Reading JEDEC ID External Flash
 I have an external flash w25q32 spi nor flash. I tried to communicate with my flash using spi_nor driver code in zephery however it didn't detect the external flash saying "flash driver was not found" .The device get binding was returning false. Then I tried to just read the jedec id with spi_transceive. I am sending 9F command and dummy bytes to detect the jedec id however still I am not able to get the jedec id. You can see the logic analyzer output attached. The jedec id  has to be ef 40 16.
My main.c is:
 * Copyright (c) 2012-2014 Wind River Systems, Inc.
#include <zephyr.h>
#include <sys/printk.h>
#include <drivers/spi.h>
//addition for combining blinky
static struct spi_config spi_cfg = {
  .operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB |
  SPI_MODE_CPOL | SPI_MODE_CPHA,
  .frequency = 4000000,
  .slave = 0,
struct device * spi_dev;
static void spi_init(void) {
    const char *
      const spiName = "SPI_3";
    spi_dev = device_get_binding(spiName);
    if (spi_dev == NULL) {
      printk("Could not get %s device\n", spiName);
      return;
void spi_test_send(void) {
  int err;
  //static u8_t tx_buffer[1];
  //static u8_t rx_buffer[1];
  static u8_t tx_buffer[5] = {
	0X9F,
        0x00,
        0x00,
        0x00,
        0x00
  static u8_t rx_buffer[5];
  const struct spi_buf tx_buf = {
	.buf = tx_buffer,
	.len = sizeof(tx_buffer)
  const struct spi_buf_set tx = {
	.buffers = & tx_buf,
	.count = 1
  struct spi_buf rx_buf = {
	.buf = rx_buffer,
	.len = sizeof(rx_buffer),
  const struct spi_buf_set rx = {
	.buffers = & rx_buf,
	.count = 1
  struct device * gpio_dev;
  struct spi_cs_control cs_control;
  gpio_dev = device_get_binding("GPIO_0");
  if (!gpio_dev) {
	printk("could not find GPIO device\n");
	return;
  gpio_pin_configure(gpio_dev,13,GPIO_OUTPUT_ACTIVE);
  gpio_pin_set(gpio_dev,13,0);
  err = spi_transceive(spi_dev, & spi_cfg, & tx, & rx);
  gpio_pin_set(gpio_dev,13,1);
  if (err) {
	printk("SPI error: %d\n", err);
  } else {
	/* Connect MISO to MOSI for loopback */
	for (int i = 0; i < sizeof(tx_buffer); i++) {
	  printk("TX transmit: %x\n", tx_buffer[i]);
	for (int i = 0; i <sizeof(rx_buffer); i++) {
	  printk("RX recv: %x\n", rx_buffer[i]);
void main(void) {
  printk("SPIM Example\n");
  spi_init();
  printk("After init\n");
  while (1) {
	spi_test_send();
	k_sleep(K_MSEC(10));
	printk(".");
my overlay is:
&spi3 {
	status = "okay";
	sck-pin = <10>;
	mosi-pin = <11>;
	miso-pin = <12>;
    //cs-gpios = <&gpio0 13 0>;
My proj.conf:
CONFIG_SPI=y
CONFIG_MAIN_STACK_SIZE=4096
# CONFIG_SPI_0=y
# UART, SPIM, and I2C are shared peripherals on nrf9160
# therefore we choose SPI3
CONFIG_SPI_3=y
CONFIG_SPI_NRFX=y
CONFIG_DEPRECATED_ZEPHYR_INT_TYPES=y
#addition for combining blinky
CONFIG_GPIO=y
The logic analyzer output is:
Can you help me with this issue. I couldn't understand why it is not working for detecting jedec id. Any help would be so helpful.
Thank you
