In mesh v4.2 NRF_BREAKPOINT_COND occurs when sending an array data to client node by UART terminal
Hi, everyone.
1. The followings are development enviroments :
- Dev. Enviroments : nRFSDK 16,  Mesh v4.2, Board PCA10040
- Project Example :  nrf5_SDK_for_Mesh_v4.2.0_src\examples\sdk_coexist\ble_app_uart_coexist\pca10040\s132\ses
2. Application Data Flow
   - At first, Mobile app send a string data to Mesh-server  ---> Client Node gets the data --> PC gets the data
   - The PC replys to Client node with 8 bytes by uart communication to respond to the Moibile app.
   - I atach the following codes
3. Problems
  - It works with button_event_handler for sendind data.
  - But NRF_BREAKPOINT_COND occurs when sending a string through the UART Terminal (ex, SerialPort program)
  - I tried to figure out what the reason is , I cannot find why.
  - Maybe priority issue?
 -  Anybody help me if you got same troubles and solved.
 ---- mesh-main.c ----
/* Get public address for accessing server */
static uint32_t assign_server_address(uint16_t new_address)
uint32_t status = NRF_SUCCESS;
dsm_handle_t publish_address_handle = DSM_HANDLE_INVALID;
nrf_mesh_address_t publish_address_stored;
uint16_t destination_address = new_address;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "=== assign_server_address ===\n")
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "new Address : %x \n", new_address);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "destination Address : %x \n", destination_address);
if (access_model_publish_address_get(m_clients[0].model_handle, &publish_address_handle) != NRF_SUCCESS) {
status = dsm_address_publish_add(destination_address, &publish_address_handle);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "access_model_publish_address_get %d.\n", status)
} else {
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "access_model_publish_address_get:SUCCESS\n");
if (dsm_address_get(publish_address_handle, &publish_address_stored) == NRF_SUCCESS)
if ((publish_address_stored.type == NRF_MESH_ADDRESS_TYPE_VIRTUAL) ||
(publish_address_stored.type != NRF_MESH_ADDRESS_TYPE_VIRTUAL &&
publish_address_stored.value != destination_address))
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Destination Address is Different.\n")
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "new_addre %x : stored.val %x \n", destination_address, publish_address_stored.value);
/* This should never assert */
NRF_MESH_ASSERT(dsm_address_publish_remove(publish_address_handle) == NRF_SUCCESS);
status = dsm_address_publish_remove(publish_address_handle); // sometimes dead here
} else {
/* Use the retrieved publish_address_handle */
} else {
// get publish_address_handle
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "else : dsm_address_publish_add : Success !!!\n");
switch (status) {
case NRF_ERROR_NO_MEM:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "NRF_ERROR_NO_MEM\n");
return status;
case NRF_ERROR_NULL:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Unexpected NULL pointer is given.\n"); // dsm_address_publish_add Fail
case NRF_SUCCESS:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "dsm_address_publish_add is Success.\n"); // dsm_address_publish_add Success
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "ACCESS_STATUS_UNSPECIFIED_ERROR\n");
return status;
NRF_MESH_ASSERT(access_model_publish_address_set(m_clients[0].model_handle, publish_address_handle) == NRF_SUCCESS);
return status;
[main.c]
[uart setting]
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOW,
err_code);
[uart_event_hadler]
     case APP_UART_DATA_READY:
else if (STX_FLAG == true && RECEIPT_FLAG == true)   //  Get  a string data from UART terminal  (baudrate 57600 or 115200 tests)
index++;
if (index == 4 ) {
Msg_Length = calc_datalength(data_array);
if (index == Msg_Length)                                                    // check Message arrived
  memcpy(message_array, data_array, Msg_Length);       // copy data_array to message_array
  MESSAGE_READY_FLAG = true;                                   // make MESSAGE_READY_FLAG to be true
[main]
uart_init();
log_init();
mesh_main_initialize();
// Start execution.
advertising_start();
mesh_main_start();
for (;;)
  if(MESSAGE_READY_FLAG == true)
     MESSAGE_READY_FLAG = false;
     _generic_onoff_client_set(message_array);     // call mesh-
   idle_state_handle();
[mesh-main.c]
uint32_t _generic_onoff_client_set (uint8_t * message_array)
generic_onoff_set_params_t set_params;
model_transition_t transition_params;
static uint8_t tid = 0;
static uint16_t new_address1;
uint8_t tx_message[8] = {0};
tx_message[0] = message_array[1];
tx_message[7] = message_array[12];
set_params.on_off = tx_message;
// 2. set params
set_params.tid = tid++;
transition_params.delay_ms = APP_ONOFF_DELAY_MS;
transition_params.transition_time_ms = APP_ONOFF_TRANSITION_TIME_MS;
// 3.
access_model_reliable_cancel(m_clients[0].model_handle);
// 4. Assign destination address
new_address1 = ((0xffff & message_array[5]) << 8) + message_array[6];
NRF_LOG_INFO(" start new dest_address = %4x \n", new_address1);
status = assign_server_address(new_address1);
switch (status)
case NRF_SUCCESS:
// 5. send message
status = generic_onoff_client_set(&m_clients[0], &set_params, &transition_params);
switch (status)
case NRF_SUCCESS:
3. Problems
   - I modified the genric_onoff_model  for sending a sting.
   - It works fine to send  a string by using button_event_handler in client node
[mesh_main_button_event_handler]
void mesh_main_button_event_handler(uint32_t button_number)
uint8_t tx_message[8] = {0xc7, 0x30, 0x31, 0x32, 0x33, 0x34, 0x35, 0x36}; //ok
uint16_t uart_length = 8;
/* Increase button number because the buttons on the board is marked with 1 to 4 */
button_number++;
NRF_LOG_INFO("Button %u pressed\n", button_number);
/* Button 1: On, Button 2: Off, Client[0] --> ODD Group : Board 1
* Button 2: On, Button 4: Off, Client[1] --> EVEN Group : Board 2
switch(button_number)
case 1:
case 2:
case 3:
//set_params.on_off = APP_STATE_ON;
set_params.on_off = tx_message; //choi
// case 2:
case 4:
set_params.on_off = APP_STATE_OFF;
assign_server_address(new_address);  // call for chainging unicast address for publinsing
generic_onoff_client_set(&m_clients[0], &set_params, &transition_params);  // send a string message
