Is this a bug in 'nrf_crypto_hash.c'
I have been trying to bring up a secure boot loader for our product based on the nRF52832 SoC.
I have reviewed three SDK versions (17.0.2, 16.0.0, 15.3.0) and observe the same misleading 'WARNING' when compiling the file 'components/libraries/crypto/nrf_crypto_hash.c'
// Internal allocation of context not available for CC310_BL in order to save code size.
#if defined(NRF_CRYPTO_BACKEND_CC310_BL_HASH_SHA256_ENABLED) && (NRF_CRYPTO_BACKEND_CC310_BL_HASH_SHA256_ENABLED == 1)
    // Do nothing
#elif defined(NRF_CRYPTO_BACKEND_CC310_BL_HASH_SHA256_ENABLED) && (NRF_CRYPTO_BACKEND_CC310_BL_HASH_SHA256_ENABLED == 0)
    // Validate input. Only validate input parameters that are used locally, others are validated
    // in the init, update and/or finalize functions.
    VERIFY_TRUE(p_info != NULL, NRF_ERROR_CRYPTO_INPUT_NULL);
    // Allocate context if needed (not provided by the user).
    if (p_context == NULL)
        p_allocated_context = NRF_CRYPTO_ALLOC(p_info->context_size);
        if (p_allocated_context == NULL)
            return NRF_ERROR_CRYPTO_ALLOC_FAILED;
        p_ctx = (nrf_crypto_hash_context_t *)p_allocated_context;
#else
    #warning NRF_CRYPTO_BACKEND_CC310_BL_HASH_SHA256_ENABLED define not found in sdk_config.h (Is the sdk_config.h valid?).
#endif // NRF_CRYPTO_BACKEND_CC310_BL_HASH_SHA256_ENABLED
I think this is not right -- there is NO CC310 component in the nRF52832 device and this warning is absolutely misleading -- I lost quite a few hours trying to see why my
specific configuration was generating this --- when all along I suspect it is wrong code released in this SDK.
Cheers
RMV
    This file is not specific for nRF52832, it is also used in nRF52840, where the CC310 backend is available, and needs to be configured/allocated correctly.
    However, I agree that this could have been excluded for chips that does not have the Cryptocell module, for instance by an #if defined() using CRYPTOCELL_PRESENT symbol:
    #if defined(CRYPTOCELL_PRESENT)
        // Do nothing
    #else
    #endif // CRYPTOCELL_PRESENT
    Jørgen
  • Thanks for the clarification. I will mark this as answered.
    Cheers
    RMV
