I referred to the following sample.
\ncs\v1.4.2\zephyr\samples\subsys\nvs\src\main.c
void main(void)
int rc = 0, cnt = 0, cnt_his = 0;
char buf[16];
uint8_t key[8], longarray[128];
uint32_t reboot_counter = 0U, reboot_counter_his;
struct flash_pages_info info;
/* define the nvs file system by settings with:
* sector_size equal to the pagesize,
* 3 sectors
* starting at FLASH_AREA_OFFSET(storage)
fs.offset = FLASH_AREA_OFFSET(storage);
rc = flash_get_page_info_by_offs(
device_get_binding(DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL),
fs.offset, &info);
if (rc) {
printk("Unable to get page info");
fs.sector_size = info.size;
fs.sector_count = 3U;
rc = nvs_init(&fs, DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL);
if (rc) {
printk("Flash Init failed\n");
/* ADDRESS_ID is used to store an address, lets see if we can
* read it from flash, since we don't know the size read the
* maximum possible
rc = nvs_read(&fs, ADDRESS_ID, &buf, sizeof(buf)); <------ (A)
if (rc > 0) { /* item was found, show it */
printk("Id: %d, Address: %s\n", ADDRESS_ID, buf);
} else {/* item was not found, add it */
strcpy(buf, "192.168.1.1");
printk("No address found, adding %s at id %d\n", buf,
ADDRESS_ID);
(void)nvs_write(&fs, ADDRESS_ID, &buf, strlen(buf)+1); <------ (B)
I went down the system at the point (A), so I fixed it.
&buf --> buf
(B) was fix as well, but the system goes down.
sdc_soc_flash_write_async to the point where it is falling in the function.
The attachment is stuck at 0x0000466E, but the next time you go with F10, the system goes down.
