Cannot implement LOG to my software
Hi, i am trying to understand the SDK 17 by building my own libraries such as interrupts, ADC, IIC or so on. I was doing well untill i come across with "LOG". When i look at the examples that uses LOG, sdk_config files are different so i cannot merge them. I just want an application that writes "DEBUG" every 1 seconds. I will build the library from it. I have added my code that converted from example named "temperature". I just deleted the code inside and implemented 2 interrupt service.1780.sdk_config.h
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "nrf.h"
#include "nrf_delay.h"
#include "app_error.h"
#include "bsp.h"
#include "nrf_gpiote.h"
#include "nrf_gpio.h"
#include "boards.h"
#include "nrf_drv_gpiote.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define OUT1 BSP_LED_0
#define OUT2 BSP_LED_1
#define IN1 BSP_BUTTON_0
#define IN2 BSP_BUTTON_1
void fonksiyon1(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action){
	nrf_drv_gpiote_out_toggle(OUT1);
	NRF_LOG_INFO("Button 1 Pressed");
void fonksiyon2(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action){
	nrf_drv_gpiote_out_toggle(OUT2);
	NRF_LOG_INFO("Button 2 Pressed");
static void interrupt_setup()
    ret_code_t err_code;
		nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
		out_config.init_state = NRF_GPIOTE_INITIAL_VALUE_HIGH;
    err_code = nrf_drv_gpiote_out_init(OUT1, &out_config);
    err_code = nrf_drv_gpiote_out_init(OUT2, &out_config);
    nrf_drv_gpiote_in_config_t config = GPIOTE_CONFIG_IN_SENSE_HITOLO(false);
	  config.pull = NRF_GPIO_PIN_PULLUP;
    err_code = nrf_drv_gpiote_in_init(IN1, &config, fonksiyon1);
		err_code = nrf_drv_gpiote_in_init(IN2, &config, fonksiyon2);
		nrf_drv_gpiote_in_event_enable(IN1,true);
		nrf_drv_gpiote_in_event_enable(IN2,true);
		interrupt_setup();
    NRF_LOG_INFO("Debug Started");
    while (true)
        for (int i = 0; i < LEDS_NUMBER; i++)
            bsp_board_led_invert(i);
            nrf_delay_ms(500);
						NRF_LOG_INFO("Debug Loop");
