ANT Data transmit with maximum power using BT840XE module
nRF SDK: 16.0, Device: nRF52840, module: BTX480XE, softdevice: ANT_s340_nrf52840_6.1.1.hex
The setup:
BLE and ANT running on same device concurrently. The device is modified Nordic UART example code, added with one master and one slave ANT channels. The code constantly broadcasts data every 100ms on Tx channel. I can receive the data packets on on ANTWAREII PC application.  There is no code compile issue.
The goal:
We want to get maximum TX/RX range from the BTX480XE module by using it's power amplifier hardware.
The issue:
The code stops sending broadcast data as soon pa_lna_init() is called in the (main.c:1165). This piece of code is using Pin 6,8,17,19 in the Fanstel module to control power amplifier.
Solutions tried:
Checked pin conflict of pin#s 6,8,17,19 in the code
Check PPI, GPIOTE and related peripherals are initialized in the code.
Attached the power amplifier initialization and driver code files for reference.
pa_init_driver.rar
  • Hi, I have changed the UART pins (6,8 were being used). The PA/LNA pins are inside the module, basically nRF52840 and LNA chip are packaged into single enclosed module. So I have no access to these pins. I have also tried disabling the UART. Also changed the RTT TX pin. Nothing works.
  • This is how I receive the data on ANTWAREII software:
    Received BROADCAST_DATA_0x4E
      :: 4e, 00-01-01-00-00-00-00-00-00
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    It seems the TXR sends data but it somehow gets corrupted. Only a few packets reach the RXR.
  • I tried this code mentioned in the ANT forum: www.thisisant.com/.../
    uint32_t err_code = sd_ant_config_pa_lna_get(&pstAmpConfig);
        pstAmpConfig.PA_CONFIG.bEnabled = 1;
        pstAmpConfig.PA_CONFIG.bActiveState = 1;
        pstAmpConfig.PA_CONFIG.ucGPIO = APP_PA_PIN;
        pstAmpConfig.LNA_CONFIG.bEnabled = 1;
        pstAmpConfig.LNA_CONFIG.bActiveState = 1;
        pstAmpConfig.LNA_CONFIG.ucGPIO = APP_LNA_PIN;
        nrf_ppi_channel_t ppi_set_ch;
        nrf_ppi_channel_t ppi_clr_ch;
        pstAmpConfig.ucGPIOTECh = 1;//nGpioTeChannelNum;
        pstAmpConfig.ucPPIChDisable = ppi_clr_ch; // 0 Value
        pstAmpConfig.ucPPIChEnable = ppi_set_ch; // 1 Value
        err_code = sd_ant_config_pa_lna_set(&pstAmpConfig);
    The result is this data received:
    > Opening Channel...
      :: 4e, 00-02-01-00-00-00-00-00-00
      :: 4e, 00-03-01-00-00-00-00-00-00
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    EVENT_RX_FAIL_0x02
      :: 40, 00-01-02
    Closing Channel...
    EVENT_CHANNEL_CLOSED_0x07
      :: 40, 00-01-07
    But I'm not sure if it actually increased the physical range or LNA simply failed to initialize. I need to test physical range to verify this.
  • It looks like this is working now, it should be possible to do some sanity check by testing line of sight range with and without pa/lna configured, also I suggest that you connect a logic analyzer trace to verify that PA and LNA pins toggles as expected. I also recommend that you try to use ANT continuous scanning mode in ANTwareII, because lost packets may also be due to inaccuracy of timing between master and slave (e.g. make sure you have configured the external 32kHz to be used when init the softdevice stack).
    For best range I assume you should use BT840XE in both ends of the link.
    Kenneth
  • Yes this solution seems to be working, the only change I had to do was:
    pstAmpConfig.ucPPIChDisable = 0; //ppi_clr_ch; // 0 Value
    pstAmpConfig.ucPPIChEnable = 1; //ppi_set_ch; // 1 Value
    in above code. Otherwise stack give error 7 (invalid parameter).
    Now I need to work on packet reliability. Many thanks for the support.
