SPI MOSI pulldown resistor
I'm working on an application with SD card, and I've noticed what I think is strange behavior on MOSI.  SD has pullup on every pin (10k), per the spec.  Whichever pin I choose as MOSI floats to around 1.7V on SPI initialization, and can't pull the signal high or low after that.  At first I thought maybe it was my hardware, but then I accidentally messed up which pin I was using and saw the same behavior on the CLK line when I accidentally chose it as MOSI.  I'm using the nRF52840-DK and an SD card (actually a micro SD card) module that I can move around the board.  I've tried a wide variety of pins and they all show the same behavior.  Tried it with a card in the reader or no card in the reader, same behavior.  I checked the pins on the SD module and they all show the right resistance values.  All other pins pull high or low accordingly, as expected, regardless of what pins I choose.  I suspect I'm doing something silly, but I can't imagine what it is...  Is there some pulldown value on the line selected on MOSI?  I suspect no since the pin also can't drive a signal, but I'm not sure what else to look at and I see no errata.  Is 10k pullup too low or something?
Here's some code (SDK 17.0.2) for completeness:
const nrfx_spim_t m_spim3 = NRFX_SPIM_INSTANCE(3);
int main()
    nrfx_spim_config_t spim_cfg = NRFX_SPIM_DEFAULT_CONFIG;
    ret_code_t error;
    nrfx_spim_xfer_desc_t desc;
    uint8_t tx_buff[6];
    uint8_t rx_buff[8];
    spim_cfg.frequency  = NRF_SPIM_FREQ_1M;
    spim_cfg.ss_pin     = NRF_GPIO_PIN_MAP(1, 04);
    spim_cfg.sck_pin    = NRF_GPIO_PIN_MAP(1, 02);
    spim_cfg.mosi_pin   = NRF_GPIO_PIN_MAP(1, 03);
    spim_cfg.miso_pin   = NRF_GPIO_PIN_MAP(1, 01);
    spim_cfg.mode       = NRF_SPIM_MODE_0;
    spim_cfg.use_hw_ss  = true;
    error = nrfx_spim_init(&m_spim3, &spim_cfg, NULL, NULL);
    APP_ERROR_CHECK(error);
    // SD CMD0
    tx_buff[0] = 0x40;
    tx_buff[1] = 0x00;
    tx_buff[2] = 0x00;
    tx_buff[3] = 0x00;
    tx_buff[4] = 0x00;
    tx_buff[5] = 0x95;
    desc.p_tx_buffer  = tx_buff;
    desc.tx_length    = 6;
    desc.p_rx_buffer  = rx_buff;
    desc.rx_length    = 8;
    nrfx_spim_xfer(&m_spim3, &desc, 0);
    // Enter main loop.
    for (;;)
        idle_state_handle();
