How to publish GPS informations to Azure IoT Hub?
I've got a Thingy:91, which I've spent a lot of hours in understanding the different samples. I want to be able to send GPS information to my Azure IoT hub device, but I can't seem to figure out how to do that??? I want to be able to set a interval in the "device twin" on my cloud, which the device should publish GPS information to my cloud in.
I have programmed the Azure IoT Hub sample and run it succesfully, where the event is triggered in a specific time interval, I can change in the devices "device twin" on my cloud. It all works. Furthermore, I run the GPS sample succesfully. I thought the way to go is to merge those two samples, but I don't know how? I think these files from both samples should be merged, but i'm not quite sure how:
  • Kconfig
  • prj.conf
  • sample.yaml
  • main.c
I've read other tickets in here, but none of them is about Azure IoT Hub. I'm using NB-IoT and I know the modem can not run GPS and LTE-NB simultaneously, but I don't know how to switch between those in the given interval. :-)
I hope somone can be helpful. I appreciate any help :-)
Thanks, Regards
Frederik
    • Kconfig
    • prj.conf
    • sample.yaml
    • main.c
    There is no kconfig file in the Azure IoT hub sample, so you don't need to worry about that.
    With prj.conf, you can probably just copy and paste the options from one sample to the other, except for the duplicate ones.
    You don't need to worry about sample.yaml I believe.
    With main.c I think it shouldn't be too hard. You can probably just use the azure_iot_hub_send() to send the GPS data in the process_gps_data() function every time GPS data is received. Perhaps the best way to go about it is to start with the GPS sample code, and add the Azure IoT code on top of it.
     Where do you have this from?
  • Hi Hakon,
    I've just read other tickets about using GPS with AWS, where the modem can't be configured to use GPS and run LTE at the same time. When I'm running the GPS sample with SUPL, the LTE is turned on and after receiving data over LTE, it turns off in order to get GPS data. I'm not sure about this, and I might be mistaken.
    In order to merge GPS and Azure_IoT_Hub sample together, how do I configure the modem, or does it have to be configured repeatedly respectively for GPS and LTE?
  • Have you enabled PSM? You need to enable PSM in the modem if you want to run LTE and GPS concurrently.
