Hi, Got stuck on an issue that has come and gone and then working fine, and are now back again.
I use a nrf51 module with the led-button-service example (sdk 5.2). It's not using bondmgr, just scan for known or recently connected peripherals. I modified the example to have 4 characteristics and to wakeup each 60 seconds to sample ADC values. In the timer event I call start advertise, which is set to 6 seconds. After update-notify two of the characteristics value I disconnect from iOS (stop notifyValue on chars and cancel connection). I am using the iOS connect functions to restore state and connectPeripheral so it get started even i background mode.
Is there anything obvious I am missing?, I can see that the peripheral reconnects direct after I cancelConnection in iOS, and the only clue I got is that it does that for the same amount of time I have set the Advertising inteval to, in this case 6s.
Does the softdevice still advertise for connection attempt after it has passed the connected state? I have tried to stop advertise sd_ble_gap_stop(), but then it will not connect next time.
Thanks in advance!
