question about nrfx_saadc_sample_convert blocking mechanism
To the kind attention of Nordic team,
About what has been said in https://devzone.nordicsemi.com/f/nordic-q-a/51879/saadc-in-sample-convert, I'd like to know if the blocking mechanism
used for nrfx_saadc_sample_convert could be in theory interfering with softdevice ble timing also. As we are experiencing rare, random BLE_HCI_CONNECTION_TIMEOUTs
during established ble connections. It could may very well be due to clock drifts. But also noticed that sometime we get BLE_HCI_CONNECTION_TIMEOUT after
using nrfx_saadc_sample_convert. Could be there any form of correlation, or softdevice is not affected at all by it in your opinion?
Thank you for your kind clarification,
Best regards
    That this function is blocking simply means that it contains a busy-loop, waiting for an event from the SAADC peripheral to be triggered (indicating that sampling is completed). The function should in no way block handling of timing-critical softdevice tasks, which runs at highest interrupt priority. The nrfx_saadc_sample_convert() function does not run in any interrupt context itself, it will run at the priority of the caller-function.
    Unless there is an error codes returned from the function that puts the application into the error handler, or a HardFault occurs (which could/would trigger a reset of the chip), I doubt that this function has anything to do with the BLE_HCI_CONNECTION_TIMEOUT.
    Jørgen
