I am using the nRF52811 for my project. I am in the layout design phase...almost completed and I need some clarifications before I launch the first Proto.
I don't have experience with RF design so, I read a lot and I am using the nRF52840 Dongle as a reference for the PCB antenna.
- Looking at the gerbers provided for the dongle, I did not see any ground plane below the antenna area, can you please confirmed that it is correct?
- For the specific PCB antenna in the dongle...is there some calculation available to understand that design? Shape...W,L...
- I put the 3.9nH and 0.8pF for the filtering and matching (50ohms) and I have also added a Pi circuit just before the antenna for the final tuning. Is there a suggested way to measure the antenna impedance? Should I add a coaxial connector, such as an MM8130-2600 to measure the ANT impedance with a VNA?
- If I use an MM8130-2600, should I put it just before the Pi circuit or just after?
Thanks for your support
Gian
