sending ASCII bytes through Mesh between a nrf52840 development kit and two dongle
Hello everyone,
I am new and tried some example on the nrf52840 devkit and dongle, including light switch example.
I am now going to send some ASCII bytes through the mesh between three boards and receive a verification message in the client side.
Actually I thought this is done by adding  sent and receive functions in the switch light example (server and client) inside the main.c. But after searching the devzone I was completely confused.
I read these discussions but I could not modify the code correctly.
https://devzone.nordicsemi.com/f/nordic-q-a/29836/send-and-receive-a-string-via-access-layer
https://devzone.nordicsemi.com/f/nordic-q-a/31256/receiving-simple-message-mesh/123576
https://devzone.nordicsemi.com/f/nordic-q-a/39629/how-to-send-data-to-all-node-over-mesh
https://devzone.nordicsemi.com/f/nordic-q-a/47611/sending-data-over-the-mesh-network
https://devzone.nordicsemi.com/f/nordic-q-a/46092/send-string-in-a-mesh-with-nrf52dk/
I have error on
simple_message_OPCODE_SEND
and
the address_set function
and also in the server side:
status= access_model_publish(m_server.model_handle, &msg);
I think there are some different in the new version of the nRF52 SDK for mesh V.5 I used.
Could you please help me on this topic.
Thank you,
Sama
    1. Have you made any changes to the project? You are using the nRF Mesh to provision the devices, bind the models to appkey and set the publish address, correct? I don't see this on my side.
    2. Any packet with size larger than 11 bytes (including header) will be split into segmented messages automatically. But the maximum possible segmented payload size is 380 so it will fail if you have a higher payload. Note that Mesh is not optimal for sending/streaming a lot of data.
    3. Yes, you can send data to a specific node by publishing to their unicast address. You can do this in the nRF Mesh app.
