Hi, I am wroking on nRF52840 Evaluation board where I am using p0.16 and p0.17 as SDA and SCL respectively using I2c mechanism and trying to read the device id, but it seems to be not working as i am getting the output as no device found?
#if TWI0_ENABLED
#define TWI_INSTANCE_ID 0
#elif TWI1_ENABLED
#define TWI_INSTANCE_ID 1
/* Number of possible TWI addresses. */
#define TWI_ADDRESSES 127
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
* @brief TWI initialization.
void twi_init (void)
ret_code_t err_code;
const nrf_drv_twi_config_t twi_config = {
.scl =  NRF_GPIO_PIN_MAP(0,17),
.sda = NRF_GPIO_PIN_MAP(0,16),
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
nrf_drv_twi_enable(&m_twi);
uint8_t address;
uint8_t sample_data;
bool detected_device = false;
NRF_LOG_INFO("TWI scanner started.");
NRF_LOG_FLUSH();
twi_init();
for (address = 1; address <= TWI_ADDRESSES; address++)
err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data));
if (err_code == NRF_SUCCESS)
detected_device = true;
NRF_LOG_INFO("TWI device detected at address 0x%x.", address);
NRF_LOG_FLUSH();
if (!detected_device)
NRF_LOG_INFO("No device was found.");
NRF_LOG_FLUSH();
