nRF SDK: 16.0, Device: nRF52840, module: BTX480XE, softdevice: ANT_s340_nrf52840_6.1.1.hex
The setup:
BLE and ANT running on same device concurrently. The device is modified Nordic UART example code, added with one master and one slave ANT channels. The code constantly broadcasts data every 100ms on Tx channel. I can receive the data packets on on ANTWAREII PC application. There is no code compile issue.
The goal:
We want to get maximum TX/RX range from the BTX480XE module by using it's power amplifier hardware.
The issue:
The code stops sending broadcast data as soon pa_lna_init() is called in the (main.c:1165). This piece of code is using Pin 6,8,17,19 in the Fanstel module to control power amplifier.
Solutions tried:
Checked pin conflict of pin#s 6,8,17,19 in the code
Check PPI, GPIOTE and related peripherals are initialized in the code.
Attached the power amplifier initialization and driver code files for reference.
