    Securerwxl01 31 0x08000 0x100000 Non-SecurerwxlNon-secure callable region 0 placed in flash region 0 with size 32.SRAM region
    DomainPermissions00 07 0x00000 0x10000 Securerwxl08 31 0x10000 0x40000 Non-SecurerwxlPeripheralDomainStatus
    00 NRF_P0               Non-SecureOK01 NRF_CLOCK            Non-SecureOK02 NRF_RTC0
    Non-SecureOK03 NRF_RTC1             Non-SecureOK04 NRF_NVMC
    Non-SecureOK05 NRF_UARTE1           Non-SecureOK06 NRF_UARTE2
    SecureSKIP07 NRF_TWIM2            Non-SecureOK08 NRF_SPIM3
    Non-SecureOK09 NRF_TIMER0           Non-SecureOK10 NRF_TIMER1
    Non-SecureOK11 NRF_TIMER2           Non-SecureOK12 NRF_SAADC
    Non-SecureOK13 NRF_PWM0             Non-SecureOK14 NRF_PWM1
    Non-SecureOK15 NRF_PWM2             Non-SecureOK16 NRF_PWM3
    Non-SecureOK17 NRF_WDT              Non-SecureOK18 NRF_IPC
    Non-SecureOK19 NRF_VMC              Non-SecureOK20 NRF_FPU
    Non-SecureOK21 NRF_EGU1             Non-SecureOK22 NRF_EGU2
    Non-SecureOK23 NRF_DPPIC            Non-SecureOK24 NRF_GPIOTE1
    Non-SecureOK25 NRF_REGULATORS       Non-SecureOK
    SPM: NS image at 0xc000SPM: NS MSP at 0x20025cf0
    SPM: NS reset vector at 0x102fd
    [00:10:00.264,862] [0m<inf> lte_lc: Network connection attempt timed out[0m[00:10:00.277,221]
    [0m+CEREG: 2,"C0D8","003AC006",9,0,0,"11100000","11100000"+CSCON: 1
    +CEREG: 5,"C0D8","003AC006",9,,,"11100000","11100000"
    LTE Link Connected!
    attempting to connect: IPv4 Address found 64.111.109.81
    [00:10:28.337,097] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20023010): Created socket 1
    [0mmqtt_connect -60IPv4 Address found 64.111.109.81
    [00:10:52.344,268] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20023010): Created socket 1
    [00:11:16.852,569]
    [00:11:41.359,893] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20023010): Created socket 1
    [00:12:05.866,271] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20023010): Created socket 1
    [00:12:30.374,389] [0m<dbg> net_mqtt_sock_tcp.mqtt_client_tcp_connect: (0x20023010): Created socket 1
  • The log says "lte_lc: Using fallback network mode". What is the fallback network mode set to?
