32MHz SPI Reducing Drive Strength
I am using the SPI at 32MHz. I would like to add 0R series resistors to the SPI lines so that I have the option to add a 10R or so to mitigate any emissions or immunity problems during CE testing. However, I do not have much spare space with our PCB size constraints.
I believe that reducing the drive strength may provide me with the same capability as the additional resistors. However, I am unsure if this will affect functionality of the SPI.
I know you recommend using high drive when using SPI at 32Mhz. Is this just a recommendation or is this essential? Should I avoid this as a solution?
Thanks for your help!
