Hello, I was successful in using Arduino headers/ libraries to program my nRF52 DK, but now I am attempting to recreate the project in Segger V5.34 for MacOS for potential mass production. I am using the ble_app_template example from the nRF52 SDK 17.0.2 and I am following this tutorial. (The only deviation was that I named the variables differently) I was on Step 4 before issues arrived. However, when I build and run everything, nothing is advertised. I also wanted to add that I am new to Segger, but I understand C pretty well. I have already flashed the S132 SoftDevice (At least, I'm pretty sure) This nRF52 DK was advertising perfectly fine when I used Arduino, so the board works. There just seems to be an issue with my code or configurations, because when I hit 'Build and Run' the board is on but nothing happens. It's also worth mentioning that the PWM examples work perfectly fine. Thank you for all the examples, by the way. They're very helpful. Thanks in advance!
from main.src
bool erase_bonds;
// Initialize.
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init(); //Services comes first, just like the tutorial
advertising_init();
conn_params_init();
peer_manager_init();
// Start execution.
NRF_LOG_INFO("Template example started.");
application_timers_start();
advertising_start(erase_bonds);
NRF_LOG_INFO("Lig started.");
// Enter main loop.
for (;;)
idle_state_handle();
ble_cus.h
// from ble_cus.c
#include "sdk_common.h"
#include "ble_srv_common.h"
#include "ble_cus.h"
#include <string.h>
#include "nrf_gpio.h"
#include "boards.h"
#include "nrf_log.h"
/**@brief Function for initializing the Custom Service.
* @param[out] p_cus Custom Service structure. This structure will have to be supplied by
* the application. It will be initialized by this function, and will later
* be used to identify this particular service instance.
* @param[in] p_cus_init Information needed to initialize the service.
* @return NRF_SUCCESS on successful initialization of service, otherwise an error code.
uint32_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init);
/**@brief Function for adding the Custom Value characteristic.
* @param[in] p_cus Custom Service structure.
* @return NRF_SUCCESS on success, otherwise an error code.
static uint32_t LED_char_add(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
uint32_t err_code;
ble_gatts_char_md_t char_md;
ble_gatts_attr_md_t cccd_md;
ble_gatts_attr_t attr_char_value;
ble_uuid_t ble_uuid;
ble_gatts_attr_md_t attr_md;
memset(&char_md, 0, sizeof(char_md));
char_md.char_props.read = 1;
char_md.char_props.write = 1;
char_md.char_props.notify = 0;
char_md.p_char_user_desc = NULL;
char_md.p_char_pf = NULL;
char_md.p_user_desc_md = NULL;
char_md.p_cccd_md = NULL;
char_md.p_sccd_md = NULL;
memset(&attr_md, 0, sizeof(attr_md));
attr_md.read_perm = p_cus_init->LED_char_attr_md.read_perm;
attr_md.write_perm = p_cus_init->LED_char_attr_md.write_perm;
attr_md.vloc = BLE_GATTS_VLOC_STACK;
attr_md.rd_auth = 0;
attr_md.wr_auth = 0;
attr_md.vlen = 0;
ble_uuid.type = p_cus->uuid_type;
ble_uuid.uuid = LedCharUUID;
memset(&attr_char_value, 0, sizeof(attr_char_value));
attr_char_value.p_uuid = &ble_uuid;
attr_char_value.p_attr_md = &attr_md;
attr_char_value.init_len = sizeof(uint8_t);
attr_char_value.init_offs = 0;
attr_char_value.max_len = sizeof(uint8_t);
err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md,
&attr_char_value,
&p_cus->LED_value_handles);
if (err_code != NRF_SUCCESS)
return err_code;
return NRF_SUCCESS;
if (p_cus == NULL || p_cus_init == NULL)
return NRF_ERROR_NULL;
uint32_t err_code;
//Initialize service structure
p_cus->conn_handle = BLE_CONN_HANDLE_INVALID;
ble_uuid128_t base_uuid = {LigService_UUID_BASE};
err_code = sd_ble_uuid_vs_add(&base_uuid, &p_cus->uuid_type);
VERIFY_SUCCESS(err_code);
ble_uuid.uuid = LigServiceUUID;
err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_cus->service_handle);
return err_code;
//Add custom characteristic
return LED_char_add(p_cus, p_cus_init);
ble_cus.c
//From ble_cus.h
#include <stdint.h>
#include <stdbool.h>
#include "ble.h"
#define LigService_UUID_BASE {0xBC, 0x8A, 0xBF, 0x45, 0xCA, 0x05, 0x50, 0xBA, \
0x40, 0x42, 0xB0, 0x00, 0xC9, 0xAD, 0x64, 0xF3}
#define LigServiceUUID 0x1400
#define LedCharUUID 0x1401
//#define ColorCharUUID 0x1402
/**@brief Macro for defining a ble_cus instance.
* @param _name Name of the instance.
* @hideinitializer
#define BLE_CUS_DEF(_name) \
static ble_cus_t _name;
/**@brief Custom Service init structure. This contains all options and data needed for
* initialization of the service.*/
typedef struct
uint8_t initial_LED_value; /**< Initial custom value */
ble_srv_cccd_security_mode_t LED_char_attr_md; /**< Initial security level for Custom characteristics attribute */
} ble_cus_init_t;
/**@brief Custom Service structure. This contains various status information for the service. */
struct ble_cus_s
uint16_t service_handle; /**< Handle of Custom Service (as provided by the BLE stack). */
ble_gatts_char_handles_t LED_value_handles; /**< Handles related to the Custom Value characteristic. */
uint16_t conn_handle; /**< Handle of the current connection (as provided by the BLE stack, is BLE_CONN_HANDLE_INVALID if not in a connection). */
uint8_t uuid_type;
// Forward declaration of the ble_cus_t type.
typedef struct ble_cus_s ble_cus_t;
services_init() in main.c
/* YOUR_JOB: Add code to initialize the services used by the application.*/
ret_code_t err_code;
ble_cus_init_t cus_init;
// Initialize CUS Service init structure to zero.
memset(&cus_init, 0, sizeof(cus_init));
err_code = ble_cus_init(&m_cus, &cus_init);
