Extended advertising works on nRF52840 but not nRF52811
I am trying to get an nRF52811 to do extended advertising.
I am using:  nRF5_SDK_17.0.2,   version 7.2.0 of s140, SEGGER Embedded Studio 4.52, Windows 10
I have stripped down the rscs example and gotten it to run on both an nRF52840 and an nRF52811.  Using a modified version of the rscs_c example, I can detect extended advertisements from the nRF52840, but not from the nRF52811.  It does not crash  on the nRF52811, just fails to send advertisements that I can detect.
The two versions use the exact same main.c, included here:
#include <stdint.h>
#include <string.h>
#include "ble_advertising.h"
#include "nrf_sdh.h"
#include "app_timer.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "ble_bas.h"
#include "SEGGER_RTT.h"
#define DEVICE_NAME                     "nRF Ext Adv"      /**< Name of device. Will be included in the advertising data. */
#define APP_ADV_INTERVAL                40                                      /**< The advertising interval (in units of 0.625 ms. This value corresponds to 25 ms). */
#define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(500, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(1000, UNIT_1_25_MS)       /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY                   0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
APP_TIMER_DEF(m_rsc_meas_timer_id);                                             /**< RSC measurement timer. */
NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
static ble_uuid_t m_adv_uuids[] =    {};                                        /**< Universally unique service identifiers. */
static void ble_stack_init(void);
static void gap_params_init(void);
static void gatt_init(void);
static void advertising_init(void);
static void advertising_start(bool erase_bonds);;
void assert_nrf_callback(uint16_t line_num, const uint8_t * p_file_name);
static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context);
static void idle_state_handle(void);
static void rsc_meas_timeout_handler(void * p_context);
static void application_timers_start(void);
static void on_adv_evt(ble_adv_evt_t ble_adv_evt);
static void timers_init();
/**@brief Function for application main entry.
    bool erase_bonds;
    // Initialize.
    timers_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    // Start execution.
    SEGGER_RTT_WriteString(0, "Simple Extended Advertiser.\r\n");
    application_timers_start();
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;) {
        idle_state_handle();
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    ret_code_t err_code;
    // Initialize timer module.
    err_code = app_timer_init();
    // Create timers.
    err_code = app_timer_create(&m_rsc_meas_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                rsc_meas_timeout_handler);
    uint32_t ram_start = 0;
    // Enable BLE stack.
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
/**@brief Function for initializing the GATT module.
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = false;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    init.config.ble_adv_fast_enabled     = true;
    init.config.ble_adv_fast_interval    = APP_ADV_INTERVAL;
    init.config.ble_adv_fast_timeout     = APP_ADV_DURATION;
    init.config.ble_adv_primary_phy      = BLE_GAP_PHY_1MBPS;
    init.config.ble_adv_secondary_phy    = BLE_GAP_PHY_2MBPS;
    init.config.ble_adv_extended_enabled = true;
    ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
    ret_code_t err_code = NRF_SUCCESS;
            SEGGER_RTT_WriteString(0,"PHY update request.\r\n");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
             SEGGER_RTT_WriteString(0,"GATT Client Timeout.\r\n");
        case BLE_GATTS_EVT_TIMEOUT:
            SEGGER_RTT_WriteString(0,"GATT Server Timeout.\r\n");
            SEGGER_RTT_printf(0,"ble_evt_handler()- Unhandled event type, %d\r\n", p_ble_evt->header.evt_id);
            // No implementation needed.
    SEGGER_RTT_WriteString(0, "idle_state_handler()\r\n");
/**@brief Function for handling the Running Speed and Cadence measurement timer timeout.
 * @details This function will be called each time the running speed and cadence
 *          measurement timer expires.
 * @param[in]   p_context   Pointer used for passing some arbitrary information (context) from the
 *                          app_start_timer() call to the timeout handler.
    UNUSED_PARAMETER(p_context);
    SEGGER_RTT_WriteString(0, "Measurement Timer Handler!\r\n");
/**@brief Function for starting application timers.
    uint32_t rsc_meas_timer_ticks;
    // Start application timers.
    rsc_meas_timer_ticks = APP_TIMER_TICKS(1000); // 1Hz
    err_code = app_timer_start(m_rsc_meas_timer_id, rsc_meas_timer_ticks, NULL);
    SEGGER_RTT_WriteString(0, "on_adv_evt()!\r\n");
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            SEGGER_RTT_WriteString(0,"Fast advertising.\r\n");
        case BLE_ADV_EVT_IDLE:
            SEGGER_RTT_WriteString(0,"Idle.\r\n");
            SEGGER_RTT_printf(0,"on_adv_evt() - Unhandled event, %d\r\n", ble_adv_evt);
The only differences between the two .emProject files are these:
2,3c2,3
< <solution Name="ble_app_rscs_pca10056_s140" target="8" version="2">
<   <project Name="ble_app_rscs_pca10056_s140">
> <solution Name="ble_app_rscs_pca10056e_52811_s140" target="8" version="2">
>   <project Name="ble_app_rscs_pca10056e_52811_s140">
17c17
<       arm_target_device_name="nRF52840_xxAA"
>       arm_target_device_name="nRF52811_xxAA"
26c26
< NRF52840_XXAA;
> NRF52811_XXAA;
164c164
<       debug_register_definition_file="../../../../../../modules/nrfx/mdk/nrf52840.svd"
>       debug_register_definition_file="../../../../../../modules/nrfx/mdk/nrf52811.svd"
175c175
< FLASH_PH_SIZE=0x100000;
> FLASH_PH_SIZE=0x30000;
177c177
< RAM_PH_SIZE=0x40000;
> RAM_PH_SIZE=0x6000;
179,181c179,181
< FLASH_SIZE=0xd9000;
< RAM_START=0x20002260;
< RAM_SIZE=0x3dda0"
> FLASH_SIZE=0x9000;
> RAM_START=0x20002300;
> RAM_SIZE=0x3d00"
216c216
<       <file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf52840.s" />
>       <file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf52811.s" />
218c218
<       <file file_name="../../../../../../modules/nrfx/mdk/system_nrf52840.c" />
>       <file file_name="../../../../../../modules/nrfx/mdk/system_nrf52811.c" />
The sdk_config.h for the nRF52840 has many more *_ENABLED defines, none of which are enabled.  Other than that, the only differences between the two sdk_config.h are these:
456c438
< #define NRFX_PRS_BOX_2_ENABLED 0
> #define NRFX_PRS_BOX_2_ENABLED 1
919c835
< #define NRF_PWR_MGMT_CONFIG_FPU_SUPPORT_ENABLED 1
> #define NRF_PWR_MGMT_CONFIG_FPU_SUPPORT_ENABLED 0
I would appreciate any help you can give in figuring out why this will run on the nRF52840 but not the nRF52811.
Craig
  • Update:
    Using nRF Sniffer, ADV_EXT_IND packets are visible from both the 52840 and the 52811. However, nRF sniffer does not help in examining the content of the advertisements.  To examine the contents, I am using a modified version of the rscs_c example, included below.  This program, running on a 52840 DK board detects advertisements from the 52840 but not from the 52811.  Any help figuring out why would be very much appreciated.
    Modified rscs_c example for detecting extended advertisements.  The most relevant modifications are in the BLE_GAP_EVT_ADV_REPORT case in the  ble_evt_handler() function.
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
     * @brief BLE Running Speed and Cadence Collector application main file.
     * This file contains the source code for a sample Running Speed and Cadence collector application.
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf_sdm.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_db_discovery.h"
    #include "ble_srv_common.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_pwr_mgmt.h"
    #include "app_util.h"
    #include "app_error.h"
    #include "ble_dis_c.h"
    #include "ble_rscs_c.h"
    #include "bsp_btn_ble.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "fds.h"
    #include "nrf_fstorage.h"
    #include "ble_conn_state.h"
    #include "nrf_ble_gq.h"
    #include "nrf_drv_power.h"
    #include "nrf_ble_scan.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG        1                                   /**< Tag that identifies the BLE configuration of the SoftDevice. */
    #define APP_BLE_OBSERVER_PRIO       3                                   /**< BLE observer priority of the application. There is no need to modify this value. */
    #define APP_SOC_OBSERVER_PRIO       1                                   /**< SoC observer priority of the application. There is no need to modify this value. */
    #define SEC_PARAM_BOND              1                                   /**< Perform bonding. */
    #define SEC_PARAM_MITM              0                                   /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC              0                                   /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS          0                                   /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES   BLE_GAP_IO_CAPS_NONE                /**< No I/O capabilities. */
    #define SEC_PARAM_OOB               0                                   /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE      7                                   /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE      16                                  /**< Maximum encryption key size. */
    #define SCAN_INTERVAL               0x00A0                              /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW                 0x0050                              /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_DURATION           0x0000                              /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning continues until it is explicitly disabled. */
    #define SCAN_DURATION_WITELIST  300                                /**< Duration of the scanning in units of 10 milliseconds. */
    #define MIN_CONNECTION_INTERVAL     MSEC_TO_UNITS(7.5, UNIT_1_25_MS)    /**< Determines minimum connection interval in milliseconds. */
    #define MAX_CONNECTION_INTERVAL     MSEC_TO_UNITS(30, UNIT_1_25_MS)     /**< Determines maximum connection interval in milliseconds. */
    #define SLAVE_LATENCY               0                                   /**< Determines slave latency in counts of connection events. */
    #define SUPERVISION_TIMEOUT         MSEC_TO_UNITS(400, UNIT_10_MS)     /**< Determines supervision timeout in units of 10 millisecond. */
    #define TARGET_UUID                 BLE_UUID_RUNNING_SPEED_AND_CADENCE  /**< Target UUID that the application looks for. */
    /**@brief Variable length data encapsulation in terms of length and pointer to data. */
    typedef struct
        uint8_t * p_data;   /**< Pointer to data. */
        uint16_t  data_len; /**< Length of data. */
    } data_t;
    /**@brief Strings to display data retrieved by Device Information Service client module. */
    static char const * const m_dis_char_names[] =
        "Manufacturer Name String",
        "Model Number String     ",
        "Serial Number String    ",
        "Hardware Revision String",
        "Firmware Revision String",
        "Software Revision String",
        "System ID",
        "IEEE 11073-20601 Regulatory Certification Data List",
        "PnP ID"
    NRF_BLE_GQ_DEF(m_ble_gatt_queue,                            /**< BLE GATT Queue instance. */
                   NRF_SDH_BLE_CENTRAL_LINK_COUNT,
                   NRF_BLE_GQ_QUEUE_SIZE);
    BLE_DIS_C_DEF(m_ble_dis_c);                                 /**< Device Information Service client instance. */
    BLE_RSCS_C_DEF(m_rscs_c);                                   /**< Running Speed and Cadence Service client instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc);                            /**< Database discovery module instance. */
    NRF_BLE_SCAN_DEF(m_scan);                                   /**< Scanning Module instance. */
    static uint16_t              m_conn_handle;                 /**< Current connection handle. */
    static bool                  m_whitelist_disabled;          /**< True if the whitelist is temporarily disabled. */
    static bool                  m_memory_access_in_progress;   /**< Flag to keep track of ongoing operations on persistent memory. */
    static bool                  m_rscs_log_enabled;            /**< Flag to enable logs related with RSCS measurements. */
    static ble_gap_scan_params_t m_scan_param =                 /**< Scan parameters requested for scanning and connection. */
        .active        = 0x01,
        .interval      = NRF_BLE_SCAN_SCAN_INTERVAL,
        .window        = NRF_BLE_SCAN_SCAN_WINDOW,
        .filter_policy = BLE_GAP_SCAN_FP_WHITELIST,
        .timeout       = SCAN_DURATION_WITELIST,
        .scan_phys     = BLE_GAP_PHY_1MBPS,
        .extended      = 1,
    static void scan_start(void);
    /**@brief Function for handling asserts in the SoftDevice.
     * @details This function is called in case of an assert in the SoftDevice.
     * @warning This handler is only an example and is not meant for the final product. You need to analyze
     *          how your product is supposed to react in case of an assert.
     * @param[in] line_num     Line number of the failing assert call.
     * @param[in] p_file_name  File name of the failing assert call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for handling the Running Speed and Cadence Service Client and
     *        Device Information Service Client errors.
    static void service_error_handler(uint32_t nrf_error)
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling database discovery events.
     * @details This function is a callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function forwards the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        ble_rscs_on_db_disc_evt(&m_rscs_c, p_evt);
        ble_dis_c_on_db_disc_evt(&m_ble_dis_c, p_evt);
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        pm_handler_on_pm_evt(p_evt);
        pm_handler_disconnect_on_sec_failure(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
                scan_start();
     * @brief Function for handling shutdown events.
     * @param[in]   event       Shutdown type.
    static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
                // Prepare wakeup buttons.
        return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            case BLE_GAP_EVT_CONNECTED:
                SEGGER_RTT_printf(0,"BLE_GAP_EVT_CONNECTED\r\n");
                // Discover the peer's services.
                err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
                if (ble_conn_state_central_conn_count() < NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                    scan_start();
            } break;
            case BLE_GAP_EVT_TIMEOUT:
                SEGGER_RTT_printf(0,"BLE_GAP_EVT_TIMEOUT\r\n");
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    SEGGER_RTT_printf(0,"Connection Request timed out.\r\n");
            } break;
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                SEGGER_RTT_printf(0,"BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST\r\n");
                // Accepting parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                        &p_gap_evt->params.conn_param_update_request.conn_params);
            } break;
               SEGGER_RTT_printf(0,"Disconnected. conn_handle: 0x%x, reason: 0x%x\r\n",
                             p_gap_evt->params.disconnected.reason);
                    scan_start();
            } break;
               SEGGER_RTT_printf(0,"PHY update request.\r\n");
            } break;
               SEGGER_RTT_printf(0,"GATT Client Timeout.\r\n");
            } break;
                SEGGER_RTT_printf(0,"GATT Server Timeout.\r\n");
            } break;
             case BLE_GAP_EVT_ADV_REPORT:
                //NRF_LOG_DEBUG("\x1B[30m GAP Advert Report");
                SEGGER_RTT_WriteString(0, "\x1B[30m Advert Report!\r\n");
                if(p_ble_evt->evt.gap_evt.params.adv_report.type.extended_pdu){
                    SEGGER_RTT_printf(0,"EXTENDED, type = %d\r\n", p_ble_evt->evt.gap_evt.params.adv_report.type);
                }else{
                    SEGGER_RTT_printf(0,"Short, type = %d\r\n", p_ble_evt->evt.gap_evt.params.adv_report.type);
                const ble_data_t *datap = &p_ble_evt->evt.gap_evt.params.adv_report.data;
                SEGGER_RTT_printf(0,"Data len = %d\r\n", datap->len);
                int i = 0;
                while(i < datap->len){
                    for(int col=0; col<8 && i<datap->len; col++){
                        SEGGER_RTT_printf(0,"%c", datap->p_data[i]);
                        i++;
                    SEGGER_RTT_printf(0,"\r\n");
            } break;
                SEGGER_RTT_printf(0,"Unhandled event type: %d\r\n", p_ble_evt->header.evt_id);
            } break;
     * @brief SoftDevice SoC event handler.
     * @param[in] evt_id    SoC event.
     * @param[in] p_context Context.
    static void soc_evt_handler(uint32_t evt_id, void * p_context)
        switch (evt_id)
            case NRF_EVT_FLASH_OPERATION_SUCCESS:
            /* fall through */
            case NRF_EVT_FLASH_OPERATION_ERROR:
                if (m_memory_access_in_progress)
                    m_memory_access_in_progress = false;
                    scan_start();
        // Register handlers for BLE and SoC events.
        NRF_SDH_SOC_OBSERVER(m_soc_observer, APP_SOC_OBSERVER_PRIO, soc_evt_handler, NULL);
    /**@brief Function for disabling the use of the whitelist for scanning.
    static void whitelist_disable(void)
        if (!m_whitelist_disabled)
           SEGGER_RTT_printf(0,"Whitelist temporarily disabled.\r\n");
            m_whitelist_disabled = true;
            nrf_ble_scan_stop();
            scan_start();
     * @param[in]   event   Event generated by button press.
        switch (event)
            case BSP_EVENT_SLEEP:
                nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle,
            case BSP_EVENT_WHITELIST_OFF:
                whitelist_disable();
    /**@brief Running Speed and Cadence collector handler.
    static void rscs_c_evt_handler(ble_rscs_c_t * p_rsc_c, ble_rscs_c_evt_t * p_rsc_c_evt)
        switch (p_rsc_c_evt->evt_type)
            case BLE_RSCS_C_EVT_DISCOVERY_COMPLETE:
                // Initiate bonding.
                err_code = ble_rscs_c_handles_assign(&m_rscs_c,
                                                     p_rsc_c_evt->conn_handle,
                                                     &p_rsc_c_evt->params.rscs_db);
                err_code = pm_conn_secure(p_rsc_c_evt->conn_handle, false);
                if (err_code != NRF_ERROR_BUSY)
                // Running Speed and Cadence Service discovered. Enable Running Speed and Cadence notifications.
                err_code = ble_rscs_c_rsc_notif_enable(p_rsc_c);
                SEGGER_RTT_printf(0,"Running Speed and Cadence Service discovered.");
            case BLE_RSCS_C_EVT_RSC_NOTIFICATION:
                if (m_rscs_log_enabled)
                    SEGGER_RTT_printf(0,"");
                    SEGGER_RTT_printf(0,"RSC Measurement received %d ",
                             p_rsc_c_evt->params.rsc.inst_speed);
                    SEGGER_RTT_printf(0,"Instantanious Speed   = %d", p_rsc_c_evt->params.rsc.inst_speed);
                    if (p_rsc_c_evt->params.rsc.is_inst_stride_len_present)
                        SEGGER_RTT_printf(0,"Stride Length         = %d",
                               p_rsc_c_evt->params.rsc.inst_stride_length);
                    if (p_rsc_c_evt->params.rsc.is_total_distance_present)
                        SEGGER_RTT_printf(0,"Total Distance = %u",
                               (unsigned int)p_rsc_c_evt->params.rsc.total_distance);
                    SEGGER_RTT_printf(0,"Instantanious Cadence = %d", p_rsc_c_evt->params.rsc.inst_cadence);
                    SEGGER_RTT_printf(0,"Flags");
                    SEGGER_RTT_printf(0,"  Stride Length Present = %d",
                           p_rsc_c_evt->params.rsc.is_inst_stride_len_present);
                    SEGGER_RTT_printf(0,"  Total Distance Present= %d",
                           p_rsc_c_evt->params.rsc.is_total_distance_present);
                    SEGGER_RTT_printf(0,"  Is Running            = %d", p_rsc_c_evt->params.rsc.is_running);
    /**@brief Function for reading all characteristics that can be present in DIS.
     * @return    The number of discovered characteristics.
    static uint32_t ble_dis_c_all_chars_read(void)
        uint32_t   disc_char_num = 0;
        for (ble_dis_c_char_type_t char_type = (ble_dis_c_char_type_t) 0;
             char_type < BLE_DIS_C_CHAR_TYPES_NUM;
             char_type++)
            err_code = ble_dis_c_read(&m_ble_dis_c, char_type);
            // The NRF_ERROR_INVALID_STATE error code means that the characteristic is not present in DIS.
                disc_char_num++;
        return disc_char_num;
    /**@brief Function for logging string characteristics that can be present in Device Information Service.
     * @param[in] char_type Type of string characteristic.
     * @param[in] p_string  Response data of the characteristic that has been read.
    static void ble_dis_c_string_char_log(ble_dis_c_char_type_t            char_type,
                                          ble_dis_c_string_t const * const p_string)
        char response_data_string[BLE_DIS_C_STRING_MAX_LEN] = {0};
        if (sizeof(response_data_string) > p_string->len)
            memcpy(response_data_string, p_string->p_data, p_string->len);
           // SEGGER_RTT_printf(0,"%s: %s",
           //              m_dis_char_names[char_type],
           //              nrf_log_push((char *) response_data_string));
            SEGGER_RTT_printf(0,"String buffer for DIS characteristics is too short.\r\n");
    /**@brief Function for logging System ID characteristic data that can be present in Device Information Service.
     * @param[in] p_sys_id Pointer to structure that describes the content of the System ID characteristic.
    static void ble_dis_c_system_id_log(ble_dis_sys_id_t const * const p_sys_id)
        SEGGER_RTT_printf(0,"%s:", m_dis_char_names[BLE_DIS_C_SYS_ID]);
        SEGGER_RTT_printf(0," Manufacturer Identifier:            0x%010X\r\n", p_sys_id->manufacturer_id);
        SEGGER_RTT_printf(0," Organizationally Unique Identifier: 0x%06X\r\n", p_sys_id->organizationally_unique_id);
    /**@brief Function for logging IEEE 11073-20601 Regulatory Certification Data List characteristic
     *        data that can be present in DIS.
     * @param[in] p_cert_list  Pointer to structure that describes the content of Certification Data List
     *                         characteristic.
    static void ble_dis_c_cert_list_log(ble_dis_reg_cert_data_list_t const * const p_cert_list)
       SEGGER_RTT_printf(0,"%s:", m_dis_char_names[BLE_DIS_C_CERT_LIST]);
        NRF_LOG_HEXDUMP_INFO(p_cert_list->p_list, p_cert_list->list_len);
    /**@brief Function for logging PnP ID characteristic data that can be present in Device Information Service.
     * @param[in] p_pnp_id Pointer to structure that describes the content of PnP ID characteristic.
    static void ble_dis_c_pnp_id_log(ble_dis_pnp_id_t const * const p_pnp_id)
        SEGGER_RTT_printf(0,"%s:", m_dis_char_names[BLE_DIS_C_PNP_ID]);
        SEGGER_RTT_printf(0," Vendor ID Source: 0x%02X", p_pnp_id->vendor_id_source);
        SEGGER_RTT_printf(0," Vendor ID:        0x%04X", p_pnp_id->vendor_id);
       SEGGER_RTT_printf(0," Product ID:       0x%04X", p_pnp_id->product_id);
        SEGGER_RTT_printf(0," Product Version:  0x%04X", p_pnp_id->product_version);
    /**@brief Device Information Service client handler.
    static void ble_dis_c_evt_handler(ble_dis_c_t * p_ble_dis_c, ble_dis_c_evt_t const * p_ble_dis_evt)
        static uint32_t disc_chars_num     = 0;
        static uint32_t disc_chars_handled = 0;
        switch (p_ble_dis_evt->evt_type)
            case BLE_DIS_C_EVT_DISCOVERY_COMPLETE:
                err_code = ble_dis_c_handles_assign(p_ble_dis_c,
                                                    p_ble_dis_evt->conn_handle,
                                                    p_ble_dis_evt->params.disc_complete.handles);
                disc_chars_num     = ble_dis_c_all_chars_read();
                SEGGER_RTT_printf(0,"Device Information Service discovered.\r\n");
            case BLE_DIS_C_EVT_DIS_C_READ_RSP:
                ble_dis_c_evt_read_rsp_t const * p_read_rsp = &p_ble_dis_evt->params.read_rsp;
                //Print header log.
                if ((disc_chars_handled == 0) && (disc_chars_num != 0))
                    SEGGER_RTT_printf(0,"Device Information:\r\n");
                switch (p_read_rsp->char_type)
                    case BLE_DIS_C_MANUF_NAME:
                    case BLE_DIS_C_MODEL_NUM:
                    case BLE_DIS_C_SERIAL_NUM:
                    case BLE_DIS_C_HW_REV:
                    case BLE_DIS_C_FW_REV:
                    case BLE_DIS_C_SW_REV:
                        ble_dis_c_string_char_log(p_read_rsp->char_type, &p_read_rsp->content.string);
                    case BLE_DIS_C_SYS_ID:
                        ble_dis_c_system_id_log(&p_read_rsp->content.sys_id);
                    case BLE_DIS_C_CERT_LIST:
                        ble_dis_c_cert_list_log(&p_read_rsp->content.cert_list);
                    case BLE_DIS_C_PNP_ID:
                        ble_dis_c_pnp_id_log(&p_read_rsp->content.pnp_id);
                disc_chars_handled++;
                if(disc_chars_handled == disc_chars_num)
                    disc_chars_num     = 0;
                    m_rscs_log_enabled = true;
            case BLE_DIS_C_EVT_DIS_C_READ_RSP_ERROR:
                SEGGER_RTT_printf(0,"Read request for: %s characteristic failed with gatt_status: 0x%04X.\r\n",
                              m_dis_char_names[p_ble_dis_evt->params.read_rsp.char_type],
                              p_ble_dis_evt->params.read_rsp_err.gatt_status);
            case BLE_DIS_C_EVT_DISCONNECTED:
     * @brief Running Speed and Cadence collector initialization.
    static void rscs_c_init(void)
        ble_rscs_c_init_t rscs_c_init_obj;
        rscs_c_init_obj.evt_handler   = rscs_c_evt_handler;
        rscs_c_init_obj.error_handler = service_error_handler;
        rscs_c_init_obj.p_gatt_queue  = &m_ble_gatt_queue;
        ret_code_t err_code = ble_rscs_c_init(&m_rscs_c, &rscs_c_init_obj);
    /**@brief Function for initializing the Device Information Service client. */
    static void dis_c_init(void)
        ble_dis_c_init_t init;
        memset(&init, 0, sizeof(ble_dis_c_init_t));
        init.evt_handler   = ble_dis_c_evt_handler;
        init.error_handler = service_error_handler;
        init.p_gatt_queue  = &m_ble_gatt_queue;
        err_code = ble_dis_c_init(&m_ble_dis_c, &init);
    /**@brief Function for initializing the Peer Manager.
     * @param[in] erase_bonds  Indicates whether the bonding information must be cleared from
     *                         persistent storage during the initialization of the Peer Manager.
    static void peer_manager_init()
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Clear bonding information from the persistent storage.
    static void delete_bonds(void){
       SEGGER_RTT_printf(0,"Erase bonds\r\n");
        err_code = pm_peers_delete();
     * @brief Database discovery collector initialization.
    static void db_discovery_init(void)
        ble_db_discovery_init_t db_init;
        memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
        db_init.evt_handler  = db_disc_handler;
        db_init.p_gatt_queue = &m_ble_gatt_queue;
        ret_code_t err_code = ble_db_discovery_init(&db_init);
    /**@brief Retrive a list of peer manager peer IDs.
     * @param[inout] p_peers   The buffer where to store the list of peer IDs.
     * @param[inout] p_size    In: The size of the @p p_peers buffer.
     *                         Out: The number of peers copied in the buffer.
    static void peer_list_get(pm_peer_id_t * p_peers, uint32_t * p_size)
        pm_peer_id_t peer_id;
        uint32_t     peers_to_copy;
        peers_to_copy = (*p_size < BLE_GAP_WHITELIST_ADDR_MAX_COUNT) ?
                         *p_size : BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
        peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
        *p_size = 0;
        while ((peer_id != PM_PEER_ID_INVALID) && (peers_to_copy--))
            p_peers[(*p_size)++] = peer_id;
            peer_id = pm_next_peer_id_get(peer_id);
    static void whitelist_load()
        ret_code_t   ret;
        pm_peer_id_t peers[8];
        uint32_t     peer_cnt;
        memset(peers, PM_PEER_ID_INVALID, sizeof(peers));
        peer_cnt = (sizeof(peers) / sizeof(pm_peer_id_t));
        // Load all peers from the flash and whitelist them.
        peer_list_get(peers, &peer_cnt);
        ret = pm_whitelist_set(peers, peer_cnt);
        APP_ERROR_CHECK(ret);
        // Setup the list of device identities.
        // Some SoftDevices do not support this feature.
        ret = pm_device_identities_list_set(peers, peer_cnt);
        if (ret != NRF_ERROR_NOT_SUPPORTED)
    static void on_whitelist_req(void)
        // Whitelist buffers.
        ble_gap_addr_t whitelist_addrs[8];
        ble_gap_irk_t  whitelist_irks[8];
        memset(whitelist_addrs, 0x00, sizeof(whitelist_addrs));
        memset(whitelist_irks,  0x00, sizeof(whitelist_irks));
        uint32_t addr_cnt = (sizeof(whitelist_addrs) / sizeof(ble_gap_addr_t));
        uint32_t irk_cnt  = (sizeof(whitelist_irks)  / sizeof(ble_gap_irk_t));
        // Reload the whitelist and whitelist all peers.
        whitelist_load();
        ret_code_t ret;
        // Get the whitelist previously set with pm_whitelist_set().
        ret = pm_whitelist_get(whitelist_addrs, &addr_cnt,
                               whitelist_irks,  &irk_cnt);
        if (((addr_cnt == 0) && (irk_cnt == 0)) ||
            (m_whitelist_disabled))
            m_scan_param.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL;
            ret = nrf_ble_scan_params_set(&m_scan, &m_scan_param);
    /**@brief Function for handling Scanning Module events.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        switch(p_scan_evt->scan_evt_id)
            case NRF_BLE_SCAN_EVT_WHITELIST_REQUEST:
                on_whitelist_req();
                m_whitelist_disabled = false;
            } break;
            case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                err_code = p_scan_evt->params.connecting_err.err_code;
            } break;
            case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
                SEGGER_RTT_printf(0,"scan_evt_handler(): Scan timed out.\r\n");
                scan_start();
            } break;
            case NRF_BLE_SCAN_EVT_FILTER_MATCH:
            case NRF_BLE_SCAN_EVT_WHITELIST_ADV_REPORT:
    /**@brief Function for initializing the scanning and setting the filters.
    static void scan_init(void)
        nrf_ble_scan_init_t init_scan;
        ble_uuid_t uuid =
            .type = BLE_UUID_TYPE_BLE,
            .uuid = TARGET_UUID,
        memset(&init_scan, 0, sizeof(init_scan));
        init_scan.connect_if_match = false;
        init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
        init_scan.p_scan_param     = &m_scan_param;
        err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
        err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &uuid);
        err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
    /**@brief Function for starting scanning.
        // If there is any pending write to flash, defer scanning until it completes.
        if (nrf_fstorage_is_busy(NULL))
            m_memory_access_in_progress = true;
            return;
        SEGGER_RTT_printf(0,"scan_stert(): Starting scan.\r\n");
        m_scan_param.filter_policy = BLE_GAP_SCAN_FP_WHITELIST;
        err_code = nrf_ble_scan_params_set(&m_scan, &m_scan_param);
        err_code = nrf_ble_scan_start(&m_scan);
        err_code = bsp_indication_set(BSP_INDICATE_SCANNING);
    /**@brief Function for initializing buttons and LEDs.
     * @param[out] p_erase_bonds  True if the clear bonding button was pressed to wake the application up.
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    /**@brief Function for initializing logging. */
    static void log_init(void)
    /**@brief Function for initializing the timer. */
    static void timer_init(void)
    /**@brief Function for initializing the GATT module. */
     * @details Handles any pending log operations, then sleeps until the next event occurs.
            nrf_pwr_mgmt_run();
    /**@brief Function for starting a scan, or instead triggering it from the peer manager (after
     *        deleting bonds).
     * @param[in] p_erase_bonds Pointer to a bool to determine whether bonds are to be deleted before scanning.
    void scanning_start(bool * p_erase_bonds)
        // Start scanning for peripherals and initiate connection
        // with devices that advertise GATT Service UUID.
        if (*p_erase_bonds == true)
            // Scan is started by the PM_EVT_PEERS_DELETE_SUCCEEDED event.
            delete_bonds();
            scan_start();
        bool erase_bonds;
        // Initialize.
        log_init();
        timer_init();
        power_management_init();
        ble_stack_init();
        gatt_init();
        peer_manager_init();
        db_discovery_init();
        rscs_c_init();
        dis_c_init();
        scan_init();
        whitelist_load();
        // Start execution.
        SEGGER_RTT_WriteString(0, "Extended Advertising Detection started.\r\n");
        scanning_start(&erase_bonds);
        // Enter main loop.
        for (;;)
            //SEGGER_RTT_WriteString(0, "Hello World from SEGGER!\r\n");
  • Hello Craig,
    Sorry for the delay. It looks like you have already performed the necessary steps to convert the project to the nRF52811 target, so I'm not sure what's missing. I also tried replicating the problem by setting up a similar test with the beacon example and a 52811 board, but I got the same result with both 52840 and 52811.
    I used a 52840 DK for scanning, and a 52811 board to do the extended beacon advertising. Attached below is the code I used for my testing. Could you try with these and see if you get the same result?
    7522.nRF5_SDK17.0.2_beacon_scanner_advertister_extended.zip
    Vidar
  • Vidar,
    I seem to get the same result.  Thank you very much for the code.
    It remains a mystery as to why my approach to the problem failed, but with the example code you provided I now appear to have a working example of a sender and receiver of extended advertisements, so I can move on forward with my project.
    Thanks again,
    Craig
  • It's strange that it didn't work with your project then. I was starting to suspect it could be something hw related (like excessive clock drift). Anyway. Thank you for the update, I'm glad it worked. Just let us know if you run into this problem again.
