nrfx_nvmc_page_erase causes NRF_FAULT_ID_SD_ASSERT
My issue seems to be similar to DRGN-12539.  However, I am erasing internal flash.
I am calling in a loop nrfx_nvmc_page_erase to erase multiple pages of flash.  At first, I erase all the required pages at once
ret_code_t erase(uint32_t startAddress, uint32_t pageCount)
  for (uint32_t i = 0; i < pageCount; i++)
    VERIFY_SUCCESS(nrfx_nvmc_page_erase(startAddress + (i * NVM_PAGE_SIZE)));
  return NRF_SUCCESS;
I change it to use an app timer that will only erase one page at a time.
#define START_ADDRESS (0x00060000)
#define PAGE_COUNT 5
#define NVM_PAGE_SIZE (4096) // Bytes in one page
APP_TIMER_DEF(m_erase_timer);
static uint32_t m_erase_page_offest = 0;
static void erase_page(void *p_context)
  UNUSED_VARIABLE(p_context);
  if (m_erase_page_offest < PAGE_COUNT)
    uint32_t address = START_ADDRESS + (m_erase_page_offest * NVM_PAGE_SIZE);
    ret_code_t err_code = erase(address, 1);
    m_erase_page_offest++;
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module.
static void timers_init(void)
  // Initialize timer module, making it use the scheduler
  app_timer_create(&m_erase_timer, APP_TIMER_MODE_REPEATED, erase_page);
/**@brief Function for application main entry.
  ret_code_t err_code;
  timers_init();
  err_code = app_timer_start(m_erase_timer, APP_TIMER_TICKS(1000), NULL);
  for (;;)
      nrf_pwr_mgmt_run();
In both case, I will get a NRF_FAULT_ID_SD_ASSERT during the process.  It varies on which page it ultimately triggers the failure.
I'm using S112 v7.2.0 on NRF52832
